Plumb Out - Decks & Fencing - Contractor Talk
Plumb Out
Old 01-24-2020, 07:06 PM   #1
Dazed and Confused
SnortinMort's Avatar
Trade: Carpentry/Handyman
Rewards Points: 24
Plumb Out
I have an exterior wall buckling outward just between the top of the sill (foundation) and the bottom of the stud wall (bottom plate). Pier and beam foundation built in the '30s, single story. It is bowing out approximately the width of itself.
Whats the trick to get it plumb over the foundation?
TIA...
Wally
SnortinMort is offline
Old 01-24-2020, 07:12 PM   #2
TimNJ's Avatar
Rewards Points: 6,814
Re: Plumb Out
Photos??
TimNJ is offline
Old 01-24-2020, 07:31 PM   #3
Dazed and Confused
Rewards Points: 24
Re: Plumb Out
Sorry... it's not happening for me. I guess I'm going to have to go to another form to learn how to upload
Old 01-24-2020, 07:31 PM   #4
Dazed and Confused
Rewards Points: 24
Re: Plumb Out
And there you go
Old 01-24-2020, 08:20 PM   #5
Tom M's Avatar
Rewards Points: 11,138
Re: Plumb Out
Snorting Mort is dazed and confused
Tom M is offline
The Following 2 Users Say Thank You to Tom M For This Useful Post:
Calidecks (01-24-2020), SnortinMort (01-24-2020)
Old 01-24-2020, 08:23 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 1,808
Re: Plumb Out
can't even tell what i'm looking at...
griz is offline
Old 01-24-2020, 08:36 PM   #7
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
Re: Plumb Out
He's got a hydraulic jack sideways trying to push the wall in. I don't think it will work
Irishslave is offline
The Following User Says Thank You to Irishslave For This Useful Post:
Old 01-24-2020, 08:40 PM   #8
Mordekyle's Avatar
Rewards Points: 5,972
Re: Plumb Out
I wonder if you have to remove the lowest course of siding.
And then run a blade under the plate to snip off any nails or bolts in the area.
Mordekyle is offline
The Following User Says Thank You to Mordekyle For This Useful Post:
Old 01-24-2020, 08:49 PM   #9
Stunt Carpenter's Avatar
Rewards Points: 2,738
Re: Plumb Out
If you have a crawl space I find a chain come along pulling works better than pushing with a bottle jack. Less likely to pop out under strain
https://builddaley.com/
Stunt Carpenter is offline
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
Old 01-24-2020, 08:55 PM   #10
Dazed and Confused
Rewards Points: 24
Re: Plumb Out
Great ideas guys.... yes I also have 2 tie down straps on the inside: one end wrapped around a post holding up a beam centrally located on the interior of the house, and the opposing ends wrapped around a couple of wall studs on the exterior wall just above the bottom plate where the bulge
is worst. So I am pulling it from the inside somewhat as well .
But honestly I didn't think about cutting all the bent nails and **** out first before I tried to move it back. That would make sense.
Old 01-24-2020, 08:58 PM   #11
Dazed and Confused
Rewards Points: 24
Re: Plumb Out
And I have gotten it to move about 2in, I'm just not comfortable with that and would like to go a little more.
Old 01-24-2020, 09:03 PM   #12
Dazed and Confused
Rewards Points: 24
Re: Plumb Out
Preshate yall.
The Following User Says Thank You to SnortinMort For This Useful Post:
Mordekyle (01-26-2020)
Old 01-24-2020, 09:13 PM   #13
TimNJ's Avatar
Re: Plumb Out
You need to find out why the rim joist failed to begin with.
TimNJ is offline
The Following 3 Users Say Thank You to TimNJ For This Useful Post:
AustinDB (01-25-2020), griz (01-24-2020), Seven-Delta-FortyOne (01-24-2020)
Old 01-24-2020, 09:18 PM   #14
Fire up the BBQ
griz's Avatar
Re: Plumb Out
seems like it may involve a tad bit more than pushing or pulling...
griz is offline
Old 01-24-2020, 09:31 PM   #15
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,570
Re: Plumb Out
I was gonna say, I'd want to find out why it failed to begin with, before I developed a remediation plan.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Calidecks (01-24-2020), Rio (01-25-2020), ScipioAfricanus (01-25-2020)
Old 01-24-2020, 10:12 PM   #16
tgeb's Avatar
Rewards Points: 828
Re: Plumb Out
Is that asbestos siding?
It looks similar, but can't tell from the photo.
Probably nothing to be concerned about.
Carry on.
Sent from my SM-G970U using Tapatalk
www.gebcon.com
tgeb is offline
Old 01-25-2020, 12:18 AM   #17
AustinDB's Avatar
Rewards Points: 1,532
Re: Plumb Out
Termites and water damage (rot) has contributed to the examples of odd things like what you have going on.
Peel off the siding and then jack up the top of that wall will make it easier to pull in.
Rotted/termite damaged framing will need to be repaired.
AustinDB is offline
Old 01-25-2020, 12:34 PM   #18
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 1,032
Re: Plumb Out
Do they have termite in Texas?
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
Old 01-25-2020, 12:35 PM   #19
Re: Plumb Out
Never mind. I looked it up. Carry on!
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
AustinDB (01-26-2020)
Old 01-25-2020, 12:41 PM   #20
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,873
Re: Plumb Out
Will work if his mother in law is sitting in a lawn chair on the other end of that 4 x 4, to keep if from backing up.
rescraft is offline
