Need Design Ideas For Trex Decking Panels - Decks & Fencing - Contractor Talk
Old 03-16-2019, 10:17 AM   #1
test
cedarboarder's Avatar
Trade: General
Rewards Points: 817
Any one ever make deck panels out of trex?
I have a client that has some rotting 4 foot sqaure cedar deck panels.
these are on top of a vinyl decking that drains half ass. We are going to switch to trex.
Any suggestions on what to use for sleepers.
Will Trex be rigid enough to pick up the panels? just make the panels smaller?
I havnt used any trex in 4 years.
havnt been my self lately and don't normally have trouble designing. Was a really bad week and could use some help.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Old 03-17-2019, 02:49 PM   #2
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,642
Re: Need Design Ideas For Trex Decking Panels
Pictures?
Mike.
_______________
Calidecks is offline
Old 03-17-2019, 02:50 PM   #3
GC/carpenter
Calidecks's Avatar
I've built a complete outdoor shower using Trex. Still in prefect shape.
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
cedarboarder (03-18-2019), greg24k (03-25-2019)
Old 03-17-2019, 04:34 PM   #4
Radical Basement Dweller
Robie's Avatar
Rewards Points: 1,142
Mike.
_______________
Yup...ditto.
Used the boards vertically and did a shadow box configuration.
It was a hit.
“A great civilization is not conquered from without until it has destroyed itself within”
― Will Durant
Robie is offline
The Following 3 Users Say Thank You to Robie For This Useful Post:
Calidecks (03-17-2019), cedarboarder (03-18-2019), greg24k (03-25-2019)
Old 03-17-2019, 05:33 PM   #5
Tom M's Avatar
Rewards Points: 12,628
"On top of vinyl decking" ?????? hmmmm trex is certain ridgid enough to make panels and durable enough to last. Attaching it to sleepers is another story. I think the trex will outlast the pressure treated sleeper......but people update before things decompose
Tom M is offline
Old 03-18-2019, 03:27 AM   #6
test
Trade: General
Rewards Points: 817
Pictures?
Mike.
_______________
I got some on my Google drive I'll dig um up. Its a loyal customer ive had for 10 years so I didn't take any recently.
The Following User Says Thank You to cedarboarder For This Useful Post:
Calidecks (03-18-2019)
Old 03-18-2019, 03:40 AM   #7
test
Trade: General
Rewards Points: 817
correction not vinyl decking. Vinyl water proof membrane.
Old 03-24-2019, 05:03 PM   #8
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 2,780
That would be I. It's my modular system.
Sent from my E6810 using Tapatalk
CityDecks is offline
Old 03-24-2019, 05:04 PM   #9
CityDecks's Avatar
Trade: Deck Builder
Is this for roof? What's the application? I have few ways to do it even rail attachment... Do it quite regularly
The Following 2 Users Say Thank You to CityDecks For This Useful Post:
Calidecks (03-24-2019), greg24k (03-25-2019)
Old 03-24-2019, 05:27 PM   #10
CityDecks's Avatar
Trade: Deck Builder
Just read further up the Post.? Is there existing railings attached to parapet or Deck? I would Skip and install with pedistals they go down as far as 1". Any thing below you add on of rubber or something they also have shims for below an 1". Just need to how Railings work on this and give rest of details and pics. Post a pic if you have
Old 03-24-2019, 10:20 PM   #11
GC/carpenter
Calidecks's Avatar
City is definitely the man for this application.
Mike.
_______________
Old 03-25-2019, 11:30 PM   #12
test
Trade: General
Rewards Points: 817
only pic I could find on Google drive. loading might have failed. So the top deck that is opened up in the picture was finished 2 years ago by me. whole other story haha.
The lower deck the posts are fastened to the outside of the parapet. has a slope to the pvc drains in the center of the deck . not over living space, just 2 car ports.
Old 03-26-2019, 05:18 AM   #13
CityDecks's Avatar
Trade: Deck Builder
It appears railings are non issue ... Yes ?
Any thoughts on ipe panels I get 2*4 and install them over framing 2' of DBL'd joist. For real structural and easy access m you lay out in brick pattern pargue straight etc.. Never rot and you don't have to to assemble a dam thing. You can pre drill and attach directly to framing.
Or make Trex on 2*4 framing 16' oc. Attachment is fussy because you have framing to go to and it 4 1/2 to framing. That's why I install the home made panels typically over pedistals and screw them latterly as being assembled for lateral strength and add 4*6 blocking for top Mount Rails. That creates a super strong grig. Same thing on ipe panels in rails are needed. If you can trash the framing and helk Bent on Trex do the pedistals and wrapping perimeter with facia to keep secure band only screw the perimeter panels. That you still maintain integrity in a semi grid and keep easy access for roof service.
2*4 ipe DBL to create 4*4
The Following User Says Thank You to CityDecks For This Useful Post:
cedarboarder (03-26-2019)
Old 03-26-2019, 05:21 AM   #14
CityDecks's Avatar
Trade: Deck Builder
Another shot
Or make Trex on 2*4 framing 16' oc. Attachment is fussy because you have framing to go to and it 4 1/2 to framing. That's why I install the home made panels typically over pedistals and screw them latterly as being assembled for lateral strength and add 4*6 blocking for top Mount Rails. That creates a super strong grig. Same thing on ipe panels in rails are needed. If you can trash the framing and helk Bent on Trex do the pedistals and wrapping perimeter with facia to keep secure band only screw the perimeter panels. That you still maintain integrity in a semi grid and keep easy access for roof service. 2*4 ipe DBL to create 4*4
Old 03-26-2019, 12:33 PM   #15
test
Trade: General
Rewards Points: 817
Correct railings don't need to be removed.
The slope isn't great, 2 inches at most, but does the job.
ipe panels sound ideal but the client doest want to ever stain.
I might have been over thinking the use of trex as sleepers. Pressure treated sleepers should last a while. Give another coat of preservative and even better.
Old 03-26-2019, 12:36 PM   #16
CityDecks's Avatar
Trade: Deck Builder
Another shot
You don't stain/ seal IPE. Let mother nature do her thing and let silver out. Eventually depending on environment it may start to blacken. Relax it's just dirt. Brush on Occi cleaner and Rinse off if it's bad break out the power washer.
Old 03-26-2019, 12:38 PM   #17
CityDecks's Avatar
Trade: Deck Builder
This is 5yrs of doing nothing. And my City is filthy.
Another shot
Old 03-26-2019, 12:57 PM   #18
test
Trade: General
Rewards Points: 817
well hot damn my client is going to be happy. He really likes the natual look of wood, but for some reason he doesn't like writing a check for stain and seal every couple years.. haha
I tried selling him on Trex panels for the top deck but he didn't like the look of them.
This ipe will give the look he wants, and with out the hassle of up keep. In the long run I can see the investment paying off vs cutting checks every couple years.
Thanks.
Old 03-26-2019, 12:59 PM   #19
CityDecks's Avatar
Trade: Deck Builder
Thanks.
Email me for supplier prices etc
[email protected]
Old 03-27-2019, 05:32 PM   #20
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 8,034
[email protected]
Who are you buying them from?
I have gotten quite a few factory direct in the past couple years that I've been very pleased with. Price is Right too.
Even with stain, you can make it last a long time up there I'd imagine cause I can get a good three years out of stains here if I really make an effort to make it last the first year of installation.
‘ugly and inaccurate because our thoughts are foolish, but the slovenliness of our language makes it easier for us to have foolish thoughts.’ -George Orwell
Deckhead is offline
Wrestling Cage design ideas Driftweed Architecture & Design 7 10-22-2014 10:04 AM
pool decking ideas PicturePerfect Decks & Fencing 8 05-11-2010 09:24 PM
Practical GREEN ideas that don't cost much, part 1. wackman General Discussion 24 03-15-2010 06:52 PM
Decking Care kenhue design General Discussion 1 02-24-2010 08:31 AM
Big Dock job - design ideas casey344 Drafting & CAD Forum 38 10-23-2009 07:46 PM
