Keep Ledger? - Decks & Fencing - Contractor Talk
Keep Ledger?
Thread Tools
Old 04-16-2019, 04:32 AM
pathbuilder's Avatar
Rewards Points: 406
Keep Ledger?
I'm bidding on a resurfacing job and wanted to reach out to see what you'd do here. Railing and boards will be replaced, along with new rim joists. Deck is 17 years old. For the most part, well built for its time: it was permitted, 2x12 beams, 2x10 joists, 2 carriage bolts in post-beam connection, W shaped carriage bolts for ledger, 4x6 posts. Digging out 8" of earth around all of the posts the wood was solid. My biggest concern is that the deck is ledgered through brick and to a cantilevered portion of the home (we do have access inside unfinished basement), which is against code here, and it wasn't flashed. This municipality will Grandfather the deck in since it was permitted. I figure they're still going to want to see flashing added, and (3) of those 18" threaded steel rods.
But what about that space behind the ledger. I have no xray vision to know if there's rot behind there. If I were to replace the ledger I'd have to (probably) detach the deck and add posts in thru their patio for a new beam.
Would you just proceed with adding flashing and the 18" threaded steel rods, ask the building department to just replace the ledger board, or add posts/beam?
Sent from my Pixel 3 XL using Tapatalk
pathbuilder is offline
Old 04-16-2019, 09:17 AM
KAP's Avatar
Trade: Custom
Rewards Points: 33,756
Re: Keep Ledger?
Why would you leave and subject the work you're going to do to a 17-year old ledger?
If it was for your Mom how would you approach it?
KAP is offline
Old 04-16-2019, 10:00 AM
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,920
Re: Keep Ledger?
i might be missing something .a lot of info is not here .why can you not tell if ledger is solid ,drill a hole in and check if you need to .are you replacing joist . are you going to flash top of joist . about that ledger -how well is it flashed .till you pull the decking you maynot know . is this ledger directly fastened to the brick ,has this damaged the back side .brick like concrete holds moisture .
if you have second thoughts -stop and rethink .it sucks when it bites you later .
JFM constr is offline
Old 04-16-2019, 10:27 AM
Rewards Points: 406
Re: Keep Ledger?
The existing deck's ledger is not flashed, not that I can tell. I'll be honest, I've never drilled a hole in to a ledger to check if it's rotted - would that truly paint a picture of the entire ledger's rot status though? Joists will be staying, will be adding waterproofing tape on top. Plan is to add proper flashing above the ledger. The ledger is currently carriage bolted from inside the house through the ledger.
The thing is, I just don't know if it's rotting. Removing ledger and re-ledgering would be more expensive than just adding the posts. Or maybe we wait for the new Simpson BVLZ, to ledger through brick in a code-approved way. Though again, this doesn't tell me if the 17 year old ledger that wasn't flashed is rotting or not.
Here's my best approach, would like your honest thoughts: Pull boards. If the ledger was flashed (and I just can't see it currently), good to go as-is. If the ledger is not flashed, add a beam & posts under the deck, keeping the ledger as-is.
Old 04-16-2019, 03:23 PM
JFM constr's Avatar
Re: Keep Ledger?
Here's my best approach, would like your honest thoughts: Pull boards. If the ledger was flashed (and I just can't see it currently), good to go as-is. If the ledger is not flashed, add a beam & posts under the deck, keeping the ledger as-is.[/QUOTE]
sounds like a good approach .
Old 04-16-2019, 04:58 PM
Talking Head
EthanB's Avatar
Rewards Points: 290
Re: Keep Ledger?
I wouldn't reskin a 17 year old deck. I definitely wouldn't reskin a deck that had tall 4x posts with that "beam" system and no lateral bracing.
Planer.....
EthanB is offline
The Following 3 Users Say Thank You to EthanB For This Useful Post:
Bull Trout (04-16-2019), Calidecks (04-16-2019), ScipioAfricanus (04-16-2019)
Old 04-16-2019, 08:59 PM
GC/carpenter
Calidecks's Avatar
Rewards Points: 17,986
Re: Keep Ledger?
And half the deck load is carried on the carriage bolts at the beam connections. That's a big no no.
And I agree wholeheartedly with everything Ethan said.
Mike.
_______________
Calidecks is offline
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
Bull Trout (04-16-2019), Irishslave (04-17-2019)
Old 04-16-2019, 09:16 PM
Rewards Points: 406
Re: Keep Ledger?
This deck aside, is the age of the deck a black-and-white indicator to resurface or not? Many of my leads are "I have an existing deck, the frame is fine, just replacing boards". Is there an age of deck you would or wouldn't do? What if a 15 year old deck looks great, still no?
Old 04-16-2019, 09:25 PM
Bull Trout's Avatar
Rewards Points: 518
Re: Keep Ledger?
Would be no for me, the only 15 yr old work I want to own is my own
Bull Trout is offline
Old 04-16-2019, 09:29 PM
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 1,350
Re: Keep Ledger?
I just re-decked pt from 1992. Framing was like in a museum. Perfect. Removed rails and other decking that's actually pretty good too. Reason being it maybe get an HR of sun per day. And older lumber and whatever else they out in it to preserve it. I couldn't believe it. Of course I added a blocking reenforced few things here and there changed/ added few hangers and sds. And replaced the stair case with proper rise/ run. Do your due diligence.
Sent from my E6810 using Tapatalk
CityDecks is offline
Old 04-16-2019, 09:34 PM
GC/carpenter
Calidecks's Avatar
Re: Keep Ledger?
What happens when the beams start splitting here where the bolt holes are?
Mike.
_______________
Old 04-16-2019, 09:43 PM
CityDecks's Avatar
Trade: Deck Builder
Re: Keep Ledger?
Mike.
_______________
Again due diligence. That's clearly needs to updated. But also keep in mind that that it's been that way for how long? In this case I would swap out including post / footings. I look at this. A new it updated deck becomes like a new puppy everyone wants to play on it. Which means it will get more action and attention then before so you have to prepare for the more.
The Following User Says Thank You to CityDecks For This Useful Post:
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,525
Re: Keep Ledger?
Would that meet current code? Safety is a good motivator.
I once had a potential deck job like that, which was pulling away from the ledger. I could not sufficiently persuade them on the catastrophic danger (not that it's what you have there).
That's a lame beam.
MarkJames is offline
Old 04-16-2019, 09:45 PM
KAP's Avatar
Trade: Custom
Re: Keep Ledger?
The last person to touch it usually owns what happens to it... what exactly are you saving?
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
Old 04-16-2019, 09:50 PM
GC/carpenter
Calidecks's Avatar
Re: Keep Ledger?
Putting new wet decking on old beams will need to be considered as well. If not by you by their insurances attorneys.
Mike.
_______________
KAP (04-16-2019)
Old 04-16-2019, 09:56 PM
CityDecks's Avatar
Trade: Deck Builder
Re: Keep Ledger?
This thread is dead already.... moving on
Old 04-16-2019, 10:06 PM
HammerSwing's Avatar
Trade: Deck Building
Rewards Points: 116
Re: Keep Ledger?
I hate the "grandfathered in" rule. If you're going to do new work to it, they should make it be up to code. If you can't build the frame exactly as it sits right now, IMO you should have to tear it down and build it to code.
I usually point out every flaw in the existing structure to try to persuade the homeowner in going with new framing as well. Because I've NEVER met a deck that just goes smoothly while resurfacing, I usually charge more than I would to just put decking on something I built. I usually add an option at the bottom of the proposal with the price of the extra tear down (usually not much extra after decking and railing demo are already included in the bid), and the framing. Again, because I am already pricing my resurfacing at a premium, the extra cost doesn't look quite as high as I normal charge (although it works out the same in the numbers).
Most of the time I get people to either add on the framing after highly suggesting it in the sales meeting, or they find someone else cheaper to resurface it. I hate trying to deck over someone else's shoddy work. It takes twice as long to make it look good. Sell sell sell them on a complete job. Much easier on you and your crew.
HammerSwing is offline
Old 04-16-2019, 11:02 PM
Rewards Points: 406
Re: Keep Ledger?
Mike.
_______________
Think those metal brackets designed for this purpose do any good?
Old 04-17-2019, 01:35 AM
GC/carpenter
Calidecks's Avatar
Re: Keep Ledger?
They may help, but that's a hell of a load to be putting in any fasteners. I like to see full bearing support.
Mike.
_______________
Old 04-17-2019, 05:23 AM
CityDecks's Avatar
Trade: Deck Builder
Re: Keep Ledger?
There for retro fit. Good idea
Thread Tools
Rate This Thread
Balloon framed house and ledger board issue quantumflux Decks & Fencing 13 06-20-2016 08:12 PM
question on best way to proceed with ledger /floor joist repairs rustyself Carpentry 3 01-17-2014 01:26 PM
whats your ledger board flashing detail? Rich D. Decks & Fencing 77 10-24-2012 07:08 PM
Ledger board attachment livingsoulsdie Decks & Fencing 20 06-06-2012 09:42 AM
Pergola, curved ledger at house. ApgarNJ Framing 34 10-25-2011 06:16 PM
