Trex Enhance Delivered Warped - Page 2 - Decks & Fencing - Contractor Talk
Old 02-13-2020, 07:21 AM   #21
Canmannc's Avatar
Rewards Points: 190
Re: Trex Enhance Delivered Warped
Originally Posted by CityDecks View Post
Just had another thought. Is that enhanced scalloped on bottom?? Dbl check it might have to be 12" oc. The stuff I'm using on floor is enhanced and needs to be 12oc or you will see sag.
Sent from my SM-G973U using Tapatalk
Yes it's the Enhanced scalloped bottom. And yes replacing joists on 12" centers. Can't use plugs in it. Wherever I use a square edge piece (fascia around outside) it has to be face screwed with color match screws. I don't like that but gotta go with manufactures instructions. Thanks.
Canmannc is offline
Old 02-13-2020, 08:13 AM   #22
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 2,760
I'll shoot you over few close ups later today.
Mike the yellow thing comes in screw bucket. It's a guide for screw but. I find it slows me down. But I do like to use it it joints as gapper. I don't usually gap boards but this job would leave me with chitt load of waste. Let me know if you have anymore questions
CityDecks is offline
The Following User Says Thank You to CityDecks For This Useful Post:
Calidecks (02-13-2020)
Old 02-13-2020, 08:15 AM   #23
CityDecks's Avatar
Trade: Deck Builder
You can plug. Just gotta hit it right
Canmannc (02-13-2020)
Old 02-13-2020, 08:49 AM   #24
Canmannc's Avatar
Rewards Points: 190
I can't find any plugs in Trex "Foggy Warf" color.
Canmannc is offline
Old 02-13-2020, 09:00 AM   #25
CityDecks's Avatar
Trade: Deck Builder
Your going to have to cross brand. If trex does not have similar go to azek. There all the same chitt just a different shade
Old 02-13-2020, 09:01 AM   #26
CityDecks's Avatar
Trade: Deck Builder
Yours looks like its a shade off of trex mystic something.
Old 02-13-2020, 09:20 AM   #27
Canmannc's Avatar
Rewards Points: 190
Well I Sent back the Trex Hidden fasteners and ordered the Camo Edge -X-Clips. Amazon, be here Saturday! I like that it's 410 stainless screw and 305 stainless clips. Since this deck is ground level and less than 100yds to the Ocean. Looks like (as you said) they will be much easier/faster. Thanks City!
Canmannc is offline
Old 02-13-2020, 09:23 AM   #28
Canmannc's Avatar
Rewards Points: 190
I might see if they have any Mystics in stock and test a few. The color is a little variegated on Foggy Warf so it might hide. Thanks
Canmannc is offline
Old 02-13-2020, 09:38 AM   #29
CityDecks's Avatar
Trade: Deck Builder
Plugs are made to a go to here and there. I use here and there if a board comes loose or a repair. So guys waste too much time and money on plugging the hole deck. I think a dumbass move.
Honestly I've built decks as much as 150k and just used color matching screws on starter boards and facial. It's not a problem unless you make it a problem.
I think plugs will move and look like chitt after a while. So dont depend on them.
Old 02-13-2020, 11:07 AM   #30
KAP's Avatar
Trade: Custom
Rewards Points: 39,526
Anytime a factory rep tells me to "go ahead and install it" when I raise a concern about a product I received that doesn't look as advertized, I immediately test their fidelity to that position by saying "so if I install this, you'll cover the labor to remove and replace if it becomes an issue"... and then if they agree to that, get it in writing...
Usually, they'll say no, so that's when I tell them to get me what I ordered then...
KAP is offline
The Following 3 Users Say Thank You to KAP For This Useful Post:
Canmannc (02-13-2020), Justin Rhoades (02-14-2020), tgeb (02-13-2020)
Old 02-13-2020, 11:07 AM   #31
VinylHanger's Avatar
Rewards Points: 12,866
Did I read it wright?? Your reusing lumber correct???
The trex clip are going g to be an even bigger headache.
- not deep / long enough for enough for older dried lumber. Screws are 1-5/8.
- we tape old lumber. Keeps water from soaking in old holes. Add life framing.
- camo edge would be your best concealed at 2-3/8 long screw.
I was teaching a new guy the other day how to deck. Kid never touched a deck board in his life. We banged out almost 600sf in 3hrs 40min.
I've been averaging around 40-50min per 100sf. The cold bent boards slow you down.
No hose no guns no hassle and I'm not even using the stand up guns.
Nothing wrong with fusion or tcg or guns and hoses. This job is all small 100sf decks and would drive myself insane in the small workspace.
That was our other problem with the Fiberon clips. The screws in the old lumber.
Sent from my SM-N975U using Tapatalk
VinylHanger is online now
Old 02-13-2020, 11:44 AM   #32
CityDecks's Avatar
Trade: Deck Builder
Yeah that just sucks. Using modern day products with with. Its always a challenge. Good luck next time. You can always reach out here or me direct.
The Following 2 Users Say Thank You to CityDecks For This Useful Post:
Canmannc (02-13-2020), VinylHanger (02-13-2020)
Old 02-13-2020, 12:18 PM   #33
Canmannc's Avatar
Rewards Points: 190
That's the question I asked my sales rep. I didn't get to talk to the Trex rep. But I said, if I put that down and the ends are sticking up, are you or Trex gonna pay material and my labor to replace it? He said, UUHHH, no.
I said come get that chit and bring me another batch. Hopefully it will be here this afternoon or tomorrow morning. We will see. Maybe the super, duper Camo Edge-X-Clips, recommended by CITYDECKS, will pull that chit down. Thank, KAP
Joel
Canmannc is offline
The Following User Says Thank You to Canmannc For This Useful Post:
KAP (02-13-2020)
Old 02-13-2020, 12:31 PM   #34
test
cedarboarder's Avatar
Trade: General
Rewards Points: 813
Originally Posted by Calidecks View Post
I can almost gaurantee you that isn't caused by Trex. They come out of the plant flat as hell. It's what happens to them during transfer and stacking that causes that.
99% of the problems I ever have with product is caused by carelessness at my yard or at the wholesalers. I don't get too upset because those guys always pay for golf!
Mike.
_______________
Like this?
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Old 02-13-2020, 12:46 PM   #35
Canmannc's Avatar
Rewards Points: 190
Originally Posted by cedarboarder View Post
Like this?
Yes. I am pretty sure it was stored in their warehouse with proper support. The full wrapped up bundle of 16 footers was fine but those 12's look like bananas.
Canmannc is offline
Old 02-13-2020, 12:53 PM   #36
GC/carpenter
Calidecks's Avatar
Rewards Points: 8,490
Like this?
I could get that to work with very little effort.
Mike.
_______________
Calidecks is online now
Old 02-13-2020, 12:55 PM   #37
GC/carpenter
Calidecks's Avatar
Iíve watched it come off the belt at their factory after heat. It lays flat.
Mike.
_______________
Old 02-13-2020, 12:58 PM   #38
Canmannc's Avatar
Rewards Points: 190
Mike.
_______________
I believe mine were much worse. My 250# brother stood on the end and couldn't get it down.
Thanks Mike. BTW Hope you are doing good on your hip recovery. Dear WIFE just had LH hip replaced 6 weeks ago. RH side was done in Nov 2017 and works great. She was back on her horse in less than 6 months.
Joel
Canmannc is offline
The Following 3 Users Say Thank You to Canmannc For This Useful Post:
Calidecks (02-13-2020), KAP (02-13-2020), tgeb (02-13-2020)
Old 02-13-2020, 01:11 PM   #39
CityDecks's Avatar
Trade: Deck Builder
I've moved on to better things to talk about....
Calidecks (02-13-2020), Canmannc (02-13-2020)
Old 02-13-2020, 04:54 PM   #40
CityDecks's Avatar
Trade: Deck Builder
Almost forgot.
DO NOT USE IMPACT DRIVER use with camo. You'll strip.
Use high speed drill with clutch.
I only have hilti's and have my clutch set at 3.
Camo says try 1/2 of what the highest setting the drill has. Start with that. you want to here the clutch spin like dry wall gun.
I love it every time I here the grrr it means I'm 1screw closer to finishing.
