Stone Over Existing Decking - Decks & Fencing - Contractor Talk
Old 04-01-2019, 05:29 PM   #1
Tgriff's Avatar
Trade: Residential Builder
Rewards Points: 14
I have a project on deck for a deck surface replacement where the previous owner put field stone on the side of the home post deck construction. I've never really encountered this issue before. My concern is the old risers are 3/4" and the new is a 9/16" composite and there will be a 3/16" gap after the new is installed. What would you all suggest to fill it with. I'm also concerned there may not be any flashing which would blow. Thanks in advance for any suggestions y'all might have,
Tgriff is offline
Old 04-01-2019, 05:59 PM   #2
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 14,026
Re: Stone Over Existing Decking
Composite decking that's 9/16
I wouldn't touch composite that's 9/16" thick. Rafters would have to be like 6" oc.
And shouldn't you be reframing it if it's going to be 9/16" decking? I can't imagine the decking there is framed for something like that.
[signature removed by admin]
Deckhead is online now
The Following User Says Thank You to Deckhead For This Useful Post:
greg24k (04-07-2019)
Old 04-01-2019, 06:10 PM   #3
Tgriff's Avatar
Rewards Points: 14
You ever just have one of those days where you've been looking at your notes for way too long and are losing your damn mind, then go to a forum and say some **** that makes no sense because its wrong. Yup that's today for me. Its the risers for the stairs I was talking about.
Tgriff is offline
The Following User Says Thank You to Tgriff For This Useful Post:
Deckhead (04-01-2019)
Old 04-01-2019, 06:30 PM   #4
Deckhead's Avatar
Trade: Carpentry,
Just shim them out.
Old 04-01-2019, 06:31 PM   #5
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 2,280
Cut some shims, if itís just for those few risers.
Idothat is online now
Old 04-01-2019, 06:32 PM   #6
Idothat's Avatar
You beat me to it , deck
The Following User Says Thank You to Idothat For This Useful Post:
Old 04-01-2019, 07:32 PM   #7
Tgriff's Avatar
Rewards Points: 14
Only issue is there are 5 more risers on the other side and the riser boards are all exposed on one side. Shims were my first thought as well. The customer isnt interested in seeing the space on the exposed side of the riser. Im thinking that filler that is used on brick veneer might be my best bet but I am not a fan of something mucking up the new composite.
Tgriff is offline
Old 04-01-2019, 07:47 PM   #8
TheConstruct's Avatar
Rewards Points: 1,014
If you rip the shims out of the same material and glue it to the riser it will just look like the riser is full depth from the side.
TheConstruct is online now
The Following User Says Thank You to TheConstruct For This Useful Post:
Tgriff (04-01-2019)
Old 04-01-2019, 08:08 PM   #9
GC/carpenter
Calidecks's Avatar
Rewards Points: 18,658
Cut back the stringer and pack out the fronts with 2x. Just don't cut them back 1-1/2"!. Do the math. I'm not fond of little sticks behind risers.
Mike.
_______________
Calidecks is offline
The Following 4 Users Say Thank You to Calidecks For This Useful Post:
greg24k (04-07-2019), mrcat (04-01-2019), tgeb (04-01-2019), Tgriff (04-01-2019)
Old 04-01-2019, 08:16 PM   #10
Tgriff's Avatar
Rewards Points: 14
Mike.
_______________
Good Call! Thank you. I think this is the way to go.
Tgriff is offline
Calidecks (04-01-2019)
Old 04-01-2019, 10:57 PM   #11
GC/carpenter
Calidecks's Avatar
I'm assuming you meant stringers?
Mike.
_______________
Old 04-02-2019, 01:03 PM   #12
Tgriff's Avatar
Rewards Points: 14
Mike.
_______________
No this was on me. My OP said decking not risers because I was planning and frustrated and looking for ideas.
Tgriff is offline
Deckhead (04-06-2019)
Old 04-06-2019, 06:48 AM   #13
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 1,366
Leave gapped and call it drainage.
Sent from my E6810 using Tapatalk
CityDecks is offline
Old 04-06-2019, 10:45 AM   #14
GC/carpenter
Calidecks's Avatar
Even so the decking you are talking about doesn't go on Rafters. It goes on Joists or stringers.
That was my point. No biggie just clarifying.
Mike.
_______________
Exterior stone tile insets at wood decking ??? akm Decks & Fencing 27 11-16-2016 11:33 AM
Eldorado Stone Over Existing Brick Aircooled Masonry 20 03-27-2011 09:44 PM
stone veneer over rough stone wall adzling Masonry 18 10-03-2010 06:40 PM
stone deck- existing cool cote europeanfloors Tiling 5 07-10-2009 09:00 PM
