How To Build A Deck 7 Ft High Without Lateral Bracing - Decks & Fencing - Contractor Talk
Old 07-10-2015, 07:39 PM   #1
Smithanator's Avatar
Trade: General contractor
Rewards Points: 274
Is there any way to build a deck 7 ft high attached to house 16' out without lateral bracing?
Smithanator is offline
Old 07-10-2015, 07:46 PM   #2
deck aficionado
SelectDecks's Avatar
Trade: General Building
Rewards Points: 973
Re: How To Build A Deck 7 Ft High Without Lateral Bracing
Yep put a 6x6 post about every 7' across your beam and bury those suckers about 3' each.....how wide?
James
www.selectdecks.com
SelectDecks is offline
Old 07-10-2015, 07:49 PM   #3
Rewards Points: 274
18 ft ... Was hoping to use top mounted brackets on footing
Old 07-10-2015, 07:52 PM   #4
Homebuilders Draftsman
TJDavis's Avatar
Trade: Architectural Draftsman
Rewards Points: 150
Yep, 6x6 pressure treated minimum...
If anyway will do, no way will do just as well!!!
TJDavis is offline
Old 07-10-2015, 08:01 PM   #5
TG Deck's Avatar
Trade: exterior carpentry
Rewards Points: 1,770
The lateral strength will be tremendously greater if you put them below ground.
J bolts with bottom post mounts suck big ones....
If you are able to sheath/skirt just below the top, you will add much strength.
Make it decorative.
TG Deck is offline
Old 07-10-2015, 08:09 PM   #6
GC/carpenter
Calidecks's Avatar
Rewards Points: 2,862
Running your deck boards at 45 degrees will help with lateral bracing. You could also run a brace diagonally on the bottom of the joists as well.
Calidecks is online now
aptpupil (07-10-2015), concretemasonry (07-18-2015), JAH (07-13-2015)
Old 07-10-2015, 08:16 PM   #7
Rewards Points: 274
Running azek boards with house face screwing should help with lateral movement as well right?
Old 07-10-2015, 08:19 PM   #8
CITY DECKS INC's Avatar
Trade: DECK BUILDER. RESIDENTIAL. COMMERCIAL
Rewards Points: 4,608
ask killer
CITY DECKS INC is offline
Old 07-10-2015, 08:23 PM   #9
GC/carpenter
Calidecks's Avatar
I don't think your going to get much support from pvc. Although every little bit helps. Brace the joist bottoms and flag pole the posts will go along way.
hdavis (07-10-2015)
Old 07-10-2015, 08:27 PM   #10
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 144
Mike nailed it - run the boards diagonally , double rim boards glued & screwed
As for the posts - I would go with PBA myself, never have been a fan of buried posts
SLSTech is offline
Old 07-10-2015, 08:30 PM   #11
hdavis's Avatar
Rewards Points: 1,546
This.
hdavis is online now
Old 07-10-2015, 08:35 PM   #12
GC/carpenter
Calidecks's Avatar
Another thing worth mentioning is if you are in an active seismic zone you may want to consider steel posts with buckets welded to the tops.
If you use wood posts the Simpson CCQ66SDS buckets help as well.
Old 07-11-2015, 12:07 AM   #13
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
flag pole footings
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 07-11-2015, 12:16 AM   #14
Talking Head
EthanB's Avatar
Rewards Points: 378
None of the jurisdictions in my part of RI will let you bury posts. The diagonal bracing on the underside of the joists should fly though. Any reason you can't use knee bracing other than the HO's "aesthetics"?
What town are you dealing with?
Planer.....
EthanB is offline
Old 07-11-2015, 06:06 PM   #15
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
Originally Posted by CITY DECKS INC View Post
ask killer
I dig holes 56" deep 12" diameter, bury them, if you use composite nail a 2x6 diagonally on the underside of the joists the opposite way ur decking is going, always put your deck boards down diagonally
killerdecks is offline
The Following User Says Thank You to killerdecks For This Useful Post:
Old 07-11-2015, 06:29 PM   #16
CarpenterSFO's Avatar
Rewards Points: 2,044
Most any structural problem, I at least price the steel option.
- Bob
CarpenterSFO is offline
Old 07-12-2015, 09:29 AM   #17
GettingBy's Avatar
Rewards Points: 6,486
How much lateral force are decks subjected to? The downward force is easy to figure. I assume uplift force is zero.
GettingBy is offline
Old 07-12-2015, 10:47 AM   #18
colevalleytim's Avatar
Trade: general contractor
Rewards Points: 390
Depends on you location. In a seismic area, uplift is something to think about. Also, how windy is the area?
colevalleytim is offline
The Following User Says Thank You to colevalleytim For This Useful Post:
GettingBy (07-12-2015)
Old 07-12-2015, 11:13 AM   #19
SamM's Avatar
Trade: Carpenter/Handyman
Rewards Points: 1,484
Depends on location and structure. I assume at least some upward force in most of my decks to account for the occasional hurricane.
Your Dreams won't work unless you do.
SamM is offline
The Following User Says Thank You to SamM For This Useful Post:
Old 07-12-2015, 06:09 PM   #20
TG Deck's Avatar
Regulations on the coast in my area are pretty extreme now.
You're building a brick sht house even if it's a small ground-level deck, if in a wind area.
You can see pics of Bolivar peninsula beach homes before and after hurricane Ike. Lots of 2 story decks standing proud...and the house is totally f'ing gone....
TG Deck is offline
Estimating with Excel for the Small Contractor YouTube cargin2 Business 127 12-09-2019 12:06 PM
Custom Bar Build... Rich D. Finish Carpentry 63 11-06-2013 10:59 PM
Summer deck projects C2projects Decks & Fencing 149 01-16-2013 12:24 AM
Deck Railing FinishingEdge Decks & Fencing 27 11-04-2012 05:09 PM
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 06:43 PM
