Hotspot Security Camera - Low Voltage - Contractor Talk
Old 06-15-2020, 06:43 PM   #1
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,386
Does anyone know if these exist? I've been doing some searching but without much luck. I've called both Ring and ADT and they each said their cameras require Wifi, Hotspot will not work.
KennMacMoragh is offline
Old 06-16-2020, 07:41 PM   #2
Stunt Carpenter's Avatar
Rewards Points: 2,892
Re: Hotspot Security Camera
I would really like something like this. It would be really nice to put up on jobs. Nice way to keep track of subs coming and going also.
https://builddaley.com/
Stunt Carpenter is online now
Old 06-16-2020, 07:46 PM   #3
MarkJames's Avatar
Rewards Points: 19,393
some random stuff:
https://reolink.com/solutions-for-wi...ternet-access/
MarkJames is offline
Old 06-19-2020, 07:31 PM   #4
Originally Posted by MarkJames View Post
Reolink uses a SIM card so it's like paying for another cell phone.
Oh well I tried, must be a reason hotspot won't work on cameras.
Old 06-19-2020, 08:08 PM   #5
tgeb's Avatar
Rewards Points: 1,044
I have a couple of cameras that work with Sprint's hotspot that I also have.
I can set up the camera and hotspot at a remote location and as long as the hotspot is within the service area and gets good signal, it works quite well.
I have amcrest wi-fi cameras.
www.gebcon.com
tgeb is online now
Old 06-19-2020, 08:43 PM   #6
Which camera are you talking about? I'm talking no Wi-Fi, no SIM card required, just hotspot.
Old 06-20-2020, 07:23 AM   #7
tgeb's Avatar
https://amcrest.com/amcrest-ultrahd-...-pt-black.html
It's a wi-fi camera and my hotspot is the wi-fi that it connects to. The sprint hotspot connects to the data of the phone network and broadcasts a wi-fi signal that connects the camera.
Maybe we have differing thoughts on what a hotspot is.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
hdavis (06-20-2020)
Old 06-20-2020, 08:09 AM   #8
hdavis's Avatar
Rewards Points: 1,928
Hotspot
https://en.m.wikipedia.org/wiki/Hotspot_(Wi-Fi)
hdavis is online now
Old 06-20-2020, 08:31 AM   #9
hdavis's Avatar
I put together a really cheap system just to see how I would use one, what it's features and limitations were, etc.
Yi Home cameras
Some mobile hotspot from Wal-Mart
Dedicated Straight Talk cell phone.(I don't put apps on my main cell phone until I've checked them out)
The supplied app only sends alerts through Yi's server in China. That seems to be the usual case. At some point I'll check to see if there is an alternate generic app that avoids routing over the internet.
Old 06-21-2020, 01:48 PM   #10
Iím not sure how you have your devices set up but I called that company they said it wonít work through a hotspot. Your camera must still be getting a Wi-Fi it hooks up to.
But the difference is hotspot uses a different frequency than Wi-Fi. You can tell which one youíre getting if you connect your cell phone to it. If itís hotspot youíll see two overlapped rings, Wi-Fi and youíll see the three waves.
Old 06-21-2020, 05:48 PM   #11
tgeb's Avatar
I don't know Kenn, mine is a wifi Hotspot.
I set it up with a unique name and password, then made it hidden so others would not know there is a wifi access point.
I'm not generally tech savvy, but I do know the camera can do 2.4 and 5ghz not sure about the Hotspot but it works well as long as there is good coverage from Sprint.
I do pay a fee for the Hotspot service. If that's what you are trying to avoid... not sure I know a solution.
Sent from my SM-G970U using Tapatalk
www.gebcon.com
tgeb is online now
Old 06-21-2020, 09:05 PM   #12
hdavis's Avatar
Every single Wi-Fi enabled camera I've seen works with a hit spot. You may have lower data rates depending on where it is, so the live video feed may go in and out. It all depends on the cell service the hit spot is using.
Old 07-01-2020, 01:04 PM   #13
Which one specifically? I tried it with a Ring camera and it simply won't connect to the network via hotspot. Their tech support verified this over the phone as well, it needs a Wi-Fi signal not a hotspot.
Old 07-01-2020, 02:07 PM   #14
hdavis's Avatar
Look at my earlier post.
Go buy a mobile Wi-Fi hotspot if you want to move your system to different locations.
You can have data rate and latency issues using a cell based Wi-Fi hotspot. Depends on how far from a tower and what the signal strength is.
Old 07-01-2020, 03:41 PM   #15
hdavis's Avatar
Ken, exactly what hardware were you using for your hotspot?
tgeb (07-01-2020)
Old Yesterday, 06:16 PM   #16
The hotspot comes from an iPhone.
I've used the Wi-Fi hotspots before but that requires a SIM card. Plus the Wi-Fi hotspots offered by At&t are very limited, they only work with the broken down low speed calling plan. Better off to use a camera with a SIM card in it, but that's what I'm trying to avoid because it's like paying for another phone.
Old Today, 12:05 AM   #17
hdavis's Avatar
If you have a WIFI router that covers 802.11 g, n, ac you MAY be able to teather your cell phone to it and connect the ring devices through the Wi-Fi router to the internet through your cell phone. Don't know, haven't tried it.
No, an iPhone isn't going to work for these. Ring uses 2.4 GHz for WIFI and cell phones use 5 GHz.
Old Today, 07:14 AM   #18
tgeb's Avatar
The camera I referenced earlier is dual band.
Currently only 65 bucks.
www.gebcon.com
tgeb is online now
hdavis (Today)
Old Today, 03:04 PM   #19
hdavis's Avatar
The hitch I've seen on the Yi, and it looks the same on yours, is all the notifications, stills, and clips go though their server, so you have to have internet for those features.
I've poked around a little looking for a generic piece of software to get around it, but nothing yet.
tgeb (Today)
Old Today, 08:23 PM   #20
tgeb's Avatar
I don't know anything about the yi camera.
I have the option to have storage through amcrest, but do not.
As far as I am aware the feed from my cam does not go through any servers other than what is needed to get to me, and is secure via password.
Not that I could not be mistaken, just my current understanding.
In fact, I can disable the wifi altogether and record to a micro SD card.
Sent from my back porch.... dang it's hot out.
www.gebcon.com
tgeb is online now
