Pros And Cons Of Attaching Ledger Board With Spacers - Page 2 - Decks & Fencing - Contractor Talk
Old 02-13-2019, 08:51 AM   #21
deckdog's Avatar
Trade: deck builder
Rewards Points: 48
Re: Pros And Cons Of Attaching Ledger Board With Spacers
Originally Posted by Patrick Munsell View Post
Here's a pretty good explanation of the differences.
Definitely two different animals.
https://www.brighthubengineering.com...or-lag-screws/
I wasn't saying they were the same. what I am saying is that most people will say "Lag that ledger to the wall" and do it with Structural screws.
deckdog is offline
The Following User Says Thank You to deckdog For This Useful Post:
Patrick Munsell (02-13-2019)
Old 02-13-2019, 03:11 PM   #22
GC/carpenter
Calidecks's Avatar
Rewards Points: 8,478
Hanging the ledger out with spacers puts more stress on the bolts, imo
Mike.
_______________
Calidecks is online now
Old 02-14-2019, 12:59 AM   #23
Talking Head
EthanB's Avatar
Rewards Points: 434
Originally Posted by deckdog View Post
I think "Lags" is a generic term used for most structural screws.
DD
Not in my world. We go through about 5 pallets of structural screws a year. If an engineer says lag, you have to use a lag, not a structural screw.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
griz (02-14-2019)
Old 02-14-2019, 01:23 AM   #24
GC/carpenter
Calidecks's Avatar
It's not hard to get an engineer to make that change. I've twisted heads off lags many times. Never happens with a structural screw.
Mike.
_______________
Rio (02-14-2019)
Old 02-14-2019, 08:20 PM   #25
Talking Head
EthanB's Avatar
Rewards Points: 434
Mike.
_______________
It can be on commercial. There are frequently 3 people between us and the engineer and they can't be bothered to worry about every little thing
Planer.....
EthanB is offline
The Following 2 Users Say Thank You to EthanB For This Useful Post:
Calidecks (02-14-2019), griz (02-14-2019)
Old 02-14-2019, 09:21 PM   #26
Fire up the BBQ
griz's Avatar
Rewards Points: 1,708
an rfi to change fasteners likely to come back pretty quick....
denied, use fasteners per plan....
griz is online now
The Following 2 Users Say Thank You to griz For This Useful Post:
Calidecks (02-14-2019), EthanB (02-15-2019)
Old 02-24-2019, 01:56 PM   #27
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,364
I've used spacers on a ledger board once, the reason for it was because it was a log cabin. I had to be careful attaching because the top half of the ledger was a wood stud frame with log siding. The bottom half were solid logs. Tearing off siding and using flashing wouldn't have been a good idea because I would have had to maul into a large portion of the solid logs. I could probably do it but it would have taken a long time and would have hacked everything up. I think for a spacer I cut out some pieces of treated wood and dipped them into more wood preservative then used them every 16 inches or so. It drained pretty well without having to tear into the building.
I wouldn't recommend using spacers on regular siding. It's not hard to take a skill saw and cut out a piece of siding then tuck some flashing in there. I worked for a guy once that didn't want to use flashing or spacers. He just had me nail the ledger right to the siding
KennMacMoragh is offline
The Following 2 Users Say Thank You to KennMacMoragh For This Useful Post:
overanalyze (02-24-2019), Patrick Munsell (02-25-2019)
Old 02-26-2019, 05:30 PM   #28
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
I built a lot of decks back in the day with deck to wall spacers and ledgerloks. All these projects were solid wood sidings or T1-11. In most cases, it saved having to tear back the existing siding to properly flash the ledger. I gave the owners the choice and associated pros and cons.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
The Following 5 Users Say Thank You to redwood For This Useful Post:
Calidecks (02-26-2019), EthanB (02-26-2019), hdavis (02-26-2019), KennMacMoragh (03-03-2019), Rio (03-03-2019)
Old 03-03-2019, 01:54 PM   #29
I thought the same thing in the back of my head, those spacers would work really nice on T1-11 siding. I'm still not a fan of doing it this way but you're right we should be more open minded and consider pros and cons when doing these things.
Old 03-07-2019, 01:26 PM   #30
DBoone's Avatar
Trade: Residential Building
Rewards Points: 38
Originally Posted by We Fix Houses View Post
Originally Posted by Rooster Cogburn View Post
This is what we use.No flashing needed.
Bold talk for a one - eyed fat man !
That’s a good one there pawpaw
DBoone is offline
Old 03-09-2019, 12:53 PM   #31
Patrick Munsell's Avatar
Rewards Points: 24
For those that have to be concerned about frost; have you ever had an application when you have made the deck next to the house, but not attached a ledger board, but rather left the deck as a stand alone?
Maybe unusual drainage circumstances, etc.?
Patrick Munsell is offline
Old 03-09-2019, 01:18 PM   #32
Talking Head
EthanB's Avatar
Rewards Points: 434
Fairly common. It's required on older balloon framed homes or on cantilevered second floors which is a common detail on raised ranches. The thing to be careful of is that you can be required to excavate to undisturbed soil on newer homes and that's usually around 8-9' around here.
Planer.....
EthanB is offline
Patrick Munsell (03-09-2019)
