Nicks Deck Rebuild - Page 16 - Decks & Fencing - Contractor Talk
Nicks Deck Rebuild
Old 08-23-2011, 09:40 PM   #301
mike86's Avatar
Rewards Points: 75
Re: Nicks Deck Rebuild
Originally Posted by FramingPro View Post
no need to get upset, i too hate when people pass something up as easy when they are doing simple ****, by no means do i think what i am doing complex, i do find it easy but it requires nearly no thought in my case, because it is so simple
You have a lot to learn
mike86 is offline
The Following User Says Thank You to mike86 For This Useful Post:
JT Wood (08-23-2011)
Old 08-23-2011, 10:06 PM   #302
mike86's Avatar
Rewards Points: 75
What a great day,
Threw my posts and beams up this morning, with the notches, endcoat everything. My notches were right on, and the beam is level and the posts are plumb. I used a string to align them in the saddles, I made a decorative mitre on the end of the beam. And by 11 i was plumbing and lining. I laid out my joists so that my butt joints land in the centre of that space, so the joists do not rot due to the dirt and water collection over one. I made like a fetus and i headed out an opening for the clean out. Tommorow i will finish the joists, block, cut the ends and do rim. And then ? decking railings stairs im not sure,
In the fourth picture from the top your beam is looking a little funky,I hope you put a string on it before you nailed your joists.
mike86 is offline
Old 08-23-2011, 10:11 PM   #303
Dirtywhiteboy's Avatar
Rewards Points: 1,600
Originally Posted by Redliz75 View Post
. Next you need to build your own sawhorses, using brackets is cheating!
Liz beat me to it
Originally Posted by Warren View Post
What is the height from the deck to the bottom of the door? Are you going to need a step?? Please say No!
Here where i live you can not have a step at a door
Your project looks great!
Dirtywhiteboy is offline
Old 08-24-2011, 02:54 AM   #304
jeffatsquan's Avatar
Trade: builder/renovator,Squam Lake NH
Rewards Points: 250
Originally Posted by jeffatsquan View Post
Yes, and it just looks better to have a revel between the post and pier.
Now that I have your atention consider notching the top of your post for your 2x8 not 3" but an 1.5" from each side this will space your 2x8's about 2.5" apart better for leting things dry out.
you say a 5-3 span so plenty strong block that space at the center point and add a 45* brace back to each post the block and brace being the same 2.5" nailing the 2x8's from both sides.
You can through bolt your 2x8's to your post and if you really want i to look sweet only notch your 2x8's in 1-3/8" that way the roundness on the edge of your 2x8 is proud of your post it's a better look that takes no extra time.
Wheres the blocks and braces -don't cut corners now
jeffatsquan is offline
Old 08-24-2011, 06:18 AM   #305
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
nick, your beam should have been laminated and sitting on the posts or do a 2 ply and have 1ply let into the beam, by doing it the latter you can have a flush beam where the joists hang off it instead of bearing
woodworkbykirk is offline
Old 08-24-2011, 07:04 AM   #306
Forming and Framing
FramingPro's Avatar
Trade: Shell builder
Rewards Points: 3,582
i did, that was pre plumb and line
Im after fortune and frame
http://www.proicf.com
FramingPro is offline
Old 08-24-2011, 07:04 AM   #307
Forming and Framing
FramingPro's Avatar
no im just saying i don't really need to think much on this one, its just pretty much 16" centres and nailing
Old 08-24-2011, 06:56 PM   #308
Forming and Framing
FramingPro's Avatar
i blocked the beam, and today i blocked the joists at the ledger, i threw on some temp decking and wow that was a stiff floor, im not used to seeing it so level and perfect.
Old 08-24-2011, 07:00 PM   #309
Forming and Framing
FramingPro's Avatar
Originally Posted by WarnerConstInc. View Post
It only took him 15 pages before he got something started.
its not like ive been building it for that long. I just made the thread early thinking it would go faster, if you were working for my dad you would see how it is, the project has completely stopped now, for no reason. stop and start x 20 adds up time
Old 08-24-2011, 08:14 PM   #310
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
My credability is shot. I wish I would have never responded to this.
knucklehead is offline
Old 08-24-2011, 08:27 PM   #311
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,562
And you spelled credibility wrong..
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
The Following User Says Thank You to JT Wood For This Useful Post:
Tom Struble (08-25-2011)
Old 08-24-2011, 08:37 PM   #312
You new what I meant.
The Following User Says Thank You to knucklehead For This Useful Post:
JT Wood (08-24-2011)
Old 08-24-2011, 08:54 PM   #313
Forming and Framing
FramingPro's Avatar
what do you mean, how has this thread gone so ****y, its a deck i posted the topic a long time ago, i didnt start for while looks like im taking a long time, i don't think im some hot **** because i can build a rectangle.
the end
Old 08-24-2011, 09:09 PM   #314
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Nick is grumpy tonight.....
ohiohomedoctor is offline
Old 08-24-2011, 09:09 PM   #315
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 1,232
TxElectrician is online now
The Following User Says Thank You to TxElectrician For This Useful Post:
Old 08-24-2011, 09:10 PM   #316
Forming and Framing
FramingPro's Avatar
no look im just trying to clear things up, i don't want any misconceptions ok
Old 08-24-2011, 09:16 PM   #317
Where's the pics I wanted new pics
Old 08-24-2011, 09:22 PM   #318
the end
Let it all out.
I was talkin to hugh
sorry
Old 08-24-2011, 09:36 PM   #319
mike86's Avatar
Rewards Points: 75
the end
So after this deck are you only going to build round decks because the rectangle ones are beneath you
I should point out that I'm just kidding,your doing a good job.
mike86 is offline
FramingPro (08-25-2011)
Old 08-25-2011, 07:34 AM   #320
Forming and Framing
FramingPro's Avatar
ok, well i could not tell over the computer
sorry
Ipe deck Clemens Decks & Fencing 64 06-20-2017 11:13 PM
Tips for an outdoor deck tile install Oldsarge Tiling 8 01-30-2011 04:08 PM
Whats The most expensive deck you've built deck king Decks & Fencing 96 07-10-2010 08:02 PM
Trex Deck damage ?'s Celtic General Discussion 15 11-02-2009 07:45 PM
Winter Deck in Montral mat casters General Discussion 3 10-19-2009 06:19 PM
