What Pressure Washer Do You Guys Use For Decks And Fences? - Decks & Fencing - Contractor Talk
Old 05-30-2015, 07:00 PM   #1
adkr3153's Avatar
Trade: Deck Repair/Refinishing
Rewards Points: 16
I'm about to buy a pressure washer and I'm wondering if I need a contractor grade power washer or if a decent standard one will do. I need the pressure washer for stripping/cleaning decks and stripping fences. Do you guys have any recommendations?
adkr3153 is offline
The Following User Says Thank You to adkr3153 For This Useful Post:
advisor267 (02-10-2018)
Old 05-30-2015, 07:04 PM   #2
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Re: What Pressure Washer Do You Guys Use For Decks And Fences?
I would never use a power washer on any deck.
John Hyatt www.deckmastersllc.com
John Hyatt is offline
The Following User Says Thank You to John Hyatt For This Useful Post:
Quality_PTG (05-30-2015)
Old 05-30-2015, 07:05 PM   #3
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Get something decent if you are gonna use it a lot. If it's only gonna be once or twice a week just get a model from lowes in the 2800+psi range with more than 2.5gpm
www.bcconstructionllc.com
BCConstruction is offline
Old 05-30-2015, 07:08 PM   #4
Trade: Construction
I wouldn't ever not use one. I have tried doing it without a pressure washer a couple of times but it came out crap compared to pressure washing.
Here's me putting stain on the day after pressure washing.
What pressure washer do you guys use for decks and fences?-imageuploadedbycontractortalk1433030822.118285.jpg
Here's what it looks like now
What pressure washer do you guys use for decks and fences?-imageuploadedbycontractortalk1433030862.886126.jpg
What pressure washer do you guys use for decks and fences?-imageuploadedbycontractortalk1433030881.206741.jpg
The Following 3 Users Say Thank You to BCConstruction For This Useful Post:
Ohio painter (01-16-2018), TNTRenovate (05-31-2015), Tom Struble (05-31-2015)
Old 05-30-2015, 07:33 PM   #5
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,268
I've got a Honda 2600psi. I would also not do it with it pressure washing.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
Old 05-30-2015, 08:20 PM   #6
adkr3153's Avatar
Rewards Points: 16
I've pressure washed every deck I've ever worked on. In fact, I'm not sure how one could properly refinish a deck without one.
adkr3153 is offline
Old 05-30-2015, 09:10 PM   #7
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
then why are you asking
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
The Following User Says Thank You to parkers5150 For This Useful Post:
John Hyatt (05-30-2015)
Old 05-30-2015, 11:21 PM   #8
John Hyatt
John Hyatt's Avatar
The concept is flawed.
forcing water into the wood is fundamentally- working in reverse by adding the very thing that later will be guarded against.
J .
Old 05-30-2015, 11:49 PM   #9
aptpupil's Avatar
Rewards Points: 1,894
I think the concept is forcing dirt out using water. Works faster and better than scrubbing in my limited experience, but you have to wait for it to dry and you can damage wood if not careful.
aptpupil is offline
The Following 2 Users Say Thank You to aptpupil For This Useful Post:
Calidecks (05-31-2015), TNTRenovate (05-31-2015)
Old 05-31-2015, 01:23 AM   #10
adkr3153's Avatar
Rewards Points: 16
I was asking about pressure washers, not whether or not to use them on decks.
adkr3153 is offline
Old 05-31-2015, 01:30 AM   #11
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,046
You can use up to 3000 psi on some composites
Calidecks is offline
Old 05-31-2015, 06:13 AM   #12
Trade: Construction
J .
Your not forcing water into the wood though. It's noting like putting the material into a pressure chamber and putting it under 3000psi.
My deck was back to the same moisture content after 4-5hrs in the sun but I left it till the next morning to apply. It's how I have done every deck since using TWP. In fact they highly recommended using a pressure washer as it better removes the oxidization than scrubbing alone and it also cleans and opens up the woods pores to allow the oil to better be absorbed.
So upto yet
You say - Don't pressure wash
TWP say - Do pressure wash
You say - Apply sealer straight away
TWP say - Wait 4-12months
You say - Build a Film for a gloss look
TWP say - Do not build a film for a gloss look
You say - No to Build layers
TWP says - You can build layers
Old 05-31-2015, 07:25 AM   #13
John Hyatt
John Hyatt's Avatar
Your right on the first two wrong on the second two.
I did build coats to a gloss but warned against others doing it
I did not say anything about not building coats that, of course, I would have to do to get a gloss.
I am in conflict with the recommendations offered by the twp can because I have done the exact opposite and found it worked.
I also found a floor machine/pad worked better than using a power washer.
J.
Old 05-31-2015, 08:28 AM   #14
Trade: Construction
J.
On a thread the other week you said something about having to strip before building coats. That's not the case. I'm not taking about building them to a gloss. That's a different thing. building with a oil to a gloss is not recommended because it builds a film and does not penetrate. The film is prone to flaking because it's not penetrated into the material it's just a film of oil on the surface. That's one reason they say wait 9months before adding another top up coat.
Old 05-31-2015, 08:52 AM   #15
Hair Splitter
Trade: General
J .
Then you aren't using the pressure washer correctly. Acceptable moisture readings will return with a day or two.
Old 05-31-2015, 10:33 AM   #16
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
I have a 4000 psi / 4gpm honda/cat unit that I use for everything. I use the green tip and run it perpendicular to the boards in a quick sweeping motion.
How often will you use it? If you use it frequently the biggest unit you can afford (4kpsi/4gpm is about the biggest before a big price jump) and it will pay for itself since the cleaning will go much faster. I used to have a 2800 psi cat unit from Home Depot and it worked well for years but my new washers are soooooooooo much faster since I can use the green or white tip and clean a much bigger area with each pass.
SuperiorHIP is offline
The Following 3 Users Say Thank You to SuperiorHIP For This Useful Post:
Calidecks (05-31-2015), Ohio painter (01-16-2018), TNTRenovate (05-31-2015)
Old 05-31-2015, 01:51 PM   #17
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
I have a Troy pressure washer with a Honda engine from Lowes, I've had it for about 4 years now and I guess I'm surprised the pump hasn't failed yet (knockin on wood). I don't use it regularly though, more like once a month.
I do use it on decks, but not to clean, just to rinse. They can tear up a softwood deck pretty easily.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 05-31-2015, 01:57 PM   #18
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
I have a BE with a Honda engine, the pump crapped out on it two years ago and I haven't tried to fix it yet. I may just buy an electric and trash the gas one.
Inner10 is offline
Old 05-31-2015, 02:03 PM   #19
Trade: Construction
You are using the wrong tip if they are tearing up softwoods. Mine will cut through a 5/4 PT board if I old it close enough. Use the correct angle tip and keep it 6"+ from the boards and you won't see a single mark on one board.
My pressure washer is a Troy as well. Had it about 6 years and has been used 2x a week at least. Does everything from cleaning gutters, running foam guns, cleaning truck, to cleaning concrete and decks. Only just the other day did it have its first issue. The runber fuel pump bubble got a split in it. Makes it a little harder to start now.
Gonna run this into the ground and get a electric kranzle. Won't have the hassle of fuel then.
Old 05-31-2015, 02:27 PM   #20
avenge's Avatar
Rewards Points: 302
That's the first time I've heard anyone say that. Maybe you should be saying "Don't use a pressure washer on a deck if you don't know what the f**k you're doing".
avenge is online now
The Following 2 Users Say Thank You to avenge For This Useful Post:
redwood (05-31-2015), SuperiorHIP (05-31-2015)
ok to pressure wash real siding? madrina Pressure Washing 27 10-29-2016 08:23 AM
Fences jaylord01 Marketing & Sales 5 10-21-2011 02:47 PM
software for a newbie to decks and fences cheeks Decks & Fencing 11 02-23-2010 11:27 PM
Fences CScalf Decks & Fencing 13 07-10-2009 02:59 PM
