Huge Rural Gate - Decks & Fencing - Contractor Talk
Huge Rural Gate
Old 06-06-2019, 09:18 AM   #1
kallisti5's Avatar
Trade: Electric
Rewards Points: 12
Huge Rural Gate
I have a *heavy* gate that I need to automate (cheaply). Not sure what the guy who installed it was thinking. (I mean, it looks great, just not practical)
Any thoughts about slicing it in half and making it a double? (welding hinges on the right side).
The thing is about 300+ pounds (steel) and has chewed up wheels from being dragged through the gravel drive.
No rust though.
kallisti5 is offline
Old 06-06-2019, 12:30 PM   #2
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Re: Huge Rural Gate
Change out that Rhode Island sized grocery cart caster for Texas sized version?
SmallTownGuy is offline
Old 06-06-2019, 12:41 PM   #3
KAP's Avatar
Trade: Custom
Rewards Points: 40,184
Re: Huge Rural Gate
Cheaply?... guess we'd need to know what you mean by cheaply first... tree-fiddy?...
KAP is offline
Old 06-06-2019, 12:43 PM   #4
kallisti5's Avatar
Trade: Electric
Rewards Points: 12
Re: Huge Rural Gate
Heh. I could weld on a bigger wheel. The driveway is uneven Caliche though and *not* flat. Rubber tires don't do well out here, there were two additional rubber wheels which were bolted on at some point over over the last two years.. both of which are rotten, split, flat.
So, consensus is to try and fix the path of the gate (redo wheels, maybe recommend paving the area) vs attempting to split it?
Old 06-06-2019, 12:45 PM   #5
kallisti5's Avatar
Trade: Electric
Rewards Points: 12
Re: Huge Rural Gate
ha, just trying to use what's here vs recommending a nice au. gate :-)
Old 06-06-2019, 12:51 PM   #6
KAP's Avatar
Trade: Custom
Re: Huge Rural Gate
If it's for your house, learn from the first guys mistake and do it right so you don't have to worry about it going forward...
If it's for a customer, same thing, but make sure you charge more than cheaply...
KAP is offline
Old 06-06-2019, 12:54 PM   #7
John the Builder
Re: Huge Rural Gate
Get yaself one of these. It will likely outlive the gate and you...
Old 06-06-2019, 06:37 PM   #8
hdavis's Avatar
Rewards Points: 2,074
Re: Huge Rural Gate
I wouldn't split it, that's just more of the same kinds of headaches. Get bigger tougher wheels.
hdavis is online now
Old 06-06-2019, 06:42 PM   #9
Dirtywhiteboy's Avatar
Rewards Points: 5,160
Re: Huge Rural Gate
The gate needs to be set up on a track so it can slide open & closed with be a remote like a normal gate in 2019
Dirtywhiteboy is online now
The Following 2 Users Say Thank You to Dirtywhiteboy For This Useful Post:
Easy Gibson (06-06-2019), TheConstruct (06-06-2019)
