#21 | |
Trade: Construction
Rewards Points: 2,394
Re: Required Size Steel Beam For This SituationQuote:
www.bcconstructionllc.com |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
#22 | |
Rewards Points: 2,248
Let me know when you find those steel I beam span tables for joist loading on a deck.
-John |
#23 |
Champion Thread Derailer
Trade: Home Renovations
Rewards Points: 380
See if this is any help. The feller is a PE and has a good app ($3.99) for your phone to calculate spans for steel beams of various make and model:
http://www.constructionknowledge.net...nding_page.php |
The Following User Says Thank You to Jeff G For This Useful Post: |
BCConstruction (04-16-2015)
Sponsored Links | |||
Advertisement |
#24 |
Trade: Construction
They are not I beams. They are LG steel beams.
#25 | |
Rewards Points: 292
If you want an engineers opinion on what to use let me know all pertinent information and I will gladly run it by mine. |
#26 | |
Trade: Construction
#27 |
Rewards Points: 380
Re: Required Size Steel Beam For This Situation |
#28 | |
Trade: Construction
#29 |
Trade: Custom deck builder
Rewards Points: 1,533
I haven't found a beam span chart yet, sorry. My building department requires an engineers stamp for it anyways so I don't even bother trying to figure it out.
For your plan of 2 posts with that span, you'll want a wide flange beam. To do it out of light gauge might be possible but it's probably pretty close to the max. Drop a post in the middle and it's easy.
Robert Shaw Colorado Springs Custom Decks Colorado Custom Decks Custom Homes Colorado |
The Following User Says Thank You to RobertCDF For This Useful Post: |
#30 |
Trade: Construction
waiting for someone to call me back.
The Following User Says Thank You to BCConstruction For This Useful Post: |
Jeff G (04-16-2015)
#31 |
Rewards Points: 3,422
#32 | |
Trade: Construction
![]() Might have someone getting back to me about knocking up a beam span chart for the LG steel. Yeah i was gueesing i would be getting real close to max span bassing it on just a single 12" 14 gauge wide flange joist. 4 of them boxed into 2 would prob def be strong enough but that aint good enough as i wanna see something from the company who makes it to say thats fine. Plus it will be ok for getting it signed of that way too.
#33 |
Trade: Construction
a picture will explain. This is not mine by the way. Just found it on google
#34 |
I'm lost. What are you asking anymore? The above photograph is steel studs, don't you want to know about the I or W they land on? The type of joist doesn't matter, then could be wood, MS or pan decking.
#35 |
Rewards Points: 1,136
If you can figure out this table, it has the answer:
http://mercypleasetw.weebly.com/uplo...88483_orig.jpg You'll still need an engineer for the joist to beam and beam to post connections. edit: I see you're talking light gauge steel - I'll leave the link up, but that isn't light gauge. Last edited by hdavis; 04-16-2015 at 12:47 PM. Reason: more info |
The Following User Says Thank You to hdavis For This Useful Post: |
#36 | |
Trade: Construction
#37 |
Trade: Construction
You been lost from the start. No they are not steel studs they are punched c joists.
#38 |
#39 |
Trade: Construction
WTF is your fascination with engineers. Give it a ****ing rest.
#40 | |
What is your fascination with doing things wrong? Advertisement |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Deck on Steel Beam | oldfrt | Decks & Fencing | 33 | 06-05-2013 07:36 AM |
Steel frame deck need engineered input | rotarex | Decks & Fencing | 18 | 05-26-2013 10:54 PM |
Want a second opinion on what size beam I should use | Old Meets New | Construction | 7 | 08-11-2012 09:38 PM |
Steel support beam | cherm90 | Carpentry | 2 | 07-27-2012 02:29 PM |
What size steel beam to use for load bearing wall??? | brianmvp | Construction | 16 | 07-29-2009 05:56 AM |
Go to Page... |
