How Do I Correctly And Quickly Find These Angles? - Page 2 - Decks & Fencing - Contractor Talk
Old 06-02-2014, 08:15 PM   #21
DuFast's Avatar
Trade: Building Trades
Rewards Points: 208
Re: How Do I Correctly And Quickly Find These Angles?
Already put the stringers in just didn't have em in yet when I took the pic. Thanks though.
DuFast is offline
Old 06-02-2014, 08:18 PM   #22
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 560
Originally Posted by DuFast View Post
I knew how to get it close and then adjust the miter saw to get it exact. I just want to know how to get it on the first try and the boards fit tight all the way down the miter
This will very rarely happen. Even if the first one ends up tight, there are many factors that can make each board a bit different. An accurate miter saw is very important too. Depending on the material, variances in size will also be a factor. Keeping them tight needs to be addressed also.
Warren is online now
The Following 2 Users Say Thank You to Warren For This Useful Post:
John Hyatt (06-03-2014), m1911 (06-02-2014)
Old 06-02-2014, 08:19 PM   #23
Stoneyard's Avatar
Trade: Journeyman Carpenter
Rewards Points: 249
Do all of the existing stringers come out the same distance from the rim joist?
Stoneyard is offline
Old 06-02-2014, 08:20 PM   #24
DuFast's Avatar
Rewards Points: 208
Yes.
DuFast is offline
Old 06-02-2014, 08:22 PM   #25
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
Your entitled to a bad day . Do a search on google . Anglefinder
Eaglei is offline
Old 06-02-2014, 08:26 PM   #26
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
Go to a teacher supply store and get a big giant protractor. Or.. better yet align the base of your saw with one edge and then rotate your saw to line up with the opposing edge. You'll have a perfect angle every time.
I'm always looking for the answer to my troubles at the bottom of a paint can.
tedanderson is offline
Old 06-02-2014, 08:27 PM   #27
DuFast's Avatar
Rewards Points: 208
Eaglei that means a lot it's been a really bad week. Had 3 tools break n all other kinds of crap.
DuFast is offline
Old 06-02-2014, 08:46 PM   #28
Stoneyard's Avatar
Rewards Points: 249
It may seem like a bad day or week but in the end its a good experience that will make you a better Carpenter. I only got where I am because of the mistakes I made...
The Following User Says Thank You to Stoneyard For This Useful Post:
pinwheel (06-03-2014)
Old 06-02-2014, 09:07 PM   #29
Patrick's Avatar
Rewards Points: 2,364
I hope Your not leaving those cut ends and grooved end exposed. They are overhanging so i would assume you are...
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 06-02-2014, 09:33 PM   #30
DuFast's Avatar
Rewards Points: 208
Got to cut the grooved end then I'm going to take a router to it to give it a tiny curve. Is there something I can put over it?
DuFast is offline
Old 06-02-2014, 09:38 PM   #31
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
That "curve" is called a round over edge.
m1911 is offline
Old 06-02-2014, 10:41 PM   #32
Quad Racer's Avatar
Rewards Points: 594
Use some scrap. Start with a reasonable angle and tweak it from there. Thats full proof and leaves you with a template.
Quad Racer is offline
Old 06-03-2014, 05:11 AM   #33
Box Builder
Morning Wood's Avatar
Rewards Points: 6
Get it close and then dial it in. The old measure twice cut three times.
Morning Wood is online now
Old 06-03-2014, 05:27 AM   #34
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
That's how I do it, and have for a lot of years. In fact I can now just look at it and say " yep that's a 20 1/2 degree, and that one is 18 1/16''
J.
John Hyatt is offline
Old 06-03-2014, 05:48 AM   #35
jb4211's Avatar
Rewards Points: 2,306
Often, the most important part of a job is the last 10%.
And, when I've been "stuck" trying to figure something out in the past, I walk away for a minute. I'll go do something else, go to lunch, whatever. After a little while i'll come back and look at the problem refreshed. Then i'll wonder why is was a problem in the first place. lol
Figuring this angle is a very small, easy thing. Don't let it beat you up. Use some of the advice here, think it though and you'll wonder why this was a problem in the first place too.
Just one thing, if you're laying boards on top to mark the angle, just make sure you have them flat. If the tread board on the right side is laying on the stringers, you'll need to lay a spacer board on the left side and then lay the left tread that you're going to use to mark the angle, on top. Other wise, the decking on the left will have one end sitting on the stringers and the other end resting on the decking board on the right causing a deviation from level and possibly effecting the finished angle.
Jon
jb4211 is offline
Old 06-03-2014, 05:49 AM   #36
Quad Racer's Avatar
Rewards Points: 594
Its better than wasting material or using some Jim Bob homeowner tool from Harbor Freight. And if you're experienced enough you shouldn't have to cut it 3 times.
Old 06-07-2014, 12:45 AM   #37
GC/carpenter
Calidecks's Avatar
Rewards Points: 58
Or an eased edge.
Calidecks is online now
m1911 (06-07-2014)
