Wi-Fi Question. - Low Voltage - Contractor Talk
Wi-Fi Question.
Old 10-14-2018, 11:54 PM   #1
VinylHanger's Avatar
Rewards Points: 13,390
Wi-Fi Question.
My Roku express is maybe 30 feet from my router. It goes through two double sheathed wood and sheetrock walls and I have a vintage metal coke sign between it and the Roku.
Is this enough to kill the signal? The bedroom has two doors and a wall to go through and it works fine. It's just my Roku to the TV. I've swapped Rokus around, and two different ones work fine in the open front room, but are very spotty or no go in the Mancave.
VinylHanger is offline
Old 10-15-2018, 07:21 AM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,840
Re: Wi-Fi Question.
There's really no way to predict or calculate these things.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
Old 10-15-2018, 07:49 AM   #3
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,784
Re: Wi-Fi Question.
It’s telling you to get off your @ss and get back to work.
Big Johnson is offline
Old 10-15-2018, 07:50 AM   #4
Fixed's Avatar
Trade: HVAC
Rewards Points: 196
Re: Wi-Fi Question.
That sort of thing depends a lot on the power of the router.
Sent from my Nexus 5X using Tapatalk
Fixed is offline
Old 10-15-2018, 07:50 AM   #5
hdavis's Avatar
Rewards Points: 1,928
Re: Wi-Fi Question.
Signals won't go through metal signs.
hdavis is offline
Old 10-15-2018, 09:11 AM   #6
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Wi-Fi Question.
Not really.
Inner10 is offline
Old 10-15-2018, 09:13 AM   #7
Inner10's Avatar
Re: Wi-Fi Question.
30 feet, two walls and a sign....yeah that could be a problem.
Inner10 is offline
Old 10-15-2018, 09:40 AM   #8
Fixed's Avatar
Trade: HVAC
Rewards Points: 196
Re: Wi-Fi Question.
Originally Posted by Inner10 View Post
Not really.
I just base that statement on my old router not being able to reach out into my garage, and my new one can. Fiber installer told me that was related to the power of the router.
I'm definitely not an expert though.
Fixed is offline
Old 10-15-2018, 11:00 AM   #9
hdavis's Avatar
Re: Wi-Fi Question.
Put the sign on the ceiling. Msybe put up a poster if you don't want a bare wall. No metal frame.
hdavis is offline
Old 10-15-2018, 01:01 PM   #10
Re: Wi-Fi Question.
I would hate to move the sign. I may end up running the router to my room and then let the rest of the house suck it.
Ok, probably not. I'd have a mutiny.
I'll have to do some thinking. How bad do I want to crawl under the house to run cable. Maybe a network expander would help.
Old 10-15-2018, 02:25 PM   #11
hdavis's Avatar
Re: Wi-Fi Question.
Some routers have a higher gain directionsl antenna you can buy. Typically these are dipoles. May work, may not...
hdavis is offline
Old 10-15-2018, 03:09 PM   #12
Inner10's Avatar
Re: Wi-Fi Question.
Here ya go, get the kit with the extenders.
https://www.amplifi.com
Inner10 is offline
Old 10-15-2018, 07:42 PM   #13
Re: Wi-Fi Question.
https://www.bestbuy.com/site/netgear...?skuId=2733324
Old 10-15-2018, 09:47 PM   #14
diplomat
Golden view's Avatar
Rewards Points: 1,550
Re: Wi-Fi Question.
Everyone keeps mentioning the router, but Rokus have pretty weak antennas. The streaming stick + advertises 4X the range, so they know it's an issue.
Golden view is offline
Old 10-15-2018, 09:55 PM   #15
TheConstruct's Avatar
Trade: Renovations & Carpentry
Rewards Points: 1,700
Re: Wi-Fi Question.
A wifi booster is a cheap option to try. Plug it in halfway in between, maybe away from the sign.
TheConstruct is offline
Old 10-16-2018, 02:44 AM   #16
Re: Wi-Fi Question.
The extender looks like the way to go.
We are on satellite internet, so spending 300 bucks would be overkill to extend a signal that is crappy on a good day.
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 58 07-31-2019 02:46 AM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
Concrete repair question german Excavation & Site Work 22 05-17-2012 11:38 AM
