Trex Reveal HR Install Question - Decks & Fencing - Contractor Talk
Old 04-23-2014, 11:51 PM   #1
BuiltByMAC's Avatar
Trade: Deck guy
Rewards Points: 2,270
Hey all,
Installing a Trex Reveal metal HR using the crossover posts because I'm running a deck board as a cap rail.
Have any of you come up w/ a graceful solution for a mitered corner over a single post? They don't have a 90 bracket and the official answer so far is 'can't be done.'
Im going to try something tomorrow but just wanted to know if you guys had already faced this.
Thanks,
Mac
BuiltByMAC is offline
Old 04-24-2014, 09:01 AM   #2
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
Re: Trex Reveal HR Install Question
doesnt that system plug into a standard wood post and sleeve??? ... I've not used it before so therefore have no valuable input ... that being said i would love to see your situation and how you approached it
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 04-24-2014, 10:15 AM   #3
BuiltByMAC's Avatar
Trade: Deck guy
You can use pretty much any post type w/ the Reveal rail, however, they do have their own metal posts that match the color/finish exactly. Their crossover posts have brackets at the top that allow a continuous cap rail. I'm using that option to mount a deck board as the cap rail on top of the railing sections because the HO's want a wider cap.
Mac
Old 04-26-2014, 02:11 AM   #4
BuiltByMAC's Avatar
Trade: Deck guy
Grind one tab off crossover bracket - miter top rails into each other
Install mitered top rail cap
Install deck board cap rail - face screwed 16" oc w/ composite deck screws (positioned so tip of screw dropped into a baluster and didn't poke out of the top rail)
Future builds like this would possibly incorporate the following change - metal cap for top rail to be glued and screwed to bottom of deck board, THEN snapped onto top rail. Might be difficult to line up mitered corners, some testing in the shop is in order.
The one thing we did change was switch the snap-on caps - the curved one went on the bottom rail, the completely flat one went on the top...made it easier to attach the deck board cap rail.
I'll get a few pics of the finished project up tomorrow. This is one I worked w/ Morgan, though to be honest, he built most of it.
Mac
The Following 2 Users Say Thank You to BuiltByMAC For This Useful Post:
parkers5150 (04-26-2014), wallmaxx (04-27-2014)
New install floor prep question gowings Tiling 24 03-04-2014 03:21 AM
Question for those of you who have been injured on the job tyb525 General Discussion 15 08-07-2013 12:54 PM
Question about workin on my own oil burner InterCounty HVAC 6 04-29-2013 12:05 AM
Radiant heat pipe install question im4snow HVAC 6 03-09-2011 07:28 AM
Mini-split system install requirement question tru HVAC 22 02-10-2010 09:18 PM
