Timbertech / Azek Movement - Decks & Fencing - Contractor Talk
Old 01-16-2020, 09:59 AM   #1
AustinDB's Avatar
Rewards Points: 1,534
putting in an order for grooved Timbertech 50yr decking and the salesman called me back to say that grooved boards were 2-3 weeks out but non-grooved was available in 3 days and that he's heard complaints of board movement with hidden clip fasteners (grooved). He suggested the camo clips and non-grooved, which I accepted b/c the lake level's going up next month and this project needs to get wrapped up.
is there an issue with Azek board movement with hidden fasteners? I thought the spacer IS the spacing and it's screwed down, so not sure what the issue is.
Anything special about using the camo fasteners? first time using this fastener.
AustinDB is online now
Old 01-16-2020, 10:39 AM   #2
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Re: Timbertech / Azek Movement
Are we talking The PVC decking or the composite?
EricBrancard is offline
Old 01-16-2020, 10:55 AM   #3
Tom M's Avatar
Rewards Points: 11,182
If you're not using a gun to install a clip plan on three times the labor.
Even the best efforts 10 to screw with the spacing unless you check it every 6 boards or so. Even though it's man-made they are not dead flat or straight.
As far as movement, the only thing I could think of is a taller clip in the lower groove. I haven't used TimberTech in a while but certain Trex boards are tighter with clips. Not all grooves I located at the same height.
Tom M is online now
AustinDB (01-16-2020)
Old 01-16-2020, 11:56 AM   #4
AustinDB's Avatar
it's PVC core and surface.
it's a 40' boat dock, so I'm going to work hard for consistent straight lines. I have a 10' piece of extruded aluminum from a storefront installation that I'll occasionally use to keep a straightedge over long distances-seems like it may help.
I don't have the screw gun but will use the Camo Marksman Pro tool for installing the decking.
Old 01-16-2020, 12:03 PM   #5
VinylHanger's Avatar
Rewards Points: 12,936
If you are using the Marksman pro with the edge screws, it will take forever. I like the system, but it is slow as molasses.
Sent from my SM-N975U using Tapatalk
VinylHanger is offline
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
AustinDB (01-16-2020), Morning Wood (01-17-2020)
Old 01-16-2020, 01:23 PM   #6
Rewards Points: 986
It leaves the most consistent spacing of any system Iíve seen and with the right system down you can move quicker. With 4 tools and 2 guys you can move quick. With 2-4 tools and 1 guy you can move at an acceptable pace. Paired with PVC decking, itís a very good system.
The Following 2 Users Say Thank You to EricBrancard For This Useful Post:
AustinDB (01-16-2020), Mordekyle (01-18-2020)
Old 01-16-2020, 01:36 PM   #7
GC/carpenter
Calidecks's Avatar
Rewards Points: 8,908
Fusionloc is designed for Timbertech. It has an excellent groove consistency. Nice thing about the fusionloc is the clip has three fastening points of contact.
Mike.
_______________
Calidecks is offline
Old 01-16-2020, 05:04 PM   #8
Rewards Points: 986
Mike.
_______________
Not for square edge boards, though, right?
Old 01-16-2020, 05:25 PM   #9
GC/carpenter
Calidecks's Avatar
True, but I can't see why he can't use the grooved with the fusionloc. He's only using square edge because the grooved was said to move. Imo it ain't going nowhere with the fusionloc.
Sounds to me like the salesman doesn't know what he's talking about and the grooved isn't available so he's hard selling the square edge. I can gaurantee you the Timbertech rep will say different.
Edit: I can see using the square edge because it's or 2 to 3 weeks out, but not because the grooved supposedly moves.
Mike.
_______________
AustinDB (01-17-2020), deckman22 (01-18-2020), Justin Rhoades (01-19-2020)
Old 01-16-2020, 05:44 PM   #10
JoeStanton's Avatar
Trade: Construction
Rewards Points: 82
His problem is the grooved is 2-3 week wait and non grooved is 3 days. His salesman "heard complains" of movement on grooved. I agree the fusionlok is a awsome system.
AustinDB, I have been using the hidfast system http://hidfast.com/ for about 6 years or 30ish decks. No complaints or issues on any and almost as fast as hardwood floors with 3 guys. It's amazing how hard it is to get the nail out if it hits a knot or doesn't fully set.
Only problem is you have to start dead strait and snap lines every 6-8 courses IMO. The nails come out to $1 a sq ft in my area.
JoeStanton is offline
The Following 2 Users Say Thank You to JoeStanton For This Useful Post:
AustinDB (01-17-2020), Tom M (01-16-2020)
Old 01-17-2020, 09:42 AM   #11
AustinDB's Avatar
the hidfast system looks interesting, especially if I was doing enough of it to justify purchasing the driver.
I agree that the salesman was likely trying to get the sale.
The Following User Says Thank You to AustinDB For This Useful Post:
Calidecks (01-17-2020)
Old 01-17-2020, 12:42 PM   #12
That's why I like it. It's pretty fool proof. Last redeck I did I only used 1 tool. Towards the end, I thought that more tools would be better. Probably do 4 to 6 tools on the next one.
That definetly would help the speed as a one man crew. Similar to Gecko Grips with Hardie. More tools make it more better.
The Following User Says Thank You to VinylHanger For This Useful Post:
EricBrancard (01-18-2020)
Old 01-18-2020, 07:23 AM   #13
deckman22's Avatar
Trade: Retired Deck Builder
Rewards Points: 4,766
Mike.
_______________
Spot on Mike. I bet I could name that salesman.
Deckman
deckman22 is offline
The Following 2 Users Say Thank You to deckman22 For This Useful Post:
AustinDB (01-18-2020), Calidecks (01-18-2020)
Old 01-18-2020, 10:12 AM   #14
AustinDB's Avatar
Gtown Lumber?
I wanted to purchase from Timbertown as they have a presence in the hill country builders association, but $0.60 more per linear foot seemed significant enough.
Old 01-18-2020, 12:35 PM   #15
deckman22's Avatar
Did not do much business with them. I guess most lumber salesmen think alike or more likely their bosses do.
Deckman
The Following User Says Thank You to deckman22 For This Useful Post:
Old 01-22-2020, 10:22 AM   #16
AustinDB's Avatar
in Vegas enjoying IBS and the client is stressing because she thinks the Timbertech Silver Oak looks purple.
Initial research looks like these PVC boards can be painted. Anyone have experience with it? I've been using mostly Sherwin Williams materials lately, but willing to change.
