To Amplify Or Not Amplify - Low Voltage - Contractor Talk
Old 07-25-2018, 07:16 PM   #1
Hardly Working's Avatar
Rewards Points: 812
So help me out a little. Hereís a little back story.
Iím a construction manager for a residential home builder. We had a customer move from one of our previous houses (7years old) into a new build (finished a week ago) and heís complaining that his previous OnQ LV panel had a amplifier in it and now the new one doesnít. Same panel manufacturer maybe different part # I donít know.
So my question is. With todays technology do we really need to have an amplifier for the cable. From some people Iíve been told no itís not necessary others say yes. So I come to my brothers at CT to help with my dilemma. If anyone could shed a little light on this for me I definitely appreciate it. Thanks in advance.
Hardly Working is offline
Old 07-25-2018, 07:50 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 694
Re: To Amplify Or Not Amplify
Cable TV/internet?
There's normally plenty of signal to run a 3 way splitter. More legs than that, I'd consider an amplifier.
Tinstaafl is online now
Old 07-25-2018, 08:58 PM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
We call it a bandaid for a reason, only put one on when there's a problem. On a single run of RG6 from the SP you should typically get 4 drops before needing an amp. So if everything thing meters out fine, you're better off without it.
Inner10 is offline
Old 07-27-2018, 09:55 PM   #4
The E's Avatar
Trade: Telecommunications
Rewards Points: 12
Amplifiers should only ever be used if your cable contractor deems it’s necessary. Some of the modern encryption and coding schemes don’t play well with basic amps.
Too much signal is as bad as not enough. Amplification also amplifies noise, drives the noise floor up and affects modulation, resulting in pixelated channels and in some cases missing channel(s).
So no, don’t just throw an amp in because a cx asks for it. As far as I know, most regional cable COs will provide one if it’s necessary.
The E is offline
Old 07-28-2018, 09:20 AM   #5
cwatbay's Avatar
Trade: Electrical Contractor
Rewards Points: 2,566
As a BTW. The Comcast signal we get is weak and has issues. Regardless of how much Comcast brags about their signal and so forth.
I have 10 drops, and, rewired everything in the walls with RG6 quad. I did end up putting a powered amp on the system. So far so good (as least for the last 5 years).
I did replace all of their stuff (Cable Modem) with my own. Much better. The only issues I have is when their equipment up line goes down or their constant internet outages in the region.
cwatbay is offline
Old 07-29-2018, 08:57 AM   #6
Rewards Points: 812
Thanks for the input. I previously had Comcast now with Frontier. Comcast constantly dropping the signal due to a broke wire from the ped. Other than an equipment difference the signal has been great with Frontier.
