Spacers For Decking - Decks & Fencing - Contractor Talk
Spacers For Decking
Old 08-05-2010, 08:17 PM   #1
C.M.J.'s Avatar
Trade: Licensed Residential Builder
Rewards Points: 75
Spacers For Decking
We are currently in the middle of a cedar deck build (our first cedar deck) and I'm trying to find a more efficient and quicker way to complete this project. We are using 8d nails for spacers and it is killing us on time. I want to find something we can just drop in between the deck boards.
I tried to search for a thread I saw a few months ago and came up empty. The thread in question had some pics of a deck that had about a bazillion yellow or orange spacers. I wanted to find out the manufacturer of said spacers. Any help would be great! Thanks!
C.M.J. Residential Services llc.
Interior/Exterior Remodeling
Hardwood and Laminate flooring
Decks
C.M.J. is offline
Old 08-05-2010, 08:18 PM   #2
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
Re: Spacers For Decking
why not go buy a sheet of 1/8th inch masonite and rip it into 3 inch strips.
Then ya just drop a few 8 foot pieces between your decking.
Brett Hocking
Eagle Eye Construction/Aspen Custom Cabinets
Buffalo, WY
bhock is offline
Old 08-05-2010, 08:25 PM   #3
Uber-Member
jeffaah's Avatar
Trade: Carpenter...Deck Guy
Rewards Points: 250
Bang some 8d into a small block of wood and then cut the head off.
Simpson makes plastic spacers the stay after the deck is installed. They have a sloped top and come in different colors. I see them at HD near the hangers/metal connectors.
jeffaah is offline
Old 08-05-2010, 08:38 PM   #4
C.M.J.'s Avatar
Rewards Points: 75
I like both ideas, however, I need something that is a little more compact for transport. I don't really want to use something that stays in after the install like the Simpson spacers. If I can't find the thread I saw I might just try the masonite idea. Thanks for the quick replies guys!
Decks
C.M.J. is offline
Old 08-05-2010, 08:57 PM   #5
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
We use heavy strap ties, about 2" wide and various lengths, but we usually use 6' and 5' if we can.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 08-05-2010, 09:00 PM   #6
Interior Renovations
KellyD&B's Avatar
Rewards Points: 250
You could use some wood biscuits.
KellyD&B is offline
Old 08-05-2010, 09:02 PM   #7
Rewards Points: 2,000
This is as close as I
can get.
http://www.contractortalk.com/f50/bow-wrenches-75418/
I have some from Johnson.
neolitic is offline
Old 08-05-2010, 09:03 PM   #8
C.M.J.'s Avatar
Rewards Points: 75
Do you mean like the ratchet straps?
Decks
C.M.J. is offline
Old 08-05-2010, 09:08 PM   #9
can get.
http://www.johnsonlevel.com/ProductD...&ID=28&pID=106
neolitic is offline
Old 08-05-2010, 09:09 PM   #10
C.M.J.'s Avatar
Rewards Points: 75
can get.
Neo-That's the one! Thanks! Where did you find your spacers?
Decks
C.M.J. is offline
Old 08-05-2010, 09:11 PM   #11
C.M.J.'s Avatar
Rewards Points: 75
Thank you Neo!
Decks
C.M.J. is offline
Old 08-05-2010, 09:12 PM   #12
Sometimes Menards has them.
Don't know about Blowes,
I got my first pair at a now
deceased lumber yard.
neolitic is offline
Old 08-05-2010, 09:13 PM   #13
neolitic is offline
Old 08-05-2010, 09:14 PM   #14
The Deck Guy
Greg Di's Avatar
Pre-HFS, they all used to give them away.
Greg Di is offline
Old 08-05-2010, 09:16 PM   #15
stp57's Avatar
Trade: carpenter/ handyman
Rewards Points: 1,000
Isn't the cedar still wet? Why would you space it if it's just going to shrink?
Steve
stp57 is offline
Old 08-05-2010, 09:31 PM   #16
C.M.J.'s Avatar
Rewards Points: 75
Steve
The cedar we are using is not extremely wet. Also, the HO wanted spaces. This is the first and last time we offer that option to the HO...lol.
Decks
C.M.J. is offline
Old 08-05-2010, 10:18 PM   #17
deckman22's Avatar
Trade: Retired Deck Builder
Rewards Points: 2,312
It may not look as good but a cedar deck will last longer with a wider gap. If the gap is too small dirt/leaves get stuck in there rotting the boards along the edges, seen it more times than I could count. If the wood is fairly dry as you said that's exactly what you should do, put that 3/16" gap in just like Neo's spacer does cause cedar will swell a lot when it gets soaking wet.
Deckman
deckman22 is online now
Old 08-05-2010, 10:57 PM   #18
redwood's Avatar
Rewards Points: 496
These are probably a lot cheaper then those spacers and don't take up a lot of space.
We use the MST's. Lay them in, slam the board against them and/or use the bow wrench. Done with the row, grab the strap with the claw of your hammer, and move on.
http://www.strongtie.com/products/co...S-HST-LSTA.asp
Mark
Pioneer, CA
redwood is offline
Old 08-06-2010, 04:59 AM   #19
Hofmann's Avatar
Trade: carpenter
Rewards Points: 150
Nails are no good because if the board is bowed it will just squeeze around the nail and close up the gap. Apart from that, the gaps are too small.
Buying special spacers is expensive and you have to hang on to them, taking up valuable truck space.
The ripped masonite is by far the best solution except that it can swell with moisture overnight and suddenly everyone can tell where you finished on day one and started on day two.
I only ever use 4.5mm hardie sheeting which I have usually demoed off the job somewhere, it's everywhere, or an offcut from the shed. You can just break it into neat squares over a joist. If you drop one through a gap, who cares, keep going. When you finish, keep em if you want or bin them and make new ones for the next job.
Hofmann is offline
Old 08-06-2010, 05:03 AM   #20
PA woodbutcher's Avatar
My speed squares are 3/16". That is what I use for reveals around doors and windows.
When you rob Peter to pay Paul, chances are pretty good you will receive Paul's vote. Apparently the object of the game is to create more Pauls than Peters....What happens when the Peters can no longer support the Pauls? .
PA woodbutcher is offline
Block Spacers 6stringmason Masonry 47 02-09-2010 02:46 PM
Tile spacers.... worst invention ever. GC-B General Discussion 27 09-08-2009 08:35 PM
tile spacers lazerguy Tiling 20 07-20-2008 07:14 PM
Can you help me to sell tile spacers? shimmerl Contractor Swap 6 04-04-2006 09:21 PM
