Questions About Framing A Ground Level Deck - Page 2 - Decks & Fencing - Contractor Talk
Old 06-09-2010, 07:31 PM   #21
Tom M's Avatar
Rewards Points: 11,170
Re: Questions About Framing A Ground Level Deck
I know the spec's for TimberTech Florizon were very clear on ventilation and limits. Even though composite is still composite I believe they were more liberal with the other boards. If your fully closed up lack of air is going to cause some problems. Synthetic would have to be the safest bet if you can sway them.
Tom M is online now
Old 06-09-2010, 08:16 PM   #22
Project Superintendent
mudpad's Avatar
Rewards Points: 2,000
Originally Posted by WarnerConstInc. View Post
I vote for stamped concrete.
Me too. They probly have a stamp pattern and color to make it look just like good old PT from HD
mudpad is offline
Old 06-09-2010, 08:27 PM   #23
DeckPros's Avatar
Trade: Outdoor Construction
Rewards Points: 250
I always try to talk those customers into pavers, bluestone, flagstone etc.
But in some cases, their lots are already at or close to impervious coverage limits (welcome to NJ). So a deck is the only choice. If it's right on the ground, the only choice in my mind is a PVC decking. And make sure to special order ground contact rated framing lumber.
http://www.thedeckpros.com
DeckPros is offline
Old 06-09-2010, 10:14 PM   #24
stp57's Avatar
Trade: carpenter/ handyman
Rewards Points: 1,000
Good improvisation. Did you just change out the windows, or is that a new house?
Steve
Originally Posted by festerized View Post
Same deal here, accept we have 4 of stone
stp57 is offline
Old 06-09-2010, 10:20 PM   #25
stp57's Avatar
I built this PT deck on concrete with 4x4's as joists. No wood touches the ground because I used composite shims under the joists. There is also a drain under the deck with an access door. Two years & no problems.
Steve
stp57 is offline
Old 06-09-2010, 10:30 PM   #26
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,824
I have seen a barn plank stamp before.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 06-10-2010, 04:45 AM   #27
mudpad's Avatar
We have poured concrete walls with architectural form liners that look like pegged wood planks after the forms and liners were removed. From a short distance it was hard to tell the difference.
mudpad is offline
Old 06-10-2010, 05:29 AM   #28
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Steve
Fire restoration
festerized is offline
Old 06-10-2010, 06:57 AM   #29
stp57's Avatar
Wow! What is the siding composed of (it doesn't appear to be damaged)? Obviously, the soffit is vinyl.
Steve
Fire restoration
stp57 is offline
Old 06-10-2010, 07:24 AM   #30
deckman22's Avatar
Trade: Retired Deck Builder
Rewards Points: 4,764
Drainage & ventilation are what's needed. If you can excavate the area under the deck to create drainage away from the house along with allowing air to flow under the deck it's doable with 2x6 flush framing. I wouldn't recommend using cedar or redwood for that kind of deck, probably not reliaboard either as there are exposed wood fibers, but one of the pvc decking products.
Deckman
deckman22 is offline
Customer Questions - Azek or Correct deck? (3 children & 2 big dogs) Legan3rd Decks & Fencing 11 01-11-2011 10:40 PM
Should Deck Posts Sunk In Concrete or Above Ground? Vince10 Decks & Fencing 40 04-30-2010 08:43 PM
Deck Awning Demolition Questions jerome8283 General Discussion 4 08-01-2007 02:52 PM
Building a deck flush to the ground Kingflynn Decks & Fencing 6 06-15-2007 06:38 PM
2 questions regarding a deck, actually 3. daveincincy Decks & Fencing 26 02-17-2007 10:04 PM
