Fire Block Foam Or Caulk - Low Voltage - Contractor Talk
Old 03-16-2019, 12:13 PM   #1
ABLE1's Avatar
Rewards Points: 1,274
Hello all,
I have a pending Fire Alarm install in a commercial building.
I will need to use a Fire Block around wall penetrations.
Anyone have a recommendation for what is to be used or not used
in this kind of application??
Thanks for any input.
Les
ABLE1
ABLE1 is offline
Old 03-16-2019, 01:01 PM   #2
finisher65's Avatar
Trade: Drywall/carpentry
Rewards Points: 92
Re: Fire Block Foam Or Caulk
We use Hilti products, caulking & bricks. We also have guys trained by Hilti
finisher65 is offline
Old 03-16-2019, 01:35 PM   #3
ABLE1's Avatar
Correct me if I am wrong, but, the Hilti requires a special adapter
device to fit the can??
ABLE1
ABLE1 is offline
Old 03-16-2019, 02:47 PM   #4
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 176
Check the drawings & specs - many times what you have to use is called out
generally caulk or the putty material is what I have seen
SLSTech is offline
Old 03-16-2019, 03:06 PM   #5
ABLE1's Avatar
I AM the Drawing & Specs
Looking to see what the favorite product is for this kind of application.
3M
Great Stuff
Red Devil
Hilti
etc.
ABLE1
ABLE1 is offline
The Following User Says Thank You to ABLE1 For This Useful Post:
SLSTech (03-16-2019)
Old 03-16-2019, 04:08 PM   #6
finisher65's Avatar
Rewards Points: 92
Hilti does have "caulk guns" that are specific to their product which is in a foil wrap, affectionately called "sausage tubes". You'll know why if you see them.
Old 03-16-2019, 06:20 PM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Originally Posted by ABLE1 View Post
Hello all,
Les
Depends on the application, you have to find an approved product for the situation. If it's a plastic pipe then FSONE if it's less than 25 wires use CP606 because it's way cheaper.
Wrong, you are now corrected.
Sausages are used by many manufacturers.
Inner10 is offline
Old 03-16-2019, 06:31 PM   #8
finisher65's Avatar
Rewards Points: 92
I interpret his question as "can you use a regular caulking gun", my interpretation could be wrong.
Old 03-16-2019, 07:04 PM   #9
Inner10's Avatar
You can because it's sold in tubes and sausages.
Inner10 is offline
Old 03-16-2019, 07:11 PM   #10
finisher65's Avatar
Rewards Points: 92
[dupe
Old 03-16-2019, 07:12 PM   #11
finisher65's Avatar
Rewards Points: 92
I'm so used to the sausages I forgot . Having checked their site the FS one comes in tubes & sausages.
Unrelated. The Great Stuff Firestopping isn't rated for commercial use.
Old 03-17-2019, 10:44 AM   #12
ABLE1's Avatar
Not unrelated -- Great Stuff is off my radar.
As for the Hilti I 'assume' that the sausages
require a specific tool that needs to be used for application.
However it appears that the tubes just need a
Plain Jane caulking gun. Is that correct??
The next question is product sourcing.
I will have to check with my local distributors to see who
handles the Hilti CP 606 in tubes.
The other thing that I can't seem to find is the ratio of 1 tube that
holds 1.25 cups of material to what expansion quantity??
Trying to get a grasp on how much coverage will one tube handle.
I know that is going to depend on a multitude of variables.
But, as to expansion ratio is it 1:1, 1:2 or something else??
Or does just come down to keep buying until all gaps are filled??
I hope it is not that crude. Really there should be some kind of
gauge of some kind. I looked over as many Data Pages that
I can, but that does not seem to listed anywhere.
Something like 1 tube will deliver a 1/4" bead 10' long would be
helpful. Any thoughts??
Sorry for any stupid questions, but then I heard that there
are never any stupid questions
Thanks in advance and have a good rest of the weekend.
Les
ABLE1
ABLE1 is offline
Old 03-17-2019, 10:49 AM   #13
Anti-wingnut's Avatar
Rewards Points: 3,430
This will help, but it is a little harder to use that a couple of decades ago
https://www.hilti.com/firestops
Anti-wingnut is offline
Old 03-17-2019, 02:56 PM   #14
Inner10's Avatar
Les
It doesn't expand, it's just caulking, some is acrylic, some is silicone, some is intumescent and expands when it gets hot.
Sausages need a sausage gun, go buy one they are 75 bucks but it's cheaper in the end than caulking tubes.
Buy a case of sausages and see how far ya get.
Inner10 is offline
Old 03-17-2019, 10:01 PM   #15
ABLE1's Avatar
Inner,
I don't have that much to do. A case of sausages would be overkill.
Thanks for the extra input.
Les
ABLE1
ABLE1 is offline
Old 03-17-2019, 11:24 PM   #16
Fire up the BBQ
griz's Avatar
Rewards Points: 1,974
you have a code or an inspector to work with?
fire caulk/putty is generally very specifically called out.
griz is online now
SmallTownGuy (03-18-2019)
Old 03-17-2019, 11:31 PM   #17
Yup. That's why I gave the OP the Hilti technical application page. This isn't something you spray Great Stuff into and call it good. This is commercial work with specific UL rated assemblies.
The Following User Says Thank You to Anti-wingnut For This Useful Post:
griz (03-18-2019)
Failing Caulk in Acrylic and Gell Coat tubs and showers. Bridget Piper General Discussion 5 10-04-2016 06:43 PM
Compressed Earth Block Construction Jaws Construction 12 02-07-2013 03:33 PM
foam insulation question phnola Construction 3 05-01-2011 09:56 AM
the great debate, foam rain screen woodworkbykirk Windows, Siding and Doors 8 09-13-2010 07:54 PM
Block building leaking inside? GSS Masonry 9 05-24-2010 09:20 AM
