Broken Tooth - Health & Safety - Contractor Talk
Broken Tooth
Old 10-18-2016, 11:35 PM   #1
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 3,624
Broken Tooth
I have a couple really impacted wisdom teeth that I was apparently supposed to have pulled years ago and never did. Anyhow it has really jacked up my back molar I guess and I broke it on something. Its cracked down to the root and I'm supposed to have a root canal and a possible implant done.
Anyhow, I've been putting it off but that sumbitch hurts. Should I just have it yanked with the other 2? I figure why bother fixing it, its only 1 and I already have a couple fake front teeth from a jetski accident so the novelty isnt really there. I don't think I really need it right? Havent been able to chew on my left side in like 2 months.
Yank it or fix it? Bout 800 dollar difference (extraction is cheaper).
Dude you thought the wall was built by Hitler. You had no plan or scheme. You look like a fool trying to convince us.
Deckhead is offline
Old 10-18-2016, 11:44 PM   #2
Mordekyle's Avatar
Rewards Points: 5,592
Re: Broken Tooth
Yank it.
No matter how good the new technology is, it falls far short of the original.
Mordekyle is online now
Old 10-19-2016, 12:06 AM   #3
The Sheriff
Jaws's Avatar
Rewards Points: 13,812
Re: Broken Tooth
I have all my teeth but one. I broke mine in a disagreement when I was around 21, dentist told me to pull it and I didnt. It finally cracked down to the root last year and it hurt a bit so I went my buddies wife (tooth doc) and I opted to pull it and have no implant. Hasn't bothered me any. Right rear next to wisdom.
I consider myself lucky I only broke one and only had cement put around a few others as many people who disagreed with me back then. Nose didn't fare as well, broke it twice.
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
Old 10-19-2016, 04:15 AM   #4
Billiam's Avatar
Trade: Landscaping & Irrigation
Rewards Points: 80
Re: Broken Tooth
I am the son of a dentist, almost became one myself, and have had similar discussions with numerous dentist friends because I am prone to cracking teeth (I just got an impression this morning for a crown on a cracked tooth). I guess the point of that first sentence is to establish my credibility; but if you are soliciting dental advice on a contractor forum, one could argue that you deserve the consequences of whatever bad decisions you make!http://img.contractortalk.com/smilies/laughing.gif
You need to consider many factors. This list is ordered by my personal preference, but you can reorder them as your values differ:
1. Pathology. If you have an active infection (abscess), bone or gum disease, or severe malocclusion (your bite is all out of whack), trying to save the tooth has a lower probability of success. Prioritize health over a single tooth.
2. Orthodontia (tooth alignment). If the broken molar is significantly misaligned or interfering with the wisdom teeth that need to come out, there may be a simple mechanical reason why it should be extracted. You need to get those wisdom teeth yanked ASAP, if they are truly "impacted" as you say. If the doc who would pull those wisdom teeth (3rd molars) says he needs that other (2nd) molar out of the way, then your decision is made for you.
3. Extent of crack. A crack below the gumline has a much lower probability of long-term successful repair, both structurally and due to inability to keep it from getting infested with nasty buggers.
4. Economics. Extractions are much cheaper than root canals plus restorations. Unless you absolutely can't afford anything but an extraction, don't let money influence your decision too much. Long-term costs of dealing with an empty socket often make the initial price difference meaningless. When you pull that tooth, you start a slow migration of your other teeth, especially the one on the opposing jaw that used to have a partner to bite against. It's a domino effect. If you are super-meticulous about your oral hygiene, you might be able to hold off the repercussions for many years. But I don't think you are, based on the fact that you avoided dealing with a known major problem for so long.
5. Aesthetics. I don't suppose you're the type of guy who just needs to have a perfectly white, straight, full set of teeth, are you? Well, unfortunately there are a lot of younger dentists who were trained in the new school of aesthetic dentistry and they like to make that decision for you. Here's a quick test to see if you need to find a new dentist: ask if they would put a gold crown on your tooth after the root canal. If they insist on a ceramic or porcelain piece of ****, or tell you they won't do gold, period, run away. I can elaborate on this if you wish.
All things being equal, you want to save the natural tooth whenever possible. That should be your default position unless other factors change the picture.
Root canal then an implant? Are you talking about the same tooth? Sounds like a scam. If you are getting an implant, where would it go unless the old tooth is yanked? Why whould you get a root canal on a tooth that is destined to be yanked? That's like getting a valve job just before an engine swap.
Billiam is offline
Old 10-19-2016, 04:46 AM   #5
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,466
Re: Broken Tooth
Whatever you do don't wait. Get it done. If you go the root canal option I recommend having it done by a specialist - not a general dentist. This was learned from one of my wife's teeth - the $10k tooth. We thought we had found a good dentist and one thing after another went wrong and before you know it it was going to be another couple of grand to get it fixed right by the correct people.
J L is offline
Old 10-19-2016, 08:14 AM   #6
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 1,047
Re: Broken Tooth
Well, first of all you only need a root canal if they are going to fix the tooth. If they are going to yank it don't let them work on it. You probably knew that, it's just the way you wrote it.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Deckhead (10-20-2016)
Old 10-19-2016, 08:25 AM   #7
KAP's Avatar
Trade: Custom
Rewards Points: 36,938
Re: Broken Tooth
Dental advice on CT... talk about trust...
$800?!! Man up dude and just do it yourself!...
Or use the tools you already have...
Seriously... you're young... $800 over the rest of your life is nothing... plus it might save you potentially having spacing/gap issues of your other teeth with a missing tooth...
That, or just get rid of them all and if you don't want all implants... dentures... just don't sneeze...
KAP is offline
Old 10-19-2016, 08:26 AM   #8
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 17,011
Re: Broken Tooth
So this is one of your wisdom teeth (extra molars back there)? If so, just have it removed.
(Btw, you can knock it out yourself with an ice skate and a rock. Did you see the film Cast Away?)
edit: Kap, you beat me to it!
MarkJames is offline
Old 10-19-2016, 08:43 AM   #9
KAP's Avatar
Trade: Custom
Re: Broken Tooth
Somehow I don't think Deckhead is the skating type...
Besides, it didn't work out too well for the Joker when he tried it...
I'm pretty sure he has a long-nose...
Tooth pain can make you do some stuff you'd normally laugh at...
Nothing like that sweet relief when it's over and your tongue becomes a detective feeling the difference...
KAP is offline
Old 10-19-2016, 08:43 AM   #10
Radical Basement Dweller
Robie's Avatar
Rewards Points: 7,710
Re: Broken Tooth
Just a little levity....very little....
Be true to your teeth and they won't be false to you...
Ignore your teeth and they will go away.
Get that sucker pulled.
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is online now
Old 10-19-2016, 08:56 AM   #11
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Re: Broken Tooth
I'm sure between all us trades here, our tools and a bottle of Jack.....we could have that sucker out no problem.......
CrpntrFrk is offline
The Following User Says Thank You to CrpntrFrk For This Useful Post:
KAP (10-19-2016)
Old 10-19-2016, 09:22 AM   #12
LRG WoodCrafting
Leo G's Avatar
Re: Broken Tooth
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 10-19-2016, 05:39 PM   #13
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 240
Re: Broken Tooth
MBR Contractors pull their own teeth...
Splinter is offline
The Following User Says Thank You to Splinter For This Useful Post:
asevereid (10-19-2016)
Old 10-20-2016, 05:01 PM   #14
TimNJ's Avatar
Rewards Points: 5,680
Re: Broken Tooth
40 years ago my wisdom teeth were coming in and the dentist told me to have them pulled.
I figured why go through all the pain. They were coming in straight he said.
Fast forward 30 years and the first one had to go.
Now I have two more that need to go.
I wish I followed that dentists advice 40 years ago.
TimNJ is offline
Old 10-20-2016, 05:27 PM   #15
LRG WoodCrafting
Leo G's Avatar
Re: Broken Tooth
At 54 years old I still have all 4. Had one dentist insist on me getting them removed. Kept asking him why and the only real answer that she could come up with is "you should have them removed". She is no longer my dentist.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 10-20-2016, 05:45 PM   #16
MarkJames's Avatar
Re: Broken Tooth
The reason is that as they continue to grow they push the rest of your arch of teeth out of line. Sort of like a pile-up in slow-mo. (I'm not sure if they would have stopped growing, though.)
Dentists are full of expensive advice.
Old 10-20-2016, 05:48 PM   #17
Mordekyle's Avatar
Re: Broken Tooth
I wonder if dentists have dentisttalk, a forum where they complain about cheapskates, have pictures of wall of shame teeth, and share sage advice?
The Following 2 Users Say Thank You to Mordekyle For This Useful Post:
KAP (10-20-2016), TimNJ (10-20-2016)
Old 10-20-2016, 06:17 PM   #18
LRG WoodCrafting
Leo G's Avatar
Re: Broken Tooth
http://www.dentistry-forums.com/
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 10-20-2016, 07:09 PM   #19
I'm on a boat!
J L's Avatar
Re: Broken Tooth
So do they have a wall of shame over there?
J L is offline
Old 10-20-2016, 09:26 PM   #20
Mordekyle's Avatar
Re: Broken Tooth
I wonder if they ask each other for remodeling advice?
Broken Screw Removal Rick5472 Decks & Fencing 13 05-19-2014 06:22 PM
Broken Closet Flange & Lead Elbow InterCounty Plumbing 9 09-02-2012 11:06 AM
removing a broken post AustinDB Construction 7 08-18-2010 08:54 PM
broken wood screw cab-guy89 Carpentry 28 04-11-2009 12:36 AM
