Rattling Dekorators - Page 2 - Decks & Fencing - Contractor Talk
Rattling Dekorators
Old 07-10-2012, 09:06 PM   #21
Resident Pain
CanningCustom's Avatar
Rewards Points: 1,730
Re: Rattling Dekorators
Looks great Tim, glad to see you are still around Mac too!
CanningCustom is offline
The Following User Says Thank You to CanningCustom For This Useful Post:
BuiltByMAC (07-12-2012)
Old 07-15-2012, 10:23 PM   #22
Rewards Points: 748
Update: we used silicone and it eliminated the problem. If we ever do this again, we'll try and use different connectors.
Timuhler is offline
The Following User Says Thank You to Timuhler For This Useful Post:
CanningCustom (07-15-2012)
Old 07-16-2012, 01:45 AM   #23
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
I always use the deckorators designer connectors, and I don't recall a problem with rattling.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 07-16-2012, 11:00 AM   #24
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Rewards Points: 2,000
I just recently used the deckorators w/ connectors and their connectors are crap.
I won't use them again either.
Winchester is offline
Old 07-16-2012, 05:40 PM   #25
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Uppers sounds like a batch problem. They did work and now they dont. Perhaps their halo has sliped down to one side and needs adjustment.
On the subject of conectors it is very easy, for Craftsmen like you good gentlemen are, to make your own wood devices. And this method has several advantages....I can make a few hundred of them in a couple of hours out of material I normaly toss.....they can be glued in...most of the time the Co. sells the screws along with the conectors those same screws cost me .4 cents per, and then there is always the fetching plus of control over delivery.
JonMon www.deckmastersllc.com
John Hyatt is offline
Old 07-17-2012, 05:11 PM   #26
thecabinetguy's Avatar
Trade: Cabinetry
Rewards Points: 75
We went back to the custom we built last year to frame a set of stairs off the deck.
We put one section of rail up and the 3/4" round balusters rattle. Is this normal to Dekorators? Any easy fix?
The rest of the deck was http://solutionsaluminum.com/sr_balu...onnectors.html and were easy to install and no rattle.
I'll be calling the lumberyard tomorrow.
I tell ya, I wouldn't mind working with a view like that! Those steps def look pretty dang sturdy
thecabinetguy is offline
Old 07-17-2012, 06:00 PM   #27
Windwash
Windwash's Avatar
Rewards Points: 148
Always appreciate your photo essays Are there risers going on? The bottom rail looks a bit high to meet the 6" rule here but don't know what code your under.
Windwash is offline
The Following User Says Thank You to Windwash For This Useful Post:
killerdecks (07-17-2012)
Old 07-17-2012, 06:35 PM   #28
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,442
I was thinking the same thing. Around here, the deck wouldn't meet code - It needs closed risers and the bottom rail on the stairs needs to be tight to the stair treads.
Regardless, it looks solid as can be, so nice work.
J L is offline
Old 07-17-2012, 07:16 PM   #29
Rewards Points: 748
Thanks guys.
You guys are very observant. The owner didn't want any risers, I think so he can keep them clean of debris from the trees and that side gets a lot of wind. He's getting older and doesn't move so well.
Timuhler is offline
Old 07-17-2012, 07:17 PM   #30
Rewards Points: 748
A question:
Where do you guys start your measurement for rail height? Or better, how do you measure in your rail height?
Timuhler is offline
Old 07-17-2012, 07:25 PM   #31
Windwash
Windwash's Avatar
Rewards Points: 148
A question:
If I'm understanding you correctly, a board laid diagonally on the stair treads and measure up from that is where I measure railing height from.
Windwash is offline
Old 07-17-2012, 07:37 PM   #32
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Min 36" from the nosing of the tread is what we do.
RobertCDF is offline
How to stop metal cables from rattling brothergrimey Framing 2 05-17-2010 04:23 PM
