How To Build A Gate When Fence Has A 2x6 Cap - Decks & Fencing - Contractor Talk
Old 09-18-2020, 03:36 PM   #1
Jaredrodgers's Avatar
Trade: Carpentry fences and decks
I’m doing a fence with a 2x6 cap and realize there will be problems with the gate opening. Can anyone point me to pics, links or help with ideas of how to make this work? Thnx!
Jaredrodgers is offline
Old 09-18-2020, 04:07 PM   #2
General Contractor
greg24k's Avatar
Rewards Points: 48
Re: How To Build A Gate When Fence Has A 2x6 Cap
Originally Posted by Jaredrodgers View Post
Iím doing a fence with a 2x6 cap and realize there will be problems with the gate opening. Can anyone point me to pics, links or help with ideas of how to make this work? Thnx!
Carpentry and fences trade and you can't figure that out?
Gate under the caps?
greg24k is offline
Old 09-18-2020, 04:14 PM   #3
GC/carpenter
Calidecks's Avatar
Rewards Points: 88
Cut the corners off that are impeding the gate.
Mike.
_______________
Calidecks is offline
The Following 4 Users Say Thank You to Calidecks For This Useful Post:
griz (09-18-2020), Rio (09-18-2020), Seven-Delta-FortyOne (09-19-2020), Tyler J (09-19-2020)
Old 09-18-2020, 05:40 PM   #4
Mordekyle's Avatar
Rewards Points: 6,494
The top rail at the latch side can have a pie shaped gap.
The hinge side should be easy enough.
Mordekyle is offline
Old 09-18-2020, 07:19 PM   #5
Dont gotta be a dick, jeez. Just getting first few fence jobs. trying to find better option than cutting the corners and breaking the continuity. Gate under caps is interesting but probably not ideal for the client. thanks
Old 09-18-2020, 07:22 PM   #6
Mike.
_______________
Yeah the client is hoping to not break the continuity having the corners cut out... brainstorming other possible options. thnx
Old 09-18-2020, 07:25 PM   #7
tgeb's Avatar
Rewards Points: 22
Scribe the gate?
Sent from my SM-G970U using Tapatalk
www.gebcon.com
tgeb is online now
Old 09-18-2020, 09:20 PM   #8
deckman22's Avatar
Trade: Retired Deck Builder
Rewards Points: 508
With the right size gap between the fence and the gate 2x6 it will close.
Deckman
deckman22 is offline
The Following User Says Thank You to deckman22 For This Useful Post:
Calidecks (09-18-2020)
Old 09-18-2020, 09:39 PM   #9
GC/carpenter
Calidecks's Avatar
Rewards Points: 88
Cutting the corners can be done to look clean. And it's only one side.
Mike.
_______________
deckman22 (09-18-2020)
Old 09-18-2020, 10:47 PM   #10
Originally Posted by tgeb View Post
Scribe the gate?
What does this mean?
Old 09-18-2020, 10:53 PM   #11
I did that on my last one. put blocks in where the hinges mount so I could extend them out further ( couldnt find any that were just long enough and would fit.) These guys are hoping for a tighter fit, more privacy.
Old 09-18-2020, 10:55 PM   #12
Sounds like cutting the corners or a wider gap (skinnier gate) are my options. Was hoping there might be someinthg else I hadnt thought of. will make it work. thanks all.
Old 09-19-2020, 07:50 AM   #13
MarkJames's Avatar
Rewards Points: 56
You shouldn't need to round off too much for it to work and still look right.. Did about a 1" radius on one and it's fine.
Perhaps a 10 degree or so cut (both ends might work. Haven't tried it, but maybe. (?)
MarkJames is offline
Old 09-19-2020, 09:19 AM   #14
hdavis's Avatar
Rewards Points: 268
Couple options if you want the cap to be visually close to continuous.
Leave off the top rail for that section, hang the gate, put the continuous top rail in place temporarily, swing arcs for both the strike side and the hinge side with the center of the arc being a little further out from the fence than the center of the hinge for the strike side. Take top rail off and cut as marked. Clean up cuts and reinstall.
The other option is to use hinges that can be mounted so that the hinge pin is further away from the fence than the edge of the top rail, so only the strike side gets cut as an arc, and the hinge side gets a square cut.
hdavis is offline
Old 09-19-2020, 09:52 AM   #15
General Contractor
greg24k's Avatar
Rewards Points: 48
If you have a 2x6 cap cut flush with the end of the fence and flush with the ends of the gate and have a 1/2" reveal on each side you don't have to round or cut anything off the cap. Most likely the reveal between the fence and the gate will be around 3/4 so it should be OK
That said not being a dick, just telling you how it is, it's common sense.
How to build a gate when fence has a 2x6 cap-untitled-1.jpg   How to build a gate when fence has a 2x6 cap-untitled-2.jpg   How to build a gate when fence has a 2x6 cap-gate-2.jpg   How to build a gate when fence has a 2x6 cap-gate-3.jpeg
greg24k is offline
The Following 5 Users Say Thank You to greg24k For This Useful Post:
Calidecks (09-19-2020), deckman22 (09-19-2020), hdavis (09-19-2020), Rio (09-20-2020), Tyler J (09-19-2020)
Old 09-19-2020, 10:59 AM   #16
deckman22's Avatar
Rewards Points: 508
My point exactly Greg, thanks for the visual. OP must be a rookie and it showed with his post. No offense Jarod, we were all there once.
Deckman
greg24k (09-19-2020)
Old 09-19-2020, 10:04 PM   #17
Mordekyle's Avatar
I think I just had a wider gap at the back of this inswing gate.
Hinges left side, three boards in. Lever latch on the right. Homeowner put on the rest of the fence boards.
Old 09-19-2020, 10:14 PM   #18
GC/carpenter
Calidecks's Avatar
Rewards Points: 88
3/4" gap is not substantial for a gate.
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
tang (09-20-2020), Tyler J (09-19-2020)
Old 09-20-2020, 11:43 AM   #19
tang's Avatar
Trade: Remodel contractor
Rewards Points: 549
Gap it enough to swing..
How to build a gate when fence has a 2x6 cap-22281601_10212415812564698_5989249123975955029_n.jpg   How to build a gate when fence has a 2x6 cap-22365279_10212415810804654_6993602649802824118_n.jpg
tang is offline
The Following 3 Users Say Thank You to tang For This Useful Post:
Calidecks (09-20-2020), deckman22 (09-20-2020), greg24k (09-20-2020)
