New Building With Commercial Smoke Alarm System - Low Voltage - Contractor Talk
Old 05-08-2019, 09:44 PM   #1
HubbaBubba's Avatar
Trade: General
Rewards Points: 30
I am building a new building that they labeled "Multi-Use" because it has a living space upstairs. Downstairs is mostly garage space that has a small office area in the front. With the "Multi-Use" they let me take out a homeowners permit for the electrical.
The building will have a full fire sprinkler system. What size and type of wire is required for an alarm system that will have six smoke detectors ? I have talked with different fire monitoring companies and got different answers, some say two some say four. I just want to have enough wire for any possible use in the future. Thanks
HubbaBubba is offline
Old 05-08-2019, 09:56 PM   #2
HubbaBubba's Avatar
Trade: General
Rewards Points: 30
Re: New Building With Commercial Smoke Alarm System
Fire Alarm Cable 14, 16 or 18 gauge ?
Old 05-08-2019, 10:23 PM   #3
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,972
Two or four what? Conductors? Wire Gauge?
Is this part of an alarm system, or just the six inter-connected smoke detectors?
Are you doing combo smoke/CO detectors?
Old 05-08-2019, 10:34 PM   #4
HubbaBubba's Avatar
Trade: General
Rewards Points: 30
Yes, it will be part of an alarm system. and Yes 2 or 4 conductors and wire gauge ?
Old 05-09-2019, 07:00 AM   #5
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,978
The detection side is usually 16, the notification side is usually 12.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
Old 09-20-2019, 05:58 PM   #6
Parnelli Jones's Avatar
Trade: Commercial
Rewards Points: 88
Does any know where to buy less expensive Intelligent or Addressable fire alarm systems , I will have 6 smoke alarms, 8 alarms and 3 pull stations ?
Parnelli Jones is offline
Old 09-20-2019, 06:32 PM   #7
ABLE1's Avatar
Rewards Points: 1,296
For starters, maybe you need to define the words "less expensive" with a few "$" signs!!
I guess if you could, the system would be missing the following.
Support, Simple Design, Quality Construction, Reliability, Install Manual in English to name a few perks.
Then again you might want to check on eBay for a auction posting.
You never know, you could get lucky!!
Sorry, i couldn't resist.
Have a good weekend.
Les
ABLE1
ABLE1 is offline
Old 09-20-2019, 06:41 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 2,722
Fire alarm systems are designed/engineered to calc voltage drop to a device which in turn will have an effect on wire size.
The design also will call out what type of devices will be where.
Last three systems i put in only have one pull station for drills.
griz is online now
Old 09-20-2019, 06:57 PM   #9
rrk's Avatar
Rewards Points: 5,740
None at the exit doors?
Worst thing you can do is use the same pull station for every fire drill. I used to work for a large institutional fire alarm company, at one large high school they did that for several years. When our company got the service contract for that school I had to test the system, the only thing that worked in the entire 40 something zone system was that one pull station. They had no idea nothing else worked.
They had to have a fire watch manned by firemen until we could get the system operational. Systems get inspected 1 or 2 times a year, fire drills are 2 times a month.
rrk is online now
Old 09-20-2019, 07:01 PM   #10
Fire up the BBQ
griz's Avatar
new california code, well for schools anyways...
system is also audible, voice gives instructions to exit the building.
no more blaring sound.
devices can also be tested with canned smoke.
griz is online now
Old 09-20-2019, 07:21 PM   #11
Trade: Commercial
Rewards Points: 88
Les
I have a small system and was just looking for something designed for a small application, I was looking for brand names and model numbers if any one has used small units. Some of these Intelligent Systems are designed for larger buildings with way more features then I need.
Old 09-20-2019, 07:44 PM   #12
Fire up the BBQ
griz's Avatar
yes, but do you know what features you need?
Current codes?
who designed/engineered the system?
griz is online now
Old 09-20-2019, 08:07 PM   #13
ABLE1's Avatar
My personal favorite is Silent Knight.
https://www.silentknight.com/Pages/C...S-SILENTKNIGHT
I choose the system and am not to concerned about the price
since I know what I am getting is worth every penny.
Les
ABLE1
ABLE1 is offline
Old 09-20-2019, 08:11 PM   #14
Trade: Commercial
Rewards Points: 88
Current codes?
I had the fire department over and they told me what they wanted, I want to tell my installer what package I want to buy ?
I don't know if you are helping ?
Old 09-20-2019, 08:12 PM   #15
Trade: Commercial
Rewards Points: 88
Les
Thanks, thats a start-
Old 09-20-2019, 08:18 PM   #16
ABLE1's Avatar
Yes he did!!
Don't you have building codes??
Need to follow NFPA 72!!
IBC
ADA
etc.
Need to have full plan submittals!!
Les
ABLE1
ABLE1 is offline
Old 09-20-2019, 08:52 PM   #17
Trade: Commercial
Rewards Points: 88
Yes he did!!
IBC
ADA
etc.
Les
I have plans, the contractor will deal with code issues. I was worried more about price from different manufacturers
Old 09-20-2019, 08:58 PM   #18
ABLE1's Avatar
When you are dealing with Fire Alarms and
Life Safety 101 taking a low bid is not necessarily
the best logical thinking that should be forefront
on your brain!!
Les
ABLE1
ABLE1 is offline
Old 09-20-2019, 09:02 PM   #19
Fire up the BBQ
griz's Avatar
but WHO designed & engineered the "package"?????
griz is online now
Old 09-20-2019, 09:15 PM   #20
Trade: Commercial
Rewards Points: 88
it hasn't been done yet, it doesn't matter that much, all of these systems can handle what I need, and handle the wiring in place
Toilet requirements - commercial building - Gym MPMC Plumbing 10 03-09-2015 05:21 PM
Flat roof - What roofing system should I use? acro Roofing 10 04-15-2013 04:47 PM
I have a burning question JonM Tools & Equipment 25 02-26-2013 09:08 PM
Elgen GSF septic system rino1494 Excavation & Site Work Picture Post 9 01-05-2013 05:11 PM
