Pros And Cons Of Attaching Ledger Board With Spacers - Decks & Fencing - Contractor Talk
Old 02-09-2019, 02:35 PM   #1
Patrick Munsell's Avatar
Rewards Points: 24
Hey all, I'm familiar with attaching the deck ledger board with either a bolt through or lag, but I've never used spacers behind the ledger.
I've seen others that have done that; why would you use that, and what are the pros and cons?
This is all assuming proper construction, attaching correctly/sufficiently, flashing, etc, etc.
Look forward to your input.
Patrick Munsell is offline
Old 02-09-2019, 04:36 PM   #2
Rooster Cogburn's Avatar
Trade: Master carpenter
Rewards Points: 344
Re: Pros And Cons Of Attaching Ledger Board With Spacers
I have been doing it for several years and leave a gap between the siding and the decking. No flashing involved.
Rooster Cogburn is offline
Old 02-09-2019, 05:37 PM   #3
Rewards Points: 24
Obviously using either lag or bolt to attach, but what do you use for a spacer?Some kind of nylon spacer? How much space?
Doing it this way removes the need for flashing?
What made you decide to go this way, rather than securing to the rim joist with no space?
Thanks for some input.
Old 02-09-2019, 06:01 PM   #4
Tom M's Avatar
Rewards Points: 1,012
The spacer needs to be water tight and you have a little allowance for the gap so cladding thickness won't work much of the time.
Tom M is online now
Old 02-09-2019, 07:30 PM   #5
Rewards Points: 24
Tom M are you saying ("so cladding thickness won't work much of the time.") that you need to keep the gap less than the thickness of the existing cladding?
Do you use anything in particular for the spacers?
Thanks
Old 02-09-2019, 07:42 PM   #6
Rewards Points: 24
I think I had a slight case of "confusion" ; help me out here.
So, is the "Spacer" approach used when you want to go over siding, without removing it?
Old 02-09-2019, 08:10 PM   #7
Tom M's Avatar
I don't use spacers. Most of the homes I deal with are multi layered siding or vinyl so I'm not fluent in the method but I believe the code limits how far beyond the framing you can space. So I imagine you would need a stucco or thin veneer.
Without digging into the code I should reserve my opinion so I don't confuse you.
Tom M is online now
Calidecks (02-13-2019)
Old 02-09-2019, 08:13 PM   #8
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,594
https://www.deck2wallspacer.com/
Steve
We Fix Houses is offline
The Following User Says Thank You to We Fix Houses For This Useful Post:
Sisyphus (02-10-2019)
Old 02-09-2019, 08:27 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 56
I see no advantage to spacing the ledger away from the wall. Either way, you need proper flashing, and the spacing is just extra work.
Tinstaafl is online now
The Following 5 Users Say Thank You to Tinstaafl For This Useful Post:
Calidecks (02-13-2019), CENTERLINE MV (03-09-2019), EthanB (02-09-2019), Irishslave (02-11-2019), mrcat (02-09-2019)
Old 02-09-2019, 08:36 PM   #10
Rewards Points: 24
The link from We Fix Houses for Deck2WallSpacer has a video and it does present an interesting approach. At this point I've only given it a quick glance, but looks interesting.
Bottom line is, we all want to provide a quality product to our customers, efficiently, cost effectively, and that's pleasing to the customer. As is usually the case, there's more than one way to skin a cat.
Old 02-09-2019, 09:40 PM   #11
Talking Head
EthanB's Avatar
Rewards Points: 438
Properly flashing the ledger is the best solution, imo. The spacer systems would not allow for my preferred method of ledger connection which I consider far more important.
Planer.....
EthanB is offline
The Following 2 Users Say Thank You to EthanB For This Useful Post:
mrcat (02-10-2019), Rio (02-10-2019)
Old 02-10-2019, 09:05 AM   #12
Rewards Points: 344
Originally Posted by We Fix Houses View Post
This is what we use.No flashing needed.
The Following 2 Users Say Thank You to Rooster Cogburn For This Useful Post:
KennMacMoragh (02-24-2019), pathbuilder (02-11-2019)
Old 02-10-2019, 01:54 PM   #13
Bold talk for a one - eyed fat man !
Steve
The Following 2 Users Say Thank You to We Fix Houses For This Useful Post:
Rooster Cogburn (02-10-2019), TxElectrician (02-10-2019)
Old 02-11-2019, 04:29 PM   #14
Rewards Points: 24
Thanks everyone for the feedback.
Gives me a little more insight into what my options are.
Old 02-11-2019, 05:29 PM   #15
Designer/Contractor
Rio's Avatar
Rewards Points: 16
Here's something to consider when thinking of using the standoffs when one has to deal with lateral loads...................
File Type: pdf Simpson-Deck lateral load connector-page19.pdf (118.1 KB, 345 views)
Rio is offline
The Following User Says Thank You to Rio For This Useful Post:
Patrick Munsell (02-11-2019)
Old 02-12-2019, 09:07 AM   #16
deckdog's Avatar
Trade: deck builder
Rewards Points: 48
Ledger spacers just bind up vinyl siding. I tried it at a homeowner's request. It created a huge headache for that application. Logic tells me it's better lagged tight with proper flashing. Although I could see it against concrete walls.
DD
deckdog is offline
The Following User Says Thank You to deckdog For This Useful Post:
Patrick Munsell (02-12-2019)
Old 02-12-2019, 11:39 AM   #17
Ed Hartmann's Avatar
Rewards Points: 358
Sometime I will if I don't trust a door or the details around a door to stop all the water. Otherwise good flashing should do the the job.
Ed Hartmann is offline
Old 02-12-2019, 09:33 PM   #18
Talking Head
EthanB's Avatar
Rewards Points: 438
IMO, lags should never be used by anyone, ever again. I've had a bunch of structural engineers agree with me on this(but more still spec them). They are just a PITA and have lower withdrawal values. Structural screws are where it's at.
Planer.....
EthanB is offline
Calidecks (02-14-2019), Patrick Munsell (02-13-2019)
Old 02-13-2019, 08:15 AM   #19
deckdog's Avatar
Trade: deck builder
Rewards Points: 48
I think "Lags" is a generic term used for most structural screws.
DD
deckdog is offline
Justin Rhoades (02-13-2019)
Old 02-13-2019, 08:38 AM   #20
Rewards Points: 24
Here's a pretty good explanation of the differences.
Definitely two different animals.
https://www.brighthubengineering.com...or-lag-screws/
