Maine Deck Bracket Experience And Basic Deck Questions - Decks & Fencing - Contractor Talk
Old 06-05-2019, 09:08 PM   #1
jb9's Avatar
Trade: Plumbing
Rewards Points: 186
Hello,
Has anyone here ever used one of the Maine Deck Brackets? It looks like a nice product. I have a 2x10 rim and I'm trying to figure out where to mount the bracket. Does anyone have any suggestions as to what size 2x I should use for the ledger? Also, do I assume that the decking is going to be 1" thick so that I can calculate the height of the deck landing? And what is a common height difference between the deck surface and the door threshold? I know it typically is a little lower.
Thanks in advance.
jb9 is online now
Old 06-05-2019, 10:07 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 2,062
Re: Maine Deck Bracket Experience And Basic Deck Questions
Originally Posted by jb9 View Post
Hello,
Thanks in advance.
Wholly $#!*, Hoss.
Got a draftsman/designer?
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
hdavis (06-06-2019)
Old 06-05-2019, 11:17 PM   #3
hdavis's Avatar
Rewards Points: 1,652
Read their FAQs. If you're using lag bolts, they have to go into 6 inches of solid wood. Preferred is carriage bolts through bolted.
I suggest you download a copy of the deck design guide to guide you through designing and building this.
https://www.awc.org/pdf/codes-standa...Guide-1405.pdf
hdavis is online now
Old 06-05-2019, 11:22 PM   #4
hdavis's Avatar
Areas with heavy snow may have the deck 6 inches below the interior floor.
With no other considerations, deck floor is set at the same height as the interior floor surface.
Old 06-05-2019, 11:33 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 1,824
Hello,
No idea what they are or how you use them
At least as wide as your joists
All depends on what kind of decking you intend to use.
I prefer flush w/threshold/finish floor.
Snow country 6" drop
Thanks in advance.
do yourself a favor and get someone to draw a a simple sketch for you as to how this thing goes together....
griz is online now
Old 06-05-2019, 11:44 PM   #6
TheConstruct's Avatar
Rewards Points: 900
I think dropping the deck a few inches, regardless of code,in snowy/rainy climates is good practice to help prevent wind driven rain and ice etc from getting under the door. Typically 3" is what I've seen here.
TheConstruct is offline
