Post Hole Nightmare - Decks & Fencing - Contractor Talk
Post Hole Nightmare
Old 10-09-2011, 11:49 AM   #1
member
Jer's Avatar
Trade: Siding, windows, Aluminum crown
Rewards Points: 150
Post Hole Nightmare
Trying to install a Sim-Tek vinyl fence (eight foot height) and the post holes need to be 48" depth and 10" diameter. The fence has to be within a foot of a concrete block retaining wall that is apparently designed with some sort of plastic webbing material that is layered between every other row of block and extends out into the newly installed fill dirt which was supposedly road base but is in actuality just crushed rock with a little dirt mixed in. A manual post hole digger would not cut this plastic webbing so we rented a one man power auger which cut through no problem but when the auger is backed out, the hole buries itself.
My son in law is a fence contractor with several years experience and after the two of us wore ourselves to a frazzle digging three holes in eight hours I am at my wits end. We still have 14 holes to go.
Any suggestions would be greatly appreciated.
Jer is offline
Old 10-09-2011, 12:42 PM   #2
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
Re: Post Hole Nightmare
That's a tough one. Sometimes water will help to hold the sides together, but not with rock.
I suspect that you are going to have some very large holes.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
The Following User Says Thank You to redwood For This Useful Post:
Jer (10-11-2011)
Old 10-09-2011, 12:46 PM   #3
mbobbish734's Avatar
Trade: Property Preservation & Remodeling
Get some sona tubes that fit loose over the auger. Start with the tube at ground level with auger. Bore a little down, stop and push the tube down. Auger some more stop push the tube down. Eventually you'll get all the way down and the tube will keeping it from collapsing. Now go dig some holes.
mbobbish734 is offline
The Following 4 Users Say Thank You to mbobbish734 For This Useful Post:
Builderbob 72 (10-10-2011), DavidC (10-10-2011), Jer (10-11-2011), WildWill (10-09-2011)
Old 10-09-2011, 01:25 PM   #4
Ash@OTL's Avatar
Trade: remodeling/ home repair
Rewards Points: 160
The mesh system is called Geogrid. It's used to reinforce the load bearing capacity of the wall. It works by trapping the rock in the mesh thereby relieving stress from the wall.
The Sono tube idea is probably your best bet because you want to displace as little material as possible. I would also try to fill in your first holes as tight as possible. What may happen is the lower level rock is dropping into the hole as you dig creating hollow spots that will sink over time forming low spots on the surface and possible jeopardizing the longevity of your fence Install.
Ash@OTL is offline
The Following User Says Thank You to [email protected] For This Useful Post:
Jer (10-11-2011)
Old 10-09-2011, 05:06 PM   #5
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
we tried this type of thing with the tubes years ago and the digger destroys the tubes. So i went and bought plywood or osb and it worked great.
steve scholl
killerdecks is offline
The Following User Says Thank You to killerdecks For This Useful Post:
Jer (10-11-2011)
Old 10-09-2011, 05:16 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 1,006
Look into Helical Piers.
Look up Greg Di on this site.
He has quite a system.
griz is online now
Jer (10-11-2011)
Old 10-10-2011, 10:29 AM   #7
DavidC
DavidC's Avatar
Rewards Points: 2,006
I was thinking the same thing except with PVC. They use a similar setup for drilling underwater holes for piers.
Good Luck
www.CookContractingLLC.com
DavidC is offline
The Following User Says Thank You to DavidC For This Useful Post:
Jer (10-11-2011)
Old 10-10-2011, 10:44 AM   #8
Sona tubes work. But I used for sandy soil. Rocky may require a more rigid tube. But it will work.
The Following User Says Thank You to mbobbish734 For This Useful Post:
Jer (10-11-2011)
Old 10-11-2011, 08:49 PM   #9
member
Jer's Avatar
Rewards Points: 150
Thanks for all the feedback, it sounds like the sono tube idea is what I should try next. I will let you all know how it turns out.
Jer is offline
Old 10-14-2011, 05:05 PM   #10
Florida GC
olligator's Avatar
Rewards Points: 250
this^^
______________
If you're not a Gator, you're Gatorbait!
olligator is offline
The Following User Says Thank You to olligator For This Useful Post:
Jer (10-16-2011)
Old 10-19-2011, 09:51 AM   #11
member
Jer's Avatar
Rewards Points: 150
Well guys I am happy to finally report that I have my post holes dug thanks to this great advise.
I ended up making sono tubes out of some old vinyl siding I had laying around (needed something tougher than cardboard to cut through the crushed rock)
It was still a chore because of the geo grid webbing. The auger tended to twist through it rather than clear a good hole through it so we had to keep stopping to snip the stuff off where the tubes kept catching on it and as we started to get near the four foot depth the auger kept binding up in the evil stuff. My son in law said these were the worst fourteen holes he has ever worked on in his twelve years of fencing but he was impressed and happy to learn this new trick.
Thanks again to all who offered their input
Jer is offline
The Following User Says Thank You to Jer For This Useful Post:
DavidC (10-19-2011)
Old 10-19-2011, 10:02 AM   #12
Should have put up a couple pics.
post hole digging machines bbgcarpentry Decks & Fencing 36 12-31-2011 02:50 PM
LENOX Contest And Give Away - Everyone Gets A FREE Speed Slot Hole Saw Nathan General Discussion 186 12-29-2011 03:02 PM
post hole digging service bcf General Discussion 9 07-11-2006 09:23 PM
