More Decks - Page 2 - Decks & Fencing - Contractor Talk
More Decks
Old 06-17-2015, 09:25 PM   #21
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Re: More Decks
Originally Posted by killerdecks View Post
I make them, have access to anything I want in extruded aluminum, have 3 welding machines and some guys that can weld
How do you mount them?
EricBrancard is offline
Old 06-17-2015, 09:41 PM   #22
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
Re: More Decks
we drill a hole 1 1/2" w/fostner bit pound it in, the friction holds it because we aren't good enough, nor anal enough, to try and weld 2 perfect 90's on each end, for the ones that might be loose we run a 3" green screw into the post, it goes right through the aluminum and locks it in.
I have seen flanges on the short side w/ 2 screw holes. than it's just a matter of a couple of 90 degree welds your saving lots of money
killerdecks is offline
The Following User Says Thank You to killerdecks For This Useful Post:
EricBrancard (06-17-2015)
Old 06-18-2015, 05:31 AM   #23
CITY DECKS INC's Avatar
Trade: DECK BUILDER. RESIDENTIAL. COMMERCIAL
Rewards Points: 4,608
Re: More Decks
Looking good killer. I like the one about the friends having them blown up. Thats a riot.
CITY DECKS INC is offline
The Following User Says Thank You to CITY DECKS INC For This Useful Post:
Calidecks (06-18-2015)
Old 06-18-2015, 11:31 AM   #24
jstanton's Avatar
Trade: carpentry
Rewards Points: 214
Re: More Decks
Cool stuff, never seen a spiral staircase outside. Can you give us an insight on what something like that costs. I'd be curious if it was cheaper than a full flight in pvc ect..
Also, I've been meaning to ask. How many have your decks killed?
jstanton is offline
Old 06-18-2015, 01:27 PM   #25
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
Re: More Decks
really?
Old 06-18-2015, 03:57 PM   #26
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Re: More Decks
Just as a side note..we always say powered coated aluminum but how do they charge a magnetic to aluminum ?
J.
John Hyatt is offline
Old 06-18-2015, 04:06 PM   #27
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,794
Re: More Decks
J.
Powder coating has nothing to do with magnets.
Positive and negative electric current.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post:
EricBrancard (06-18-2015), John Hyatt (06-18-2015)
Old 06-18-2015, 04:31 PM   #28
Jimbo2015's Avatar
Trade: solar
Rewards Points: 178
Re: More Decks
I'm building two spirals now, one indoor and one outdoor off a deck onto a upper balcony.
All in western red cedar, once you have plans they are not hard to build, but the handrails are in fact harder than the steps.
Those look great, but I don't like that bar between the risers, looks like a trip hazard, I realize it meets code likely.
But there are better safer options.
Jimbo2015 is offline
Old 06-18-2015, 05:28 PM   #29
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
Re: More Decks
Finally a "friend"
That's that horizontal bar for little kids to crawl up on, because the rises are too tall.
So let's see all the pics of your better safer solutions, "friend"
Old 06-18-2015, 05:51 PM   #30
TG Deck's Avatar
Trade: exterior carpentry
Rewards Points: 1,770
Re: More Decks
Originally Posted by Jimbo2015 View Post
...... but the handrails are in fact harder than the steps.
For sure.
So much more time required.
TG Deck is offline
Old 06-18-2015, 07:48 PM   #31
Rewards Points: 986
Re: More Decks
Finally a "friend"
Dude, he was pretty polite in his response. Just sayin....
Old 06-18-2015, 07:54 PM   #32
Jimbo2015's Avatar
Trade: solar
Rewards Points: 178
Re: More Decks
On this one a solid piece was installed attached under the tread.
Another one is to use clear acrylic full height,
The Following 3 Users Say Thank You to Jimbo2015 For This Useful Post:
EthanB (06-21-2015), JAH (06-21-2015), Tom Struble (06-21-2015)
Old 06-18-2015, 08:05 PM   #33
Dan_Watson's Avatar
Rewards Points: 2,748
Re: More Decks
Almost spit out my beverage.
I never even read your name like that. But is there a number?
I see where everyone is coming from and can agree with both sides. My company is more like the others, not Killer. Our customers would be up in arms over the way the field boards meet the boarder in those pictures. Different sized gaps and the field board cuts are not parallel to boarders. We have been called out on much less.
Different markets, different customers, different projects, different end results. My point is some of us can blast through a project, get it done, make it look good and move on, some of us have to take more time, be more meticulous and provide a great/ near perfect product.
This is why we switched to helical and steel framing. Less variables, less issues, better end results. All faster than other methods.
Dan_Watson is offline
Old 06-20-2015, 09:41 PM   #34
maxwage's Avatar
Trade: Commercial Construction
Rewards Points: 791
Re: More Decks
Bad ass deck builders can be such divas! Christ almighty! I have a 7 year old only child whose diva levels don't even compare to a select few on here. Good work MEN! All of yous. Pull your phucking tampons out and stop being little pubescent pussies.
I'm a beast at everything I do.
I buy tools. Not brands.
maxwage is offline
The Following User Says Thank You to maxwage For This Useful Post:
parkers5150 (06-21-2015)
Old 06-20-2015, 10:14 PM   #35
Hack
asevereid's Avatar
Rewards Points: 160
Re: More Decks
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
Old 06-20-2015, 11:51 PM   #36
GC/carpenter
Calidecks's Avatar
Rewards Points: 6,134
Re: More Decks
I thought this thread stayed pretty civilized actually
Calidecks is online now
Old 06-21-2015, 04:27 AM   #37
jb4211's Avatar
Rewards Points: 2,306
Re: More Decks
I think it looks great. I'd be proud if it was my creation.
Great job
Jon
jb4211 is offline
Old 06-21-2015, 07:31 AM   #38
Re: More Decks
thats one way or we usually use 3" oak or lvl beam as tread and make sure the rise around 7" riser gap is up to 4" or less depending on the over all rise.
http://www.citydecksinc.com/#!sample...lbumphotos0=22
Old 06-21-2015, 09:53 AM   #39
maxwage's Avatar
Rewards Points: 791
Re: More Decks
A little tipsy last night. I almost caught a TUI. Agree to disagree. Different styles, regions. All accomplished, some of the best in their area, if not country!!
maxwage is offline
Old 06-21-2015, 12:08 PM   #40
GC/carpenter
Calidecks's Avatar
Re: More Decks
I wish I could get tipsy, problem is I'd have to stay that way for the rest of my life.
autofeed screw guns for decks and/or drywall dale rex Tools & Equipment 11 02-24-2016 10:16 AM
Kid needed decks and finish work toronto bbgcarpentry Help Wanted or Looking For Work 3 04-23-2013 09:55 PM
New home decks klyde Business 2 01-29-2013 10:29 PM
How many decks can a crew finish. klyde Decks & Fencing 40 11-03-2012 04:15 PM
Framing decks from the top down redwood Decks & Fencing 79 08-24-2012 05:14 PM
