Stupid Human Question. - Decks & Fencing - Contractor Talk
Old 07-07-2020, 08:03 PM   #1
VinylHanger's Avatar
Rewards Points: 13,778
I have a rise of 21 inches, so 3 7 inch steps. It is across around 15 feet wide. So I need to make around 10 or so stair jacks.
Is it easier to just make 2 boxes and stack them and lock them in place or make 10 or 11 short stair jacks.
I'll be setting the ends on pads and locking it all together with blocking. Or I may set one long PT on the flat on pads and set on that. Not sure yet.
What do you do?
Like I said, stupid human question.
Sent from my SM-N975U using Tapatalk
VinylHanger is offline
Old 07-07-2020, 08:39 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,038
Re: Stupid Human Question.
Never heard them called stair jacks before--had to look that up.
I'd go with boxes. And I'm on the internet, so I must be right.
Tinstaafl is online now
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
ScipioAfricanus (07-07-2020), VinylHanger (07-07-2020), wallmaxx (07-09-2020)
Old 07-07-2020, 08:51 PM   #3
Tom M's Avatar
Rewards Points: 12,658
I would ladder box two steps but cut stringer for three.
Three total? deck being the third?
Tom M is online now
Old 07-07-2020, 08:55 PM   #4
Yep, deck is the third.
I had stop and think if I called them stair jacks. Yep, that's what we call them.
It's been a long day.
Old 07-07-2020, 09:07 PM   #5
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 588
Boxes for sure.
Trying to keep that many stringers in line is a biotch.
Andy.
ScipioAfricanus is offline
Old 07-07-2020, 09:56 PM   #6
hdavis's Avatar
Rewards Points: 3,026
I say make it with stringers, and you'll remember to use boxes next time.
hdavis is offline
The Following 4 Users Say Thank You to hdavis For This Useful Post:
Mordekyle (07-08-2020), ScipioAfricanus (07-08-2020), TheConstruct (07-07-2020), wallmaxx (07-09-2020)
Old 07-07-2020, 10:23 PM   #7
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,698
I always cut stringers when I can.
Mike.
_______________
Calidecks is online now
deckman22 (07-09-2020)
Old 07-07-2020, 10:25 PM   #8
GC/carpenter
Calidecks's Avatar
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
greg24k (07-08-2020), wallmaxx (07-09-2020)
Old 07-07-2020, 10:39 PM   #9
Lettusbee's Avatar
Rewards Points: 1,770
I'm trying to understand why?
Boxes seem simpler, as in quicker, and easier to not screw it up?
Mike.
_______________
Sent from my SM-N960U using Tapatalk
Lettusbee is offline
Old 07-07-2020, 11:02 PM   #10
GC/carpenter
Calidecks's Avatar
I don't see it that way. I can cut stringers very fast without issue.
Mike.
_______________
greg24k (07-08-2020), Lettusbee (07-08-2020)
Old 07-07-2020, 11:03 PM   #11
GC/carpenter
Calidecks's Avatar
Not completely sure but I believe stringers take less material as well. When you consider all the ladder blocking. I think it's less work.
Mike.
_______________
Old 07-07-2020, 11:05 PM   #12
GC/carpenter
Calidecks's Avatar
I cut all those stringers on a couple long boards. If I remember correctly I used 20 footers, and didn't cut the small stringers until I had the whole 20' cut.
Mike.
_______________
Dirtywhiteboy (07-09-2020)
Old 07-07-2020, 11:26 PM   #13
Stunt Carpenter's Avatar
Rewards Points: 3,012
I agree. With two treads or less boxes are better. Above that they become more work.
A lot of the time there is enough scrap from the rest of the framing for the blocking. So itís using waste vs making more.
https://builddaley.com/
Stunt Carpenter is online now
Old 07-07-2020, 11:34 PM   #14
hdavis's Avatar
Real stringer= 5 cuts
Box "stringer" = 2 cuts
If it's PT, field treat all the cut ends by standing it in a pan.
Real stringers take a lot more to field treat the cuts.
hdavis is offline
Old 07-08-2020, 12:07 AM   #15
I usually just put a spray bottle sprayer on a bottle of liquid brown death and spray it.
Well, now I have a consensus of two ways to do it.
Now I will spend the entire night over thinking it and then still not know how I want to do it in the morning.
I may do stingers just because I am working alone and building and moving 15 foot boxes will get heavy.
Cutting them all from long material does seem pretty quick.
Though, I would need to drop downriggers and box in the bottom of the deck.
Well, now time for overthinking to commence.
The Following User Says Thank You to VinylHanger For This Useful Post:
hdavis (07-08-2020)
Old 07-08-2020, 12:17 AM   #16
GC/carpenter
Calidecks's Avatar
You are not including all the ladders? They all have to be cut.
Mike.
_______________
Old 07-08-2020, 12:51 AM   #17
Mordekyle's Avatar
Rewards Points: 6,214
How will they be anchored at the bottom?
A few posts?
A beam laying on the ground or in a bed of gravel?
If a few posts, I would box it.
If on a beam or on blocks, I would box it.
Mordekyle is online now
Old 07-08-2020, 07:34 AM   #18
hdavis's Avatar
Mike.
_______________
No, I was pointing out just cutting and treating those pieces. If it weren't for that, boxing would be much slower and use more material.
hdavis is offline
Old 07-08-2020, 08:29 AM   #19
Lettusbee's Avatar
One downside to boxes is it creates an opportunity for unwanted critters to build a home.
The Following User Says Thank You to Lettusbee For This Useful Post:
hdavis (07-08-2020)
Old 07-08-2020, 11:03 AM   #20
hdavis's Avatar
I've made some that were 3 steps, including a landing. A woodchuck decided it was a good place for a home.
hdavis is offline
