MC 4 Solar Connector Removal. - Page 2 - Low Voltage - Contractor Talk
Old 02-03-2018, 08:18 AM   #21
rrk's Avatar
Rewards Points: 4,002
Re: MC 4 Solar Connector Removal.
All your loose screws will be stuck to the top of the box now with all of those magnets
rrk is online now
Old 02-03-2018, 08:42 AM   #22
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,693
In order to move the panels I need to use a wonderbar to break the magnet from the box and then put a 3/16" strip of wood between the magnet and the box, times 10.
Then they still have enough magnetic attraction to resist movement.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 02-03-2018, 09:28 AM   #23
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,280
Fancy! Very cool setup Leo.
overanalyze is online now
Old 02-03-2018, 10:09 AM   #24
LRG WoodCrafting
Leo G's Avatar
I charged the battery last night on AC and got it to float level this morning.
Now all it's doing is maintaining float.
I have the temp compensation set at -4mv/ºC/cell and it's cold outside today, so the charging voltages are higher than you'd expect.
Here's the top view of the truck. I think my window needs a cleaning.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 02-18-2018, 12:32 PM   #25
Rmcooke86's Avatar
Trade: Electrician / control tech
I did read through your entire post however I missed the beginning question you asked about drilling the panels, what was your final decision?
I would never drill through panels for many reasons. First being you'll pitentially void your panel warranty. You could create a rough / sharp chaff point for the wire, unless you installed a bushing. Not to mention your creating a lot of work for yourself, take a look at my attached picture these clips will never fall off and there listed for the intended use.
Rmcooke86 is offline
Old 02-18-2018, 01:51 PM   #26
LRG WoodCrafting
Leo G's Avatar
I wouldn't drill through the panel, but the aluminum frame I certainly would. Not going to void the warranty, but I won't be able to return it because it's no longer resalable.
I used something similar to this to secure the wires to the underside of the panel.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 02-12-2019, 05:38 PM   #27
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 718
So a year later, how's that setup been working out for you? Do you have any stats on % of discharge vs time to float?
SWMBO made me buy a little camper trailer and I'm toying with the idea of setting up a panel or two for boondocking with it. That way she can be comfy in base camp while I go backpacking.
Tinstaafl is online now
Old 02-12-2019, 08:04 PM   #28
LRG WoodCrafting
Leo G's Avatar
No, not really. System works good though. Since I don't use it every day when I need it it has a full charge. Plus I only have 120 watts worth of panels which has never produced more than 93 watts. The one time when I really used the system it was recovered by mid morning the next day.
If you have the space get 2-300 watts worth of panels and 2 batteries for the system.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 02-12-2019, 08:21 PM   #29
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 718
Pretty much I expected to hear. If you were really using that setup regularly, it most likely wouldn't be enough.
I'll start small and see how it goes. A regular car battery lasts me 4 days at hunting camp before it needs a boost, so I think a good deep discharge jobby with a single portable (so I can point it sunwards) 100W panel stands a fair chance. Easy enough to double up either or both if I need to. She'll use more power than I would.
Old 02-12-2019, 08:29 PM   #30
LRG WoodCrafting
Leo G's Avatar
If a regular car battery lasts 4 days you won't have any problems. I use saws, irons, heat guns and all of my 120v tools on mine. Generally I can get an 8 hour day out of it. If I have good sun while I'm working it'll extend that even farther.
I actually though she was using electricity. 4 days off a car battery isn't using squat. Even my system could easily handle that.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 02-12-2019, 08:57 PM   #31
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 718
Well, I pretty much only run 2-3 LED lights at camp, and a 12V vacuum. She'll probably want 15-20 other amenities.
Hydronic Solar Thermal TLP HVAC 5 10-15-2014 07:57 AM
DIY solar powered heaters AmeliaP Off Topic (Non Trade) 3 10-01-2012 01:01 PM
Solar Hot Water System Morning Wood Plumbing 3 09-16-2011 02:43 PM
New CertainTeed Roofing Shingles Offer Industry-Leading Solar Reflectivity, Authentic Grumpy Roofing 0 04-27-2011 10:08 PM
Solar Power Industry Dead In California w6ire Electrical 2 06-28-2007 08:57 AM
