Question For Wheelchair Ramp - Decks & Fencing - Contractor Talk
Old 07-25-2010, 09:56 AM   #1
sbcontracting's Avatar
Trade: General Contracting
Rewards Points: 562
Hey there. I'm doing a bunch of work on a home, one of the things is to upgrade the wheelchair ramp a bit. Right now it's P/T 3/4" Plywood and rotted out at the bottom where it hits the ground... not to mention they have a rubber mat sitting on top of it that retains water.
It's a simple ramp - maybe 14" high at the highest and extending out about 17', 4' wide. I was planning to construct out of cedar, 5/4 planks for the surface.
My problem is where it meets the ground. There is an existing Interlock sidewalk which I want to make flush with the ramp. I was planning to remove a couple of courses of interlock to make this happen.
So the question is - how do I handle the frame at the bottom of the ramp? It's going to be exposed to the dirt/ground. My concern with digging down below grade I will create a catch-basin where water will pool.... unless I dig a drainage ditch. Hoping to avoid this complexity with a simpler solution.
Are there products out there designed to handle transitions like this? Or do I just taper the joists down to nothing and have them slightly elevated?
Thanks for any input....
sbcontracting is offline
Old 07-25-2010, 10:01 AM   #2
Rewards Points: 562
Re: Question For Wheelchair Ramp
IGNORE! Just found the 'ramp-a-thon' thread....
Old 07-25-2010, 10:18 PM   #3
WallMonkey's Avatar
Trade: Framer/Carpenter
Rewards Points: 75
Mac KNOWS!!!
and, i really need to post up pics of my recent and finished ramp...
https://www.contractortalk.com/f50/an...-thread-80944/
"I Really Do Need To Get A Job To Support My Framing Habit"!!!
WallMonkey is offline
Old 07-26-2010, 06:46 AM   #4
Rewards Points: 562
Question - I was intending to use cedar - looks nicer... but that sure-grip plywood stuff seems to be a lot more sensible.
Are there stick-on grippy-sandpaper that you can buy? We get a lot of snow up here, so I'm not sure that would be enough.
Going to call a couple of specialty plywood shops today to see if they have the sure-grip stuff. But any other suggestions on making the surface winter/slip-proof, other than the sure-grip plywood?
Regards, Mike
Old 07-26-2010, 06:57 AM   #5
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 198
You can add it, and add some some more, and add some more...
It works best on flat level area's but is prone to chipping, peeling, etc... The only places I have see the materials last is on concrete & generally then painted concrete which helps block the water from getting under it
Stain with that sand product (non slip additive) added?
SLSTech is offline
Old 07-26-2010, 07:35 AM   #6
Rewards Points: 562
Yeah, was thinking of something like that... anyone use anything? Not sure of who to even ask ie maybe wood store... such a specialty application..... but probably the way to go
Old 07-26-2010, 08:36 AM   #7
deckman22's Avatar
Trade: Retired Deck Builder
Rewards Points: 5,598
Don't bother trying to add something to stain. I was asked to do that very thing on a big commercial job some years back. The deck was all ready stained so I used spar eurathane, added polymar beads to it & coated it over the stained cedar deck. It looked & worked great, but only for a short while. It was worn smooth off in about 3 months. There's no way any stain that I know of would hold the polymar beads, soon as it was absorbed into the wood they would just be loose sand on the deck.
In another area, a bridge from the parking lot to the front of the stores, I used these sticky strips that looked like sandpaper on top. They wore out fast too. Keep in mind this was at a very busy place with lots of foot traffic, on a home I'm sure these would have lasted a good bit longer.
One other time, I added crushed walnut shells to paint for a customer that wanted their deck painted. I used a high grade enamel paint that would have been slick when wet so the grit was needed. This worked pretty well, but was a piece of work getting an even amount of grit everywhere. The paint had to be constantly stirred & most of the grit would come off the roller where first applied, like one time around the roller.
Deckman
deckman22 is online now
The Following 2 Users Say Thank You to deckman22 For This Useful Post:
sbcontracting (07-26-2010), SLSTech (07-26-2010)
Old 08-05-2010, 06:40 AM   #8
Rewards Points: 562
This ramp turned out really nice. I'll post photos later.
What do people prefer for finish? Water-based sealer? It's western red cedar.
Old 08-05-2010, 07:02 AM   #9
Sean
SLSTech's Avatar
Rewards Points: 198
Oil based stains last longer in my opinion, but generally take a few days before they are supposed to be walked on
Water based is fine, just more frequent re-applications
No matter what make sure the deck is fully cleaned & dried before installing the sealer
SLSTech is offline
Old 08-05-2010, 10:10 AM   #10
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
can someone please direct me to the rampathon thread
parkers5150 is offline
Old 08-05-2010, 01:50 PM   #11
BuiltByMAC's Avatar
Trade: Deck guy
Rewards Points: 2,270
https://www.contractortalk.com/f11/ramp-thon-50366/
Mac
BuiltByMAC is offline
The Following User Says Thank You to BuiltByMAC For This Useful Post:
parkers5150 (08-05-2010)
Question from lawyer trying to help contractor scp Business 52 02-25-2011 01:23 AM
Contract question MACEXCAVATING Excavation & Site Work 4 12-20-2008 09:24 PM
HVAC Licensing question kdan General Discussion 2 08-25-2008 08:17 AM
