Wooden Deck At Ground Level: Excavate? - Decks & Fencing - Contractor Talk
Old 06-04-2015, 11:13 AM   #1
Martwest2007's Avatar
Hi guys, I'm looking at building a wooden deck at the level of the interior floor, which is only a few inches above grade outside. To complicate things even further, 14 feet out the lawn steps up about 30 inches, making the entire area between the house and the back of the yard a bathtub. The client is convinced that he wants a ground level deck; how much airspace do I need under and around this deck for proper airflow? I couldn't find the local building code for this but research suggests 12". This would mean excavating down 24" an area about 14' x 22'.
I'm wondering if it would make more sense to build a waterproof deck with a perimeter drain, rather than creating an airspace under the deck where water can build up.
Of course I'm trying to convince the home owner that a paver or concrete patio would make more sense in this area. Any suggestions? Thanks
Martwest2007 is offline
Old 06-04-2015, 04:39 PM   #2
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Re: Wooden Deck At Ground Level: Excavate?
What would I do? I would sell them on a paver or concrete or walk away. I'm not going to put my name on something like that.
RobertCDF is offline
The Following 4 Users Say Thank You to RobertCDF For This Useful Post:
Calidecks (06-04-2015), CarpenterSFO (06-04-2015), parkers5150 (06-06-2015), redwood (06-05-2015)
Old 06-04-2015, 05:53 PM   #3
Thanks Robert, you're right. Now it's just a matter of convincing the client.
Old 06-04-2015, 06:07 PM   #4
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
When you tell them the cost is half as much I'm sure they will go for it.
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
Old 06-04-2015, 06:26 PM   #5
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
Convince?????????????
just walk away
killerdecks is offline
Old 06-04-2015, 06:44 PM   #6
General Contractor
greg24k's Avatar
Rewards Points: 48
If you excavate, might as well put a liner in and have a floating deck with an option to soak theirs feet. Don't forget to charge extra for that
greg24k is offline
sunkist (06-09-2015)
Old 06-04-2015, 06:48 PM   #7
Box Builder
Morning Wood's Avatar
Rewards Points: 6
Patio
Morning Wood is offline
Old 06-04-2015, 07:12 PM   #8
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
I did one like that !
Behind a Condo , no attention to drainage it was all left up to the owner. Flooded the house every time a big rain came
I clear spanned the whole area and dug out so the water flowed to either side. For all intent turned it into a drainage ditch . A covered drainage ditch.
John Hyatt www.deckmastersllc.com
John Hyatt is offline
Old 06-04-2015, 07:20 PM   #9
Thanks for the feedback. Made my decision to reject the idea easier.
Old 06-09-2015, 06:20 PM   #10
TG Deck's Avatar
Trade: exterior carpentry
Rewards Points: 1,770
Another option is a concrete or other type pad at the entrance area, then going up a 7-8" step onto a deck.
With a large enough pad, it can look nice with the deck wrapping around.
TG Deck is offline
How low to the ground can I get this deck? Easy Gibson Decks & Fencing 76 11-04-2016 11:31 PM
Recommendation for water proofing of multi level wood deck simeonk Roofing 8 11-28-2012 01:34 PM
Slope a deck or a level deck? wallmaxx Decks & Fencing 28 08-13-2009 12:36 AM
