LED Under Cabinet Lighting - Low Voltage - Contractor Talk
Old 07-03-2020, 07:23 PM   #1
SignatureW's Avatar
Rewards Points: 24
Hi,
I am a kitchen subcontractor. On the kitchen that I am finishing up, I installed a LED tape light from Commercial Electric. When I used this product before, all of the cabinets were at the same height and I was able to run continuous lighting by drilling a hole along the bottom of the cabinets
However on this kitchen none of the cabinets except 2 are at the same height. So I thought that I could connect each cabinet light to the rest of them using wire. That is connected together on the top of the cabinets and then run to each light.
I am finding that the first 2 cabinets will light but the last 2 won't. I checked voltage and polarity and they both seem right. I suspect there is too much resistance but don't know enough not have a meter to test that.
Does anyone think that's what it could be? Could I get a more powerful power supply to solve the problem?
See the attached photos. Thanks
Kevin Johnson
Sent from my SM-G965U using Tapatalk
SignatureW is offline
Old 07-03-2020, 07:49 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 15,035
Re: LED Under Cabinet Lighting
Something isn't connected properly. Are the LEDs cut at the proper length? There are specific areas you can cut them, if you don't do they they won't work or might even blow a few out from over voltage across them. Usually 12v LEDs are cut every third LED and 24v are cut every 6th.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 07-03-2020, 07:55 PM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,978
Without knowing the wattage of the strips, we can't say if the power supply is large enough.
When it comes to polarity, you can't just say "left is -, right is +"..... it depends on which end you're looking at.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is offline
The Following User Says Thank You to 480sparky For This Useful Post:
overanalyze (07-03-2020)
Old 07-03-2020, 08:16 PM   #4
LRG WoodCrafting
Leo G's Avatar
Half the strips wouldn't light if the power supply was under powered. It would overload and shut down. It might make the lights flash as it came on, realized the overload and shut down. Rinse and repeat.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 07-03-2020, 09:16 PM   #5
480sparky's Avatar
Originally Posted by Leo G View Post
....... Are the LEDs cut at the proper length? There are specific areas you can cut them, if you don't do they they won't work or might even blow a few out from over voltage across them. Usually 12v LEDs are cut every third LED and 24v are cut every 6th.
Old 07-03-2020, 10:41 PM   #6
LRG WoodCrafting
Leo G's Avatar
I know that, you know that, doesn't mean he did.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Aaron Berk2 (07-04-2020)
Old 07-04-2020, 12:36 AM   #7
480sparky's Avatar
I used the OPs photo to emphasis what you said. That's all. Carry on.
Old 07-13-2020, 04:28 PM   #8
SignatureW's Avatar
Rewards Points: 24
Ok, I am jumping back in here to thank everyone and tell you what the problem was. It was one the connector.
I think if I use this lighting with the tape again I need to find a supply of connectors (not just the ones in the box) or a more robust tape lighting kit.
Old 07-13-2020, 04:30 PM   #9
480sparky's Avatar
I quit using field connectors years ago. I now solder the wiring directly onto the tape. It's a pain, but eliminates this problem altogether.
overanalyze (07-14-2020)
Old 07-13-2020, 05:07 PM   #10
LRG WoodCrafting
Leo G's Avatar
Ditto. I find any of those connects mediocre at best. Soldering them makes it nearly impossible for the connection to go bad. Don't overheat them. Small 50 watt iron with rosin core solder.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 07-13-2020, 05:34 PM   #11
rrk's Avatar
Rewards Points: 5,740
Outwater Plastics has a wide variety of LED lights and supplies
https://www.outwater.com/lighting/
rrk is online now
Old 07-13-2020, 06:35 PM   #12
tjbnwi's Avatar
Rewards Points: 5,310
Get Helping Hands, make soldering the leads to the tape so much easier.
https://www.harborfreight.com/helpin...xoCHQ8QAvD_BwE
tjbnwi is offline
Old 07-13-2020, 06:38 PM   #13
480sparky's Avatar
I use this outfit:
https://www.superbrightleds.com/
Orders are usually in my hands in 2-3 days.
Old 07-13-2020, 06:40 PM   #14
tjbnwi's Avatar
I use GML.
http://www.gmlighting.net
tjbnwi is offline
