Notching Girder Into 6x6 Post - Decks & Fencing - Contractor Talk
Old 07-10-2015, 02:29 PM   #1
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Looked at project today, previous builder got the boot
Is this legal?
Notching girder into 6x6 post-photo-jul-10-11-27-30-am.jpg   Notching girder into 6x6 post-photo-jul-10-11-26-46-am.jpg
festerized is offline
Old 07-10-2015, 03:14 PM   #2
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
Re: Notching Girder Into 6x6 Post
Oh man.... doesn't doing something like that weaken the load capacity of the 6" x 6" ???
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
Old 07-10-2015, 05:31 PM   #3
David Festa
festerized's Avatar
Thereís plenty of meat left over on the 6x6 so I donít see a major problem there unless the load decides to shift to the outside of the girder, the floor beams on both levels are flush so I donít see the girder rolling.
What Iím concerned about is the 2Ē bearing, over time the weight will compress on the small point load causing the girder to split, the notch could end up splitting too
The Following User Says Thank You to festerized For This Useful Post:
hdavis (07-10-2015)
Old 07-10-2015, 05:36 PM   #4
hdavis's Avatar
Rewards Points: 4,930
Notching posts for decks is standard. The big question is whether the connections have to be engineered - for everything I've done, they would be. There isn't a prescriptive solution I'm aware of.
hdavis is online now
Old 07-10-2015, 07:10 PM   #5
deckman22's Avatar
Trade: Retired Deck Builder
Rewards Points: 2,688
Notch isn't deep enough, and yea it's legal long as the connection is done right.
Deckman
deckman22 is online now
Old 07-10-2015, 07:11 PM   #6
TG Deck's Avatar
Trade: exterior carpentry
Rewards Points: 1,770
....There isn't a prescriptive solution I'm aware of..........................
That's a nice statement, and quotable...
I recently had one 'engineered' for triple 2x6's over 6x6 posts.
The 'engineer' wanted one of the 3 to hang off (2 perched on the top) and bolt the triple to the notched 6x6.
Ok...
Original draft was 25 footers and I took him down to 16 with modifications.
TG Deck is offline
The Following User Says Thank You to TG Deck For This Useful Post:
hdavis (07-10-2015)
Old 07-10-2015, 09:18 PM   #7
GC/carpenter
Calidecks's Avatar
Rewards Points: 21,324
Doesn't a post hold something like 500 lbs per square inch? So taking a notch out of them lessens sq inches. Where am I wrong?
Calidecks is online now
Old 07-10-2015, 09:23 PM   #8
Tom M's Avatar
Rewards Points: 4,346
I dont know why people avoid hanging the beams with brackets in between the posts.
Tom M is online now
John Hyatt (07-11-2015)
Old 07-10-2015, 10:28 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,599
Maybe because there's an instinctive recognition that a crappy piece of bent sheet metal won't hold up nearly as well as a beefy chunk of wood?
Tinstaafl is offline
JAH (07-11-2015)
Old 07-10-2015, 10:42 PM   #10
GC/carpenter
Calidecks's Avatar
Then half the deck is being supported be SDS screws?
Old 07-10-2015, 10:45 PM   #11
GC/carpenter
Calidecks's Avatar
Is this legal?
Those step risers look to be taller than 7-3/4" too.
Old 07-10-2015, 10:54 PM   #12
deck aficionado
SelectDecks's Avatar
Trade: General Building
Rewards Points: 973
Wha...wha...what??
James
www.selectdecks.com
SelectDecks is offline
Old 07-10-2015, 10:55 PM   #13
deck aficionado
Rewards Points: 973
Maybe 10d hanger nails
James
www.selectdecks.com
The Following User Says Thank You to SelectDecks For This Useful Post:
Calidecks (07-10-2015)
Old 07-10-2015, 11:00 PM   #14
GC/carpenter
Calidecks's Avatar
I said sds giving him the benefit of the doubt. But you're right, some hangers are only nailed.
Old 07-10-2015, 11:11 PM   #15
GC/carpenter
Calidecks's Avatar
Just for giggles can someone tell me what kind of load a Simpson HUC412 or 414 can carry?
Old 07-10-2015, 11:21 PM   #16
Tom M's Avatar
They make heavy duty hangers. Im sure if I get out that simpson book I can find some serious concealed hangers. Painted black is not horrible.
I agree beefy wood looks better specially if its going to be the finished piece.
Tom M is online now
Old 07-10-2015, 11:22 PM   #17
GC/carpenter
Calidecks's Avatar
I think they are rated for like 8000 lbs each. I'm too lazy to search
Old 07-10-2015, 11:26 PM   #18
hdavis's Avatar
Old 07-10-2015, 11:27 PM   #19
Tom M's Avatar
On these porches the tributary loading is minimal Im sure they exceed the code.
Tom M is online now
Old 07-10-2015, 11:38 PM   #20
Talking Head
EthanB's Avatar
Rewards Points: 310
Notching isn't a problem but not bearing the whole beam on the post is. You could probably meet minimum requirements by adding a deck joist tie at each post and through bolting them. I recently built a beam and decided to add a third ply and that is what I did. We met code with a two ply beam but I decided to beef it up, after the fact.
The ties are only rated for a little over 1k lbs per but it looks like you only have about 100 sf or so bearing on the beam so that adds 36 lbs to the design load.
Planer.....
EthanB is offline
Exterior Wood Post to Concrete bwiab Construction 4 04-11-2013 11:06 PM
