How To Build A Deck 7 Ft High Without Lateral Bracing - Page 2 - Decks & Fencing - Contractor Talk
Old 07-12-2015, 10:07 PM   #21
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
Re: How To Build A Deck 7 Ft High Without Lateral Bracing
Instead of nailing a diagonal to the underside of the joists, run a set of diagonal blocking from each corner of the deck from the house connection side.
Takes a bit longer, but is cleaner looking (especially if the owners will be walking under there), and I think it is more effective as bracing. Nailing the brace under the deck, the nails could rust and work themselves free.
jlhaslip is offline
The Following User Says Thank You to jlhaslip For This Useful Post:
hdavis (07-12-2015)
Old 07-12-2015, 10:37 PM   #22
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,238
That's why you dont use nails you would use fastenmaster screws.
Calidecks is online now
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
EthanB (07-13-2015), ghhartmann (07-13-2015)
Old 07-12-2015, 11:01 PM   #23
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
I am not convinced that little blocks will have as much strength as 1 continuous board.
killerdecks is offline
The Following 3 Users Say Thank You to killerdecks For This Useful Post:
Calidecks (07-12-2015), EthanB (07-13-2015), Rio (07-16-2015)
Old 07-13-2015, 05:12 AM   #24
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
The connection to the piers could provide lateral strength .
I have a couple out fastened with custom U shaped brackets made up out of 1 / 2 '' steel flat stock, welded on both sides, 24 '' high. Bolted down to the pier with glav threaded rod and two part Hilti epoxy, then through bolted into the post / bracket .
They are both free standing with 0 movement. 10' high or so no lateral braces at all.
The cost is not bad, my hot rod welder Bud charges me $75 per. I prime / paint them black just for looks but really it would take a forever long time for them to rust out.
John www.deckmastersllc.com
John Hyatt is offline
Old 07-13-2015, 06:38 AM   #25
Rhode Island's Avatar
Trade: Genral Contractor
Rewards Points: 264
Originally Posted by EthanB View Post
None of the jurisdictions in my part of RI will let you bury posts. The diagonal bracing on the underside of the joists should fly though. Any reason you can't use knee bracing other than the HO's "aesthetics"?
What town are you dealing with?
Do you mean below grade burying? I never do decks, but a family member wants a face lift on their existing deck. Nothing major, some new stringers/treads/decking....but I wanted to get the posts off the ground. My first thought was dig out footings and and set the posts in them. Have the footing 24" off the ground so the posts don't sit in the water and snow anymore.
Like I said I don't do decks and don't mean to hijack the thread. This is in Bristol which couldn't be any further for me to go in RI!
Rhode Island is offline
Old 07-13-2015, 09:30 AM   #26
hdavis's Avatar
Rewards Points: 2,184
This depends a lot on connection and stress details. Fixed to the underside, it's all shear. Diagonal blocking is mixed shear plus pull out. The blocks should be stronger for the same number and type of fasteners if it's all done tight.
Personally, solid blocking would be holding moisture against the side of the joist - I'm not a fan of that and the extra work to do it.
hdavis is online now
Old 07-13-2015, 01:11 PM   #27
GettingBy's Avatar
Rewards Points: 6,486
If an adult stands with feet apart and rocks his weight over one leg and then the other, parallel to the house side, it will put lateral forces on the deck.
Have another person standing on the far edge of the deck as a "sensor".
IDK how much deflection at the top of the posts is normal for this condition. I'd think a quarter inch would get people upset but it may be more important as to what the other person senses.
How much wobbling should you see for a deck on two story posts?
See
http://www.google.com/search?client=...UTF-8&oe=UTF-8
GettingBy is offline
Old 07-13-2015, 02:05 PM   #28
GC/carpenter
Calidecks's Avatar
Here's an engineered detail because a client didn't want knee braces on one of my balconies.
CarpenterSFO (07-13-2015), hdavis (07-13-2015), Rio (07-16-2015)
Old 07-13-2015, 07:18 PM   #29
TG Deck's Avatar
Trade: exterior carpentry
Rewards Points: 1,770
Fastenmaster,, of course.
I forgot.....
TG Deck is offline
Old 07-13-2015, 07:28 PM   #30
GC/carpenter
Calidecks's Avatar
I forgot.....
I'm really not sure what your point is.
There's a lot of guys on this forum who like Fastenmaster. I'm in no way affiliated with them nor do I get special favors from them. They are a huge benefit to my company and deserve any and all kudos I can give. They have earned my business and my respect.
Old 07-14-2015, 11:27 AM   #31
jlhaslip's Avatar
Rewards Points: 196
Thanks for the pointer about using those screws. I have used them for decking.
Problem with using screws to mount the diagonal blocking is that screws are not allowed as per the Building Code except for attaching subfloor and mounting drywall. Nails everywhere else.
jlhaslip is offline
Old 07-14-2015, 12:27 PM   #32
GC/carpenter
Calidecks's Avatar
I'm pretty sure these would be more than allowed in most jurisdictions.
Old 07-14-2015, 01:02 PM   #33
deck aficionado
SelectDecks's Avatar
Trade: General Building
Rewards Points: 973
Wait, your local code folks adopted their own code no not allow screws anywhere on a deck? Nice
James
www.selectdecks.com
SelectDecks is offline
Old 07-14-2015, 01:10 PM   #34
hdavis's Avatar
He's in Canada, who knows...
Old 07-14-2015, 01:55 PM   #35
GettingBy's Avatar
FWIW,
A deck diagonal dim is 20'.
An aluminum angle 1/8" thk x 3" x 3" x 20' is clamped between the deck boards and the joists by the fasteners and so this metal angle can resist buckling extremely well, better than a free standing angle.
You can only see the angle from underneath.
For 30 degree angle between the metal and the 1.5" thk joists, the slot length would be slightly over 1.7", the slot depth = 3" and there are as many slots as joists.
Alternatively you could put a 20' x 3/8" thk wood strip under the deck boards but each board would have to notched.
Old 07-14-2015, 02:08 PM   #36
GC/carpenter
Calidecks's Avatar
Originally Posted by GettingBy View Post
FWIW,
So how do you keep the the deck boards flat where they lay on a nailed strap. Notch all the joists and let in the strap?
Old 07-14-2015, 02:56 PM   #37
GettingBy's Avatar
They are slightly not flat, but if that's objectionable . . .
The tops of the joists are in compression.
If you fill a notch in a joist top with an incompressible material then the joist bending resistance is not compromised, at least in principle. The notch cannot begin to close.
Another way is to lay 1/8" strips of almost any width on the joist tops so that they keep the deck boards perfectly flat.
To be fair, note that I have worked on only two decks in my whole life, and one I screwed up and charged the HO nothing.
Old 07-14-2015, 03:35 PM   #38
CarpenterSFO's Avatar
Rewards Points: 2,044
- Bob
CarpenterSFO is offline
Old 07-14-2015, 04:34 PM   #39
madmax718's Avatar
Trade: General
Rewards Points: 3,276
I'll leave the deck expertise to you guys who build decks on the regular, but anytime you make a notch/cut into the tops or bottoms of the wood you significantly weaken it. Not to mention the PT used nowadays doesn't last nor penetrate that deeply, so yet another area where rot and damage can form more easily.
madmax718 is offline
The Following User Says Thank You to madmax718 For This Useful Post:
Calidecks (07-14-2015)
Old 07-14-2015, 04:39 PM   #40
madmax718's Avatar
Trade: General
Well, thats.. interesting. But why go with the angle iron, when they could have just gone with a 30" box. Angle iron still has significantly more deflection than the box, and they specify it for a full 10" depth anyways.
Estimating with Excel for the Small Contractor YouTube cargin2 Business 127 12-09-2019 12:06 PM
Custom Bar Build... Rich D. Finish Carpentry 63 11-06-2013 10:59 PM
Summer deck projects C2projects Decks & Fencing 149 01-16-2013 12:24 AM
Deck Railing FinishingEdge Decks & Fencing 27 11-04-2012 05:09 PM
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 06:43 PM
