RG 59U For Speaker Runs - Low Voltage - Contractor Talk
Old 03-07-2008, 12:42 AM   #1
Rusty shorts's Avatar
We are starting to run silver core RG59U for our speakers, and it is working very well, just wondering how this has been working for other. Or it could be we are just slower with the new stuff in UT
Rusty shorts is offline
Old 03-07-2008, 04:52 PM   #2
GregS's Avatar
Trade: Low Voltage
Rewards Points: 502
Re: RG 59U For Speaker Runs
RG59 as in coaxial? Typically RG59 has a 20 gauge core. Why would you run 20g wire for speakers? How do you terminate this?
GregS is offline
Old 03-07-2008, 05:29 PM   #3
mdshunk's Avatar
Rewards Points: 2,002
I've used RG-6 with Snap-n-Seal's RCA ends for subs, but not for the regular speakers. Sounds silly.
mdshunk is offline
Old 03-07-2008, 05:35 PM   #4
mickeyco's Avatar
Trade: Squirrel Handler
Rewards Points: 2,000
I've seen coax "bundled" in a "jacket" with speaker/power wire but it would seem odd to use caox itself for speaker wire, would there be some problems with that? Wouldn't there be an impedance matching problem if the cable wasn't specifically for speakers (I don't know)?
mickeyco is offline
Old 03-07-2008, 10:36 PM   #5
GregS's Avatar
Trade: Low Voltage
Rewards Points: 502
Exactly. I use RG6 for subs too, but no way no how would you use it for a speaker.
GregS is offline
Old 03-07-2008, 11:18 PM   #6
Young Gun
HallisseyDesign's Avatar
Trade: Smartass
Rewards Points: 250
When i do my home theatres it is in 12 gauge stranded or 10 gauge stranded.
HallisseyDesign is offline
Old 03-08-2008, 09:06 AM   #7
sirroundsound's Avatar
Trade: Audio video and automation
He has to be kidding...
sirroundsound is offline
Old 03-08-2008, 10:19 AM   #8
Handle It!
MALCO.New.York's Avatar
When speaking of Speakers and Nominal Impedance and Impedance Curves, Gauge versus length is the ONLY real factor. RG6U is good for up to 32 Feet with 8 Ohm load speakers and 16 feet for 4 Ohm speakers. It does not make a difference in the wire construction of copper. Solid, stranded, braided, oxygen free, etc. What matters is that it is copper and the correct gauge for length.
Over-gauged wire is a waste of money unless one considers the possibility of a future change in speaker configuration as in todays 8 Ohm installation and tomorrows upgrade to 4 Ohm speakers!
If you can purchase Coaxial RG6 or RG11 cheaper than 2 conductor stranded, then by all means use it!
http://www.roger-russell.com/wire/wire.htm#introduction
I play with music and audio equipment every once in a while!
http://i212.photobucket.com/albums/c...k/CIMG1878.jpg
http://i212.photobucket.com/albums/c...k/CIMG1874.jpg
The only not-so-upside is the aluminum resistance compared to the copper resistance. Should not be a factor if wired properly. Unless you have coax with copper shielding then it is NOT a factor at all.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 03-08-2008, 10:46 AM   #9
GregS's Avatar
Trade: Low Voltage
Rewards Points: 502
Um, what sized room is this? That's a little extreme for most cases unless you are doing a bunch of 1000W speakers with a power amp the size of a VW Bus.
Well okay, in that case I would use even thicker than that.. but still, 10g for speaker wire is a lot of wasted copper.
GregS is offline
Old 03-09-2008, 02:09 PM   #10
I guess for very small runs, if someone was so inclined, they could muck about with RG6 for a speaker wire. But why would you...
Basic 2 cond zip cord is cheap, and really easy to strip and connect to the speakers.
The OP doesn't state if they were just running short amounts from a stereo to speakers, or trying to pre wire a whole house music system this way.
There is one company I have used that offers speaker wire over RG6. I believe it's called MIT one wire, BUT, they have expensive connector / adapters that they require you to use, not making it an inexpensive solution.
Old 03-09-2008, 03:31 PM   #11
GregS's Avatar
Trade: Low Voltage
Rewards Points: 502
Hey, another AV guy from Burlington.. Welcome Pat!
GregS is offline
Old 03-09-2008, 06:21 PM   #12
Young Gun
Trade: Smartass
Rewards Points: 250
The speakers were 1000w's. I did 4 rooms in a basement with 10ga stranded. It sounds amazing and was not to hard to wire. It really was not that pricey might have been 20 bucks more then 14ga stranded. We have a good electrical supply house that we have been getting our wire and parts from for some time.
Old 03-10-2008, 08:58 PM   #13
Sorry to change the topic, but Homes, where did you get my name from??
I looked at your profile, no name, looked at my profile, no name. Just curious.
Old 03-10-2008, 10:01 PM   #14
GregS's Avatar
Trade: Low Voltage
Rewards Points: 502
Google knows all.
GregS is offline
Old 03-11-2008, 07:36 AM   #15
Of course.... silly me.
Old 04-09-2008, 05:56 PM   #16
Low Voltage Contractor
ChillaWatt's Avatar
Trade: C-7
Rewards Points: 75
Usually the manufacturer of component knows the best way to connect their component. Subs and A/V rcvrs have coaxial outs/ins and don't require you to convert with an adapter. Speakers have binding posts or those spring-loaded thingies, as do the A/V rcvrs. Stick with that. Only time I use RG-59 is with security cameras.
Chilla
ChillaWatt is offline
Old 07-09-2008, 03:14 PM   #17
avintel's Avatar
Seriously, from experience:
We have used RG6 & RG59 for hi level audio - not by choice, it was a fix for another company that pre-wired a home and indicated that they ran speaker wire to locations that they did not and when the home was finished they were left with this issue.
Do not do, people told us that it cant be done, but we figured it out and it works fine. not great. there is definitely a noticeable difference in audio quality. we hot dropped 16 awg to see and it is amazing how noticeable the diff is.
however, with that said, if it is necessary, it can be done.
avintel is offline
Old 07-09-2008, 03:14 PM   #18
avintel's Avatar
i do have a feeling though, the poster must be talking about low-level for rca connections to active speakers.
avintel is offline
Old 07-19-2008, 07:31 PM   #19
He does mention Speakers (plural), to many that would not say subwoofers or other active style speakers.
Mind you the OP hasn't responded either, thus the post is hard to take seriously.
Using RG59 or RG6 for an active speaker will work, but you still can experience problems.
Old 08-11-2008, 04:50 PM   #20
AV Darren's Avatar
If you use it for speaker level, its going to turn into a hi-pass filter and shave off your low end
AV Darren is offline
Furnace and AC runs Michaeljp86 HVAC 17 10-27-2007 09:43 PM
Who runs the Thermostat wire? DupuisConst Electrical 51 08-19-2007 10:36 AM
runs!!!! Traditions Painting & Finish Work 24 02-27-2007 10:20 AM
Laying Long runs and string sag lukachuki Masonry 26 01-21-2007 12:07 PM
Runs in Urethane HandyAl Painting & Finish Work 4 06-22-2006 02:33 PM
