Notching Girder Into 6x6 Post - Page 2 - Decks & Fencing - Contractor Talk
Old 07-10-2015, 11:54 PM   #21
Designer/Contractor
Rio's Avatar
Rewards Points: 778
Re: Notching Girder Into 6x6 Post
put through bolts from the girder to the posts and put knees on the post to girder assembly.
Rio is online now
Old 07-10-2015, 11:55 PM   #22
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
it aint legal in cali
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
The Following User Says Thank You to parkers5150 For This Useful Post:
Calidecks (07-10-2015)
Old 07-10-2015, 11:59 PM   #23
GC/carpenter
Calidecks's Avatar
Rewards Points: 6,172
ganja?
Calidecks is online now
Old 07-11-2015, 06:37 AM   #24
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Originally Posted by Tom M View Post
I dont know why people avoid hanging the beams with brackets in between the posts.
I agree
Looks like previous builder built the decks after the 6x6 post were set, then notched in girders.
He could of used concealed flange hangers between post
festerized is offline
The Following User Says Thank You to festerized For This Useful Post:
Tom M (07-11-2015)
Old 07-11-2015, 08:13 AM   #25
David Festa
festerized's Avatar
Originally Posted by Californiadecks View Post
Just for giggles can someone tell me what kind of load a Simpson HUC412 or 414 can carry?
Calidecks (07-11-2015)
Old 07-11-2015, 08:34 AM   #26
Tom M's Avatar
Rewards Points: 9,412
Through bolting single joists acting like beams on each side of the post used to be pretty common too.
Tom M is online now
Old 07-11-2015, 06:48 PM   #27
always building
ganja?
depends on who's knocking at your door.
www.RDPontheWeb.com
Old 07-11-2015, 07:04 PM   #28
TG Deck's Avatar
Trade: exterior carpentry
Rewards Points: 1,770
Sandwiching and thru-bolting beams to posts is still common for low under beam decks, too...to the wrath of 'engineers'.
TG Deck is offline
Old 07-11-2015, 07:28 PM   #29
deck aficionado
SelectDecks's Avatar
Trade: General Building
Rewards Points: 973
Doesn't make it right
James
www.selectdecks.com
SelectDecks is offline
Old 07-11-2015, 07:53 PM   #30
TG Deck's Avatar
Who is your boss?
Simpson said you need to do it differently...
Why in the world would they say such a thing?
Oh....yeah, that's it.......
The shear of two 5/8 galv thru-bolts is weaker that that flimsy-ass column cap over a #2 4x4 which provides laughable lateral support?
OK...
TG Deck is offline
Old 07-11-2015, 07:59 PM   #31
GC/carpenter
Calidecks's Avatar
Originally Posted by TG Deck View Post
Who is your boss?
OK...
It's not the bolt that's going to break/shear. It's the 2x that will split on the bolt. A beam that's bearing on a post in a Simpson or any bracket for that matter is much safer. What happens is the sandwiched 2x rots and all hell breaks loose. Literally!
EthanB (07-12-2015)
Old 07-11-2015, 08:09 PM   #32
SamM's Avatar
Trade: Carpenter/Handyman
Rewards Points: 1,484
I've seen the same thing done in a 4x4.
It's not something I would do or recommend. Though in old homes I've seen the builders cut a notch and put a 16 in then put the 2nd floor joists on them. Most of those homes are 125+ and there's no crush damage to the notches or 1x. way less load though.
Your Dreams won't work unless you do.
SamM is offline
Old 07-11-2015, 08:20 PM   #33
TG Deck's Avatar
Eventually...the entire freaking thing rots. Duh...
I said low level decks.
That 2x6 doesn't 'spilt' across the grain.
Push sideways on a beam bolted until it's broken, and then push sideways on a capped bracketed beam.
The comparison is not even close.
The 'engineering' statement reads something like...'in cases where substandard coated fasteners 'could' be used...so it not allowed....for every builder...by code.
Tell where I'm wrong.
TG Deck is offline
Old 07-11-2015, 08:28 PM   #34
Tom M's Avatar
Besides splitting potential I would not consider a single dimensional framing member a beam. With one on each of a column one does all the work.
You could overcome the shear on the bolts with scabs and more bolts
Tom M is online now
Old 07-11-2015, 08:37 PM   #35
TG Deck's Avatar
Of course...when you sandwich you have 2 and load is spread over the shear of both, not one.
What seems to be not considered is posts running up thru the deck, also sandwiched by 2x joists above, and those posts are railing posts.
You would need a tractor to push that down.
TG Deck is offline
Old 07-11-2015, 08:38 PM   #36
GC/carpenter
Calidecks's Avatar
If it's not a good idea on high level decks why would it be a good idea on any level deck? Duh. It's unacceptable, period
Old 07-11-2015, 08:50 PM   #37
GC/carpenter
Calidecks's Avatar
Here's a whole thread on it
http://www.contractortalk.com/f50/de...estion-114868/
Old 07-11-2015, 09:12 PM   #38
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
Totally wrong connection.
Having done some Timber Framing, the Beams should be coming into the post from the side and in to a housed connection. A splined, or "loose tenon" could be used there.
Not certain if this meets Code since my code book is Canadian, but this is not something I would do on a two story deck as displayed.
jlhaslip is offline
The Following 2 Users Say Thank You to jlhaslip For This Useful Post:
Calidecks (07-11-2015), hdavis (07-21-2015)
Old 07-19-2015, 09:59 PM   #39
Designer/Contractor
Rio's Avatar
Rewards Points: 778
1x let-in ribbon ledgers are very common with balloon framing and are a time tested, very safe way to carry floor joist loads.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
Calidecks (07-19-2015)
Old 07-20-2015, 06:52 PM   #40
TG Deck's Avatar
Sure, but if Simpson isn't in the chain, the engineers won't get their backdoor perks.
TG Deck is offline
Exterior Wood Post to Concrete bwiab Construction 4 04-11-2013 11:06 PM
