Can Anyone Explain This In Simple Terms?? - Low Voltage - Contractor Talk
Old 03-05-2019, 03:53 PM   #1
ABLE1's Avatar
Rewards Points: 1,274
Hello all,
Please excuse my stupid naivete, but I am having a hard time
with this item. This is in no way a sales pitch.
https://www.cmple.com/recessed-pro-p...de-inlet-white
Can someone, in different words that are not listed
in the "Overview" explain how this would function and for what
practical reason??
I tried to visualize and I can't wrap my brain around it.
I will sit back now and let the juices and comments flow as they may!!
Thanks,
Les
ABLE1
ABLE1 is offline
Old 03-05-2019, 03:55 PM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Can Anyone Explain This In Simple Terms??
Originally Posted by ABLE1 View Post
Hello all,
practical reason??
Thanks,
Les
So a non-electrician can bring power up behind a TV.
Inner10 is offline
rrk (03-05-2019)
Old 03-05-2019, 04:26 PM   #3
ABLE1's Avatar
So how does an extension cord on the floor make it better??
And now a non-electrician that doesn't know how to run wire
is now smart enough to know how run wire inside the wall??
ABLE1
ABLE1 is offline
The Following User Says Thank You to ABLE1 For This Useful Post:
MarkJames (03-05-2019)
Old 03-05-2019, 04:42 PM   #4
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 12,652
Two words: Madison and Avenue.
If you build it, some schmuck will be stupid enough to buy it.
So how does an extension cord on the floor make it better??....
Technically, you'd be energizing 'permanent' wiring with an extension cord, which is a no-no. I don't see how it got an ETL listing.
So a big red FAIL in my book.
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 03-05-2019, 04:43 PM   #5
MarkJames's Avatar
Rewards Points: 18,929
That's ridiculous and thanks for the brain teaser.
I tried to figure it out, and failed three different ways.
MarkJames is online now
Old 03-05-2019, 04:45 PM   #6
MarkJames's Avatar
Hilarious, the closer you look.
https://datacommelectronics.com/wp-c...-WH-072817.pdf
Old 03-05-2019, 05:59 PM   #7
Inner10's Avatar
It has a short power cord that goes from your outlet below the TV to the box that relays power to the device behind the TV. It's a way of getting power to a TV legally without the need for an electrician or an electrical permit...and without having an unsightly cord running up to the TV.
What's not to understand?
Inner10 is offline
Old 03-05-2019, 06:00 PM   #8
Inner10's Avatar
It's listed...
Inner10 is offline
Old 03-05-2019, 07:12 PM   #9
MarkJames's Avatar
Did you look at the illustration in my link? That makes sense to you?
Old 03-05-2019, 07:46 PM   #10
Inner10's Avatar
I've installed the product it makes perfect sense to me.
Inner10 is offline
Old 03-05-2019, 08:32 PM   #11
Fire up the BBQ
griz's Avatar
Rewards Points: 1,900
just like this one....
griz is online now
Old 03-05-2019, 08:58 PM   #12
MarkJames's Avatar
So the main benefit is limiting hidden (in-wall) wiring to the same stud cavity, but running a short extension cord horizontally to reach the cavity?
And what wire is happy homeowner supposed to use to connect lower to upper receptacle in the wall? Is 12-2 apparent for this DIY product?
Old 03-05-2019, 10:26 PM   #13
480sparky's Avatar
It's listed...
Never said it wasn't.
But to me, it's a violation of 400.12(1).
Old 03-05-2019, 10:29 PM   #14
test
cedarboarder's Avatar
Trade: General
Rewards Points: 813
Now that's what I call thinking out side of the box!!
It's so stupid that it probably sells well.
cedarboarder is offline
Old 03-05-2019, 10:31 PM   #15
Inner10's Avatar
It's a retrofit products. Joe blow wants to wall mount his TV but doesn't have power outlet on the wall. This brings power and a chase for low voltage wiring to the TV without the need for an electrician.
This one you have to supply your own wire, but they make a preterminated kit that includes wire.
Inner10 is offline
rrk (03-06-2019)
Old 03-06-2019, 07:13 AM   #16
MarkJames's Avatar
Here's their vid.
They overlook so many basic things (studs?) for selecting the mounting location, and hardly a mention of fishing cable to run power to the upper box.
cedarboarder (03-06-2019)
Old 03-06-2019, 07:52 AM   #17
ABLE1's Avatar
Here's their vid.
https://www.youtube.com/watch?v=pEGI9vFhYdo
Not only that she had someone on the other side of the wall
"HAND FEED" the Data Wire through the hole.
Sorry Inner10, but this still hurts my brain.
Have a good day.
Les
ABLE1
ABLE1 is offline
Old 03-06-2019, 09:33 AM   #18
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 2,566
Have a good day.
Les
Yes, the video and docs do ignore "real life" conditions such as the studs and insulation. Also, are they letting the DIY'er determine what kind of wiring they will use to connect the outlets??? It look like they used 14/2 romex, but what is to stop the DIY'er from using speaker cord, a cut off flexible extension cord, etc. ?
I went over 401.1 which addresses flexible cord (extension type) in enclosed spaces, plenum and non-plenum areas, etc. However, I don't see an issue with this type of install if the installer uses approved wiring for the connection between the in-wall receptacles.
cwatbay is offline
Old 03-06-2019, 09:35 AM   #19
480sparky's Avatar
Here's their vid.
Well, of course they don't mention the 'bad' stuff. Gotta make it look easy-peasy like they do on This Old House, etc. to peddle it.
Not once in their instructions do they mention Code compliance. Heck, they even emphasize "This product is not part of your homes' electrical system."
Fook, I think I'll start using that line during inspections. "No, Mr. Inspector, I don't need to do that.... this wiring isn't part of the homes' electrical system..." Yeah..... that'll fly.
The Following User Says Thank You to 480sparky For This Useful Post:
MarkJames (03-06-2019)
Old 03-06-2019, 09:37 AM   #20
480sparky's Avatar
How about 310.10(B)?
Amazon Terms & Conditions, am I reading this right? MOTB Marketing & Sales 4 11-27-2015 03:05 PM
Terms for Hardwood Floor Refinishing Contract floorguy33558 Business 4 06-21-2015 10:39 PM
Slang and Terms for measurements. TNTRenovate General Discussion 54 09-30-2013 09:36 PM
Would you sign a contract, extend terms, etc for a $1500 job? rtztgue Business 2 07-19-2013 02:07 PM
120 day pament terms jon cocroft Plumbing 5 12-13-2010 12:00 AM
