Ripping Trex On End? - Decks & Fencing - Contractor Talk
Thread Tools
Old 05-09-2010, 01:33 PM
vthunter
vthunter's Avatar
Trade: remodel
not so much a deck question but material handling....
brainstormed this idea to replace the nasty carpet in my boat (very stupid idea putting carpet in a boat).... i had originally stripped it to put spray-in bedliner on the floor and a few inches up the sides to make a nice wash and wear floor covering. then thought about ripping trex (or other syn deck material) on end for a finished thickness of say slightly less than 3/8" (giving me two working sides for each piece) and making it more flexible to get 100% contact for glue. should i have any worries for getting this stuff that thin for my application?
anyone rip this stuff down that thin for a threshold or decorative finish? wondering also which would be the best fastening method, epoxy? ss screws? both?
dont want the wider facia/rim board look. plus i like the idea of getting two boards for one all opinions welcome.....
thanks
doug
vthunter is offline
Old 05-09-2010, 07:23 PM
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 24
Re: Ripping Trex On End?
No way would I want something like that on a boat deck. Way too slippery when wet--that's why they put carpet on.
But if you're determined to do it, I imagine epoxy would be best. That would unitize everything, with no voids. Try it on something other than your boat first, though.
Tinstaafl is offline
Old 05-09-2010, 08:54 PM
deckman22's Avatar
Trade: Retired Deck Builder
Rewards Points: 58
How you gonna cut that trex? It'll be some flimsy stuff however you cut it.
Better keep brainstorming.
Deckman
deckman22 is offline
Old 05-10-2010, 05:21 AM
PA woodbutcher's Avatar
Rewards Points: 1,000
Have never used trex, but imagine it would be like the composites I have used, hell on blades. Can't imagine trying to run it through the band saw without melting everything and making a mess.
When you rob Peter to pay Paul, chances are pretty good you will receive Paul's vote. Apparently the object of the game is to create more Pauls than Peters....What happens when the Peters can no longer support the Pauls? .
PA woodbutcher is offline
Old 05-10-2010, 06:43 AM
D.Foster's Avatar
Trade: Carpentry & Remodeling
Maybe if you built a jig to hold it on edge and support the saw over top of it. Have one continuous support on one side to run a circular saw guide on, and enough surface area on top of the jig to keep the saw stable.
But like the others said i dunno about trex on a boat....
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 05-10-2010, 09:36 AM
curapa's Avatar
Trade: Carpentry / Fencing / Decks
My bass boat has marine carpet and we have never had a problem with it. If the right carpet is used then you should be good to go.
I wouldn't use a composite or PVC material in a boat. I don't really have a reason for it besides the weight but just seems weird considering there are so many options intended for boat decks.
For the deck look into Awlgrip, Duraback, Tuff coat. Bedliner has been used many times before and it does work. You definitely want to put down a white or light color.
http://www.seadek.com/
I saw the product a while back and it looks pretty impressive. You can get it in wood grain if you want.
www.ParkerFenceandDeck.com
curapa is offline
Old 05-10-2010, 04:06 PM
D.Foster's Avatar
He must have left overs, and only half of what he needs!!
D.Foster is offline
Thread Tools
Rate This Thread
Trex Gate?? D.Foster Decks & Fencing 17 06-06-2012 10:34 AM
Noisey Trex????? Shoreline58 Decks & Fencing 13 04-25-2010 11:28 PM
Trex Partners with Service Magic Five Star Business 21 02-11-2010 07:39 PM
trex sm partnership Bone Saw Decks & Fencing 5 02-11-2010 09:41 AM
Spec critique: screened porch floor stone, adjacent deck Trex UpNorth Decks & Fencing 0 01-21-2010 06:28 AM
