How To Pull A 4x4 Post? - Decks & Fencing - Contractor Talk
Old 02-20-2012, 03:27 PM   #1
The Deck Guy
Greg Di's Avatar
Rewards Points: 2,000
Isn't there a "redneck" way to pull a 4x4 that's embedded in concrete (a footing...not a fencepost) with a come along and/or a jack that's pretty easy?
I have a job where I can't get any equipment in to pull out four old post/footings for a freestanding landing.
Greg Di is offline
Old 02-20-2012, 03:29 PM   #2
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Re: How To Pull A 4x4 Post?
Jackhammer...
RobertCDF is offline
Old 02-20-2012, 03:30 PM   #3
Yankee Framer's Avatar
Trade: Framing
Rewards Points: 150
Drill a hole through the post and insert a rod or bolt and use a bottle jack....or something along those lines.
Yankee Framer is offline
Old 02-20-2012, 03:41 PM   #4
DavidC
DavidC's Avatar
Rewards Points: 2,006
I'd bet you're thinking of a fence post jack. Plenty of redneck versions out there and you can still get a store bought one. The secret ingredient is leverage to pop a fence post straight up.
But them fence posts is blunt or sharpened, no concrete shoes wider than the post hole.
You'll need a couple of Armstrong Excavators and rent an electric demo hammer for the concrete.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 02-20-2012, 03:42 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,711
Originally Posted by Greg Di View Post
a "redneck" way
Dynamite.
Per Yankee's concept, I've picked up a 1400 lb furnace with a steel rod and a bottle jack. A lot of it would depend on the soil and the size of the footings.
Tinstaafl is offline
Old 02-20-2012, 03:43 PM   #6
The Deck Guy
Greg Di's Avatar
The footing is most likely about 36" deep I might add...
Greg Di is offline
Old 02-20-2012, 03:58 PM   #7
DavidC
DavidC's Avatar
Sounds like your helpers going to need a helper.
Good Luck
DavidC is offline
The Following User Says Thank You to DavidC For This Useful Post:
SC sawdaddy (02-20-2012)
Old 02-20-2012, 04:01 PM   #8
Jdub2083's Avatar
Trade: General Contracting / Commercial Carpenter
Rewards Points: 282
Can it just be cut if off? Seems like the only "easy" way to do it.
Jdub2083 is offline
Old 02-20-2012, 04:08 PM   #9
MarkDeck's Avatar
Trade: Fence and Decks
Rewards Points: 75
They make a non-redneck post pullers. Around here they are $500 for a manual version. If you're doing a bunch they make a hydraulic version.
MarkDeck is offline
The Following 3 Users Say Thank You to MarkDeck For This Useful Post:
aptpupil (02-21-2012), Blackfly (02-20-2012), onthelevel (02-21-2012)
Old 02-20-2012, 04:25 PM   #10
The Deck Guy
Greg Di's Avatar
Originally Posted by Jdub2083 View Post
Can't you just cut if off? Seems like the only "easy" way to do it.
No...new location is just about in the same place so the old ones will just be in the way.
For all I know, they might be miniscule footings and will come out easy. I just am preparing for the worst.
We can pull some footings with the Techno Metal Post machine.
Greg Di is offline
Old 02-20-2012, 04:34 PM   #11
katoman's Avatar
Trade: carpenter
Greg, just have the guys dig a sloped trench up to the post. Tip it over and drag it out. Fastest way I've come up with. By the time you rent or set up some machine the jobs' done.
katoman is offline
Old 02-20-2012, 04:40 PM   #12
Trade: Framing
Rewards Points: 150
You could also attach a board perpendicular to the post a little off the ground and then take one or two of the new posts you have and lever the thing out with a rock or brick or 4x4 drop off placed at a good ratio on the ground for max advantage. Is the footing continuous or isolated around each post?
I would prefer calling it a "MacGyver" way then "redeck" way.
Old 02-20-2012, 06:00 PM   #13
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
I dont mind Redneck at all.
A floor jack works real well. They are cost efective and work with the same chain.
Dont know how to use them ??? watch the 500 race this Sunday there will be plenty of action with floor jacks I can tell you.
JonMon www.deckmastersllc.con
John Hyatt is offline
The Following User Says Thank You to John Hyatt For This Useful Post:
DeckPros (02-20-2012)
Old 02-20-2012, 07:21 PM   #14
Willy is's Avatar
Trade: residential restoration
Rewards Points: 250
I have done this and it is quick and easy. You could use 2x4s but picture a teepee shape with 3 or 4 legs directly over the post.
A chain is connected to the top for a lifting point.....
To a comealong that reaches down to the base of the 4x4, a light small linked chain or cable choker grabs the base of the post.
Now....... all you have to do is let the comealong do the lifting instead of your back.
Extra credit; can you imagine how well anchored the post is on a dry July day when the dirt or clay is like rock?
Take a root fertilizer, they hook to a garden hose with a long hollow spike on the end. You can irrigate the post about 2 foot down. Now, instead of rock hard dirt, you have mud holding the post in place.
With a good hoist and wet ground the posts come right up. This is the type of SOB that I used to throw my back out on.
No digging, no lifting and relatively no mess.
willy
Willy is is offline
Old 02-20-2012, 07:23 PM   #15
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,728
Tie a chain around it as low as you can go. Get a wheel as big as you can and wrap the chain around the wheel and hook it to your truck. Pulls it out every time.
NKLHD
knucklehead is offline
The Following 2 Users Say Thank You to knucklehead For This Useful Post:
davitk (02-21-2012), Tom M (02-20-2012)
Old 02-20-2012, 07:50 PM   #16
XJCraver's Avatar
Trade: Building Official
Rewards Points: 28
A High-Lift jack (or Handyman jack around here) and a short piece of chain should pop them right out. If there's an enormous amount of concrete around the bottom, rent an engine hoist (cherry picker around here) and use the same chain.
You can buy the handyman jack for ~ $50, and the cherry picker should rent for $30-$40 a day.
XJCraver is offline
Old 02-20-2012, 08:43 PM   #17
RAbraker's Avatar
Trade: Carpentry/Basements/Decks
Rewards Points: 75
That is nothing short of brilliant
RAbraker is offline
Old 02-20-2012, 08:47 PM   #18
Brett Ashworth
FrehouseRemdlin's Avatar
Trade: Remodeling, Additions, Repairs
Rewards Points: 75
That's how I do it too. Mainly with the high lift jack. Luckily so far I haven't needed to drag out the cherry picker.
FrehouseRemdlin is offline
Old 02-20-2012, 09:22 PM   #19
The Deck Guy
Greg Di's Avatar
I like it! Thanks...
The only problem I could forsee is that the jack might be sitting on top of the concrete footing while it's positioned next to post which may negate any jack....don't know...
Greg Di is offline
Old 02-20-2012, 10:34 PM   #20
General Contractor
greg24k's Avatar
Rewards Points: 8,402
It's a post and a footing... come on Greg, yank this thing right out, do you really need to know how to do it?
Any Which Way You Can...(and there is so many ways) Get it done
greg24k is online now
Timo (02-21-2012)
concrete inside vinyl fence post? pjwinstalls Decks & Fencing 3 07-17-2009 01:36 PM
