Post Topping Jig - Decks & Fencing - Contractor Talk
Post Topping Jig
Old 08-19-2012, 11:01 AM   #1
Artisan Carpentry
basswood's Avatar
Trade: trim carpenter
Rewards Points: 1,030
Post Topping Jig
Mostly self explanatory, let me know if you have any questions or comments:
Post Topping Jig-post_cutting_jig1.jpg   Post Topping Jig-post_cutting_jig2.jpg   Post Topping Jig-post_cutting_jig3.jpg
basswood is offline
Old 08-19-2012, 11:30 AM   #2
Kent Whitten's Avatar
Rewards Points: 2,040
Re: Post Topping Jig
I have a comment....I wish you were here every day
You always have good stuff bass.
SalmonFallsCabinetry.com
Kent Whitten is offline
The Following 2 Users Say Thank You to Kent Whitten For This Useful Post:
basswood (08-19-2012), JesseCocozza (08-19-2012)
Old 08-19-2012, 11:37 AM   #3
Tom M's Avatar
Rewards Points: 11,182
Whats going on with that base plate of the saw? Do you have somekind of home made track set up?
Tom M is online now
Old 08-19-2012, 11:41 AM   #4
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 350
With all due respect to Bass...
Is a jig really necessary for that?
Warren is offline
The Following 3 Users Say Thank You to Warren For This Useful Post:
Calidecks (09-04-2012), Dirtywhiteboy (08-19-2012), jamesdc (08-19-2012)
Old 08-19-2012, 11:45 AM   #5
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 362
I've always just used a speed square.
pinwheel is online now
The Following User Says Thank You to pinwheel For This Useful Post:
Old 08-19-2012, 11:49 AM   #6
Tom M's Avatar
I use a speed sq too but then your pulling measurements for the offset and the cut can vary.
Tom M is online now
Tom Struble (08-19-2012)
Old 08-19-2012, 11:56 AM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 1,928
I use a Big Foot or a Beam saw.
griz is online now
The Following 4 Users Say Thank You to griz For This Useful Post:
Dirtywhiteboy (08-19-2012), jamesdc (08-19-2012), JT Wood (08-19-2012), redwood (08-19-2012)
Old 08-19-2012, 11:59 AM   #8
Artisan Carpentry
basswood's Avatar
The saw is set up for a rail (EZ guide)
I made that jig for my 16" Makita beam saw for cutting 6x6's, but I found it works nice for 4x4's too with smaller saws.[YOUTUBE]http://www.youtube.com/watch?v=FzecgPNpsOE[/YOUTUBE]
The benefits are no measuring the offset, zero clearance so less tear out, nice stable infeed and outfeed support, and I can hold the saw with one hand and hold the cut off with the other hand.
I've done that too, but like having the other hand on the saw or to pull the cut off away.
basswood is offline
The Following 2 Users Say Thank You to basswood For This Useful Post:
pinwheel (08-19-2012), Tom M (08-19-2012)
Old 08-19-2012, 12:00 PM   #9
pinwheel's Avatar
Rewards Points: 362
I draw the line where I want the cut & start the cut freehand & move the square to the sawbase. Well, I used to, I don't build decks anymore.
Old 08-19-2012, 12:02 PM   #10
Artisan Carpentry
basswood's Avatar
ALL, the jig is also good for cutting pyramid tops accurately.
I should make a video, the jig is very fast to use. It works well with just one Quick Clamp too.
basswood is offline
Old 08-19-2012, 12:03 PM   #11
Geometrist
Warren's Avatar
Rewards Points: 350
Now that I could see. Pretty much every time a 4x4 is square cut, it gets covered up anyway. When finishing the cut, I switch to one hand, freeing the other hand to grab the chunk.
Warren is offline
Old 08-19-2012, 12:07 PM   #12
Tom M's Avatar
Most of the time 4x4 PT are so twisted that you can draw a square line around each side and find that it dont meet starting point.
I rarely get to do deck either these days but I always framed down. Deck platform on temp supports then butted up my girder and finished with the 4x4 cut on a chop saw.
Tom M is online now
Old 08-19-2012, 12:08 PM   #13
Artisan Carpentry
basswood's Avatar
Yeah, I'm not fond of the kerf binding and the saw kicking right at jugular height.
basswood is offline
Old 08-19-2012, 12:09 PM   #14
pinwheel's Avatar
Rewards Points: 362
I can see where it would work very well for pyramid tops, but just feel it would slow me down having to reclamp of flat tops.
Old 08-19-2012, 12:10 PM   #15
Geometrist
Warren's Avatar
Rewards Points: 350
Yeah, it's an acquired taste. I think as a framer, we cut a lot of big stuff and develop a good sense when things will bind or not. If the cutoff is large, I will usually have someone grab on. Also keeps it from falling on finished areas, or toes!!!
Warren is offline
Old 08-19-2012, 12:18 PM   #16
Artisan Carpentry
basswood's Avatar
It would be a little slower. That happens when you let the trim carpenter out of the house.
I've seen you guys hanging of off ladders plumb cutting rafter tails above yours heads with worm drives. I would need a bucket truck and a jig for that work too!
basswood is offline
The Following User Says Thank You to basswood For This Useful Post:
Old 08-19-2012, 03:47 PM   #17
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
If that is for a fence, we just scribe the line and cut it freehand with the beam saw. Same with arbor posts if they aren't visable after wrapping everything. Deck posts are usually cut with mitersaw or beam saw if they are already erected.
I would like to know how you guys frame your decks from the top down. Most decks I build are around 1000 sq. ft., with angles and 6 - 12ft off the ground. The ground is not always flat either.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 08-19-2012, 05:19 PM   #18
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Mark, I always frame from the top down.
You might not think so but there are some steep hill sides over here and deep water sheds.
It's just a matter of long 2xs , temp braces,and diagonals. Doing this is so much faster. For Me anyway. Doing lower to the ground projects it is many times faster.
Jon Mon www.deckmastersllc.com
John Hyatt is offline
tripple 2x8 beams on 6x6 post lewisthepilgrim Decks & Fencing 33 08-06-2012 02:36 PM
