Nicks Deck Rebuild - Page 3 - Decks & Fencing - Contractor Talk
Nicks Deck Rebuild
Old 07-23-2011, 04:28 PM   #41
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
Re: Nicks Deck Rebuild
you're going to tyvek the joists but leave an untreated, not flashed ledger against masonry??...
Dealing with the masonry wall, it would be a good idea to remove the ledger, and replace with PT spaced away from the wall for drainage, or grind out the mortar joint and install a 'Z' flashing at least...
Maybe the original ledger was in good shape, but that approach to remodeling is a bad habit to get into!!
Sometimes it's permissible to reuse existing structure....most often it's laziness or cutting a corner..... If you take pride in your work, stuff like that makes you feel dirty inside.
IMPO...Tear it off replace and flash correctly!
WNYcarpenter is offline
The Following 2 Users Say Thank You to WNYcarpenter For This Useful Post:
jkfox624 (07-25-2011), loneframer (07-23-2011)
Old 07-23-2011, 04:31 PM   #42
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
flash it? why would i flash it when i could just use spacers
it is treated
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 07-23-2011, 04:48 PM   #43
wannabe
Trade: carpentry
The point is, it's easy to just leave the untreated ledger....I deal with this situation almost daily.
You're not just replacing what was there, you're solving any and all problems that may exist....as long as you're there you should do it right! Leaving the ledger as is isn't a good practice!
The only time we leave questionable structure is if the fix would require a whole house remodel!
Believe me, it is easy to get in the habit of taking short cuts.....this is the perfect example of what separates the quality of contractors!
The Following User Says Thank You to WNYcarpenter For This Useful Post:
woodworkbykirk (07-23-2011)
Old 07-23-2011, 04:55 PM   #44
Forming and Framing
FramingPro's Avatar
its treated and in perfect shape. i will add bolts and drill out some holes in the spacer but it is level, straight, I will treat it with some sealer and oil
Old 07-23-2011, 05:32 PM   #45
Custom Builder
Chris@Sunrise's Avatar
Rewards Points: 502
If its TREATED and SPACED as nick said why would he remove it?
Looks like it is in perfect shape. Im with nick if the existing treated ledger is in the shape it appears like it is in the pictures, I would add a few lags and flash it and move on. Theres no reason to beat a dead horse here by doing more work replacing a perfectly good piece of lumber with the same thing.
Chris@Sunrise is offline
The Following 5 Users Say Thank You to [email protected] For This Useful Post:
aptpupil (07-25-2011), Dirtywhiteboy (07-23-2011), Framer53 (07-23-2011), FramingPro (07-23-2011), Kent Whitten (07-23-2011)
Old 07-24-2011, 07:16 AM   #46
Forming and Framing
FramingPro's Avatar
it may be cedar. everything else was, but still its rot free and is covered under my overhang. I willl lag it more
Old 07-24-2011, 07:27 AM   #47
Kent Whitten's Avatar
Rewards Points: 2,040
Cedar framing?
Kind of looks like it though. Cedar is not very good for ledgers if it is. Maybe someone will prove me wrong. Good for rot resistance, yes. Good structurally, no.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 07-24-2011, 07:36 AM   #48
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
That ledger may or may not be solid and structurally sound, but it's kind of like re-using step flashings when ripping and replacing a roof, IMO.
I doubt it will have a remaining service life equivalent to the new deck framing.
For 20-30 bucks worth of new lumber and an hour or two of work, it's not worth the risk of leaving to build on top of with a couple thousand dollars worth of new material.
loneframer is offline
The Following 7 Users Say Thank You to loneframer For This Useful Post:
Dirtywhiteboy (07-24-2011), fourcornerhome (08-03-2011), FramingPro (07-24-2011), Timster (09-04-2011), Tinstaafl (07-24-2011), Tom Struble (07-24-2011), WNYcarpenter (07-26-2011)
Old 07-24-2011, 08:16 AM   #49
Solid advice bro.
Old 07-24-2011, 08:18 AM   #50
Tom M's Avatar
Rewards Points: 13,116
How about ledging over the existing? Not that you need it but double the strength. The old joists were just toe nailed over that one. Were you going to it that way again?
Tom M is online now
Old 07-24-2011, 08:22 AM   #51
Forming and Framing
FramingPro's Avatar
thats what i will do, i will toenail to existing and ontop i will add one and use pressure blocks.
Old 07-24-2011, 09:20 PM   #52
Forming and Framing
FramingPro's Avatar
i laid out my pier locations and stuff. and set batterboards i got it within a 1/4" in 24' . not bad.
I will dig holes tommorow, with a hand auger
Old 07-24-2011, 10:33 PM   #53
Custom Builder
Rewards Points: 502
That makes alot of sense to. Id have to really see it to tell if Id leave it or replace it. If it was perfectly fine I would leave it there though. Ive yet to ever see a deck ledger in like new condition on a rebuild though.
Old 07-25-2011, 08:08 PM   #54
Forming and Framing
FramingPro's Avatar
later in the week we will rent a auger from HD and drill holes.
Do you think 8" tubes would be ok. 6x6 post and 2x8 beams spanning 5'-3"
We will borrow our friends trailer and go to the cheap framer lumberyard and buy 1 of each thing we need for the deck, then on the bill we will have cheap prices and HD will beat it by 10%
Old 07-25-2011, 08:35 PM   #55
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
the kids got game
Tom Struble is offline
Old 07-25-2011, 08:50 PM   #56
jeffatsquan's Avatar
Trade: builder/renovator,Squam Lake NH
Rewards Points: 250
Nick draw an 8" circle then draw a 5.5" square in side of it.
let us know what you come up with
jeffatsquan is offline
Old 07-25-2011, 08:57 PM   #57
Forming and Framing
FramingPro's Avatar
i looked in the store, i would have to be right on, while the rebar is only in the centre i may be better off having some play and assured full bearing
Old 07-25-2011, 09:20 PM   #58
Rewards Points: 250
Yes, and it just looks better to have a revel between the post and pier.
Now that I have your atention consider notching the top of your post for your 2x8 not 3" but an 1.5" from each side this will space your 2x8's about 2.5" apart better for leting things dry out.
you say a 5-3 span so plenty strong block that space at the center point and add a 45* brace back to each post the block and brace being the same 2.5" nailing the 2x8's from both sides.
You can through bolt your 2x8's to your post and if you really want i to look sweet only notch your 2x8's in 1-3/8" that way the roundness on the edge of your 2x8 is proud of your post it's a better look that takes no extra time.
Old 07-25-2011, 09:23 PM   #59
Forming and Framing
FramingPro's Avatar
of course i will notch it. i will not bolt it, just nail. Ill keep that in mind while i notch
Old 07-25-2011, 09:42 PM   #60
RhodesHardwood's Avatar
Trade: Hardwood Floors
Rewards Points: 594
Nice. Look forward to seeing it finished.
RhodesHardwood is offline
Ipe deck Clemens Decks & Fencing 64 06-20-2017 11:13 PM
Tips for an outdoor deck tile install Oldsarge Tiling 8 01-30-2011 04:08 PM
Whats The most expensive deck you've built deck king Decks & Fencing 96 07-10-2010 08:02 PM
Trex Deck damage ?'s Celtic General Discussion 15 11-02-2009 07:45 PM
Winter Deck in Montral mat casters General Discussion 3 10-19-2009 06:19 PM
