Water At Deck Footing - Decks & Fencing - Contractor Talk
Old 05-29-2015, 09:04 AM   #1
bizz6405's Avatar
Trade: general contractor
Rewards Points: 46
Doing a deck and while digging for footings hit water at about 32" still have another 10" to get to below frost. I am pumping water out to see if we just hit a pocket of water or if it is ground water/spring. Just thinking if it is ground water/spring how would you put drainage in around footings for a deck?
bizz6405 is offline
Old 05-29-2015, 10:31 AM   #2
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,960
Re: Water At Deck Footing
Dig out to the depth that is required for code and drawings. - You may be encountering a lot of wet soil and having a wider excavation. On a big job dewatering could be done with some early planning.
Since it only a matter of going 10" more, just tough it out and form a best as possible. Concrete has been placed below water for decades if proper methods are used (don't dump the concrete into a hole, but use a large hose/pipe to place the concrete and allow the concrete to raise the water level up). The biggest problem is to form the footings and get the rebar (if required) in place for verification by someone else if necessary.
A drawing of the size of the d eck and footing locations would be helpful.
Dick
concretemasonry is offline
Old 05-29-2015, 05:33 PM   #3
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
r u only digging 1 hole, we ran into this 20 years ago around a pool deck, dug em all,38 holes, put a submersible pump in various holes, until we hit the magic hole that drained all the rest.
also if you dig to 56" you can put concrete in at bottom till you are at 44 or so when his tape goes in the hole it'll be hard. you should put some gravel at the bottom of the 56" hole and concrete on top 4 drainage
killerdecks is offline
The Following User Says Thank You to killerdecks For This Useful Post:
bizz6405 (05-29-2015)
Old 05-29-2015, 05:46 PM   #4
Talking Head
EthanB's Avatar
Rewards Points: 438
I'd overdig it and put gravel in the hole so you can get compaction then use stovepipe with a contractor bag taped to the bottom for the footing. It will keep the concrete from getting too wet.
Planer.....
EthanB is offline
Old 05-29-2015, 06:11 PM   #5
Dan_Watson's Avatar
Rewards Points: 2,748
Helical.
Dan_Watson is offline
The Following User Says Thank You to Dan_Watson For This Useful Post:
heavy_d (06-12-2015)
Old 05-29-2015, 08:13 PM   #6
bizz6405's Avatar
Rewards Points: 46
Five footings.
bizz6405 is offline
Old 05-29-2015, 09:18 PM   #7
deck aficionado
SelectDecks's Avatar
Trade: General Building
Rewards Points: 973
Originally Posted by Dan_Watson View Post
Helical.
I'd love to go helical just so gosh darn expensive
James
www.selectdecks.com
SelectDecks is offline
Old 05-30-2015, 07:43 AM   #8
Dan_Watson's Avatar
Where are you?
Its a wash if not cheaper....Add in the time savings and it is definitely cheaper.
Unless you pay guys cash under the table, under minimum wage and don't need footing inspections and always use 8" sonotubes and don't use the correct standoff brackets for the post.
Old 05-30-2015, 09:09 AM   #9
deck aficionado
Rewards Points: 973
Pittsburgh
James
www.selectdecks.com
Old 05-30-2015, 11:10 AM   #10
Dan_Watson's Avatar
Pittsburgh
I might have asked you that before.
Might be frowned upon so PM me and I will send you my email address if this shouldn't be an open discussion on someone else's hijacked thread, but have you calculated what a traditional concrete footing costs? From digging through pouring, and all materials and inspections.
Old 05-30-2015, 11:55 AM   #11
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
Hijacking is good, I thought it was they way things are done on the hate thread,
lets people learn other stuff also
Old 05-30-2015, 02:15 PM   #12
Talking Head
EthanB's Avatar
Rewards Points: 438
Averages $95 dollars for a 10" tube with 16" footing. For me.
Planer.....
EthanB is offline
Old 05-30-2015, 06:29 PM   #13
Dan_Watson's Avatar
I would be $68.32 materials only, no markup, no time to pick them up...Then digging, inspection, concrete and j bolt, cure time....
How did you calculate $95?
Old 05-30-2015, 09:19 PM   #14
Talking Head
EthanB's Avatar
Rewards Points: 438
We're talking cost so markup isn't in it. I don't pay for inspection or dry time or pickup. For me it's usually this:
Sonotube $6
6x6 ABA base $17
Quickcrete $18
Anchor bolt $2
Materials $43
Labor 3x$18
Total = $97
We're hand digging holes for a 10" tube to 42" with a flared bottom for a 16" footing.
I look for a helical installer near me every year. I'd be happy to pay a premium for that product for a number of reasons but I don't see how it could be done for less than what I have. Helical doesn't have to be cheaper. It's easier and better in several ways.
Planer.....
EthanB is offline
Old 05-31-2015, 01:35 AM   #15
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,298
Sonotube $6
6x6 ABA base $17
Quickcrete $18
Anchor bolt $2
Materials $43
Labor 3x$18
Total = $97
Boulders and rocky soil could be an issue. We have our share out here, especially in places like Mira Mesa.
Calidecks is online now
Old 05-31-2015, 08:51 AM   #16
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
ok Mike I'll buy one move to the land of no rain and constant sunshine and do your piers for you.
do you do a lot of them,? Are there lots of deck builders in California?, I only need to make 30k profit a month
that's about 300 piers a month. 75 a week 15 a day
I might be able to struggle by on 20k not sure though, that would be almost like welfare.
EthanB (05-31-2015)
Old 05-31-2015, 12:29 PM   #17
Talking Head
EthanB's Avatar
Rewards Points: 438
Steve, I can't remember, do you have a helical machine? I'm not really interested in diversifying(heading the other direction actually) but you do enough decks to own one for just your company, I would think.
Edit: Never mind. I just remembered that you bury your posts so it wouldn't fit your designs. My memory is going...
Planer.....
EthanB is offline
Old 05-31-2015, 01:36 PM   #18
GC/carpenter
Calidecks's Avatar
My footings are often only 18" deep. Makes more sense to just dig them.
Dan_Watson (05-31-2015)
Old 05-31-2015, 03:09 PM   #19
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
all the more reason to be your helical guy, less work, and than I can charge the real big spenders over there more money for a better thing
Calidecks (05-31-2015)
Deck step footing question Spencer Decks & Fencing 13 05-30-2014 06:41 PM
Re-surfaced deck and now it is pooling water in the middle BTW General Discussion 12 11-27-2013 05:40 PM
Water proof a cantilevered deck KennMacMoragh Decks & Fencing 62 09-09-2011 02:10 PM
New deck footing ? Versaron General Discussion 2 06-16-2011 09:40 PM
