Has Anyone Ever Heard Of This? - Decks & Fencing - Contractor Talk
Old 02-16-2016, 08:59 PM   #1
kprestige3335's Avatar
Trade: Fence
Rewards Points: 36
I am a fence contractor. We recently installed a 1"x4" Cedar T&G fence in late Nov. We had the fence stained prior to installation. As we were completing the job, we noticed tremendous buckling of most of the panels. My manufacturer blames my painter (that it should've dried out first) & my painter blames my manufacturer (not leaving enough room for expansion). Note - Not all of the panels did this but most of them did.
Has anyone ever heard of this?
I do know that we had great weather around the time of the staining but there were a few nights that the temp dropped to the 30's. My painter told me the lumber came wet. He would dry it in his garage with heaters overnight & then stain them. He'd then store the panels outside once completed.
Could this severe buckling be due to:
1.The fence being too wet and the boards expanded when the temp dropped below 32 degrees?
2.The stain applied over wet wood and sealed in moisture which then expanded when the temp dropped below 32 degrees?
3. A manufacturer defect?
Any input would be great..Thanks.
kprestige3335 is offline
Old 02-16-2016, 09:09 PM   #2
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Has Anyone Ever Heard Of This?
not a fence installer but i never heard of wood fence buckling from stain..
Tom Struble is offline
Old 02-16-2016, 09:23 PM   #3
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 16,512
Stain wouldn't "seal" in moisture unless there was a vigorously applied topcoat sealant. Like, shellac.
I'm more inclined to side with your painter's opinion of them not leaving room for expansion.
Pictures?
Easy Gibson is offline
Old 02-16-2016, 09:26 PM   #4
avenge's Avatar
Rewards Points: 130
What kind of stain, solid, semi? If the wood was that wet that the painter tried to dry them then there was too much moisture content to stain them. But I don't think that's what caused the buckling the wood was simply too wet to install period.
avenge is offline
The Following 3 Users Say Thank You to avenge For This Useful Post:
CarpenterSFO (02-18-2016), Easy Gibson (02-16-2016), ryan71 (02-21-2016)
Old 02-16-2016, 09:49 PM   #5
antonioooooooo's Avatar
Trade: framing, finishing.
Rewards Points: 429
I stained a large anount of cedar boards (5/4s) and 2x4s once. Before I stained them they were noticeably wet. I stained them anyways and left them to dry in a heated shop for over a week, and still the boards were wet to the touch. Ended up installing them TIGHT together for a fence, and on the first downpour, everything swelled and shifted bad. Had to remove boards and leave a bit of space for expansion. Bosses orders BTW!
antonioooooooo is offline
The Following User Says Thank You to antonioooooooo For This Useful Post:
kprestige3335 (02-18-2016)
Old 02-16-2016, 11:05 PM   #6
Trade: Fence
Rewards Points: 36
Stain was semi solid Benjamin Moores (not cheap). Areas below which appear to be sunlight are actually buckles in the fence.
Has anyone ever heard of this?-20151228_130739_90668841595057_15433_1455681772525.jpg
Old 02-17-2016, 02:59 PM   #7
Trade: Fence
Rewards Points: 36
Semi Solid Benjamin Moores (not cheap)
Old 02-17-2016, 03:03 PM   #8
Trade: Fence
Rewards Points: 36
Old 02-17-2016, 04:40 PM   #9
Radical Basement Dweller
Robie's Avatar
Rewards Points: 8,148
Didn't you just post this yesterday?
You're a fence contractor?
http://www.contractortalk.com/f11/rare-problem-257369/
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is online now
Old 02-17-2016, 04:54 PM   #10
avenge's Avatar
Rewards Points: 130
Ya obviously you want us to hear it again.
avenge is offline
Old 02-17-2016, 05:07 PM   #11
Trade: siding
Rewards Points: 20
coulda had it fixed by now..
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
Calidecks (02-17-2016), Robie (02-17-2016)
Old 02-17-2016, 05:26 PM   #12
mako1's Avatar
Rewards Points: 1,094
You or the painter one should know you can't dry lumber with a high moisture content in a garage with a heater overnight.
mako1 is offline
The Following 3 Users Say Thank You to mako1 For This Useful Post:
aptpupil (02-19-2016), CarpenterSFO (02-18-2016), philcav7 (02-18-2016)
Old 02-17-2016, 05:40 PM   #13
Trade: Fence
Rewards Points: 36
My bad. I posted it yesterday under General discussion. I thought I"d post it today in a different group to see if anyone else had an opinion. Didn't realize everyone can see it. New here. But thanks for your advice. You sound like a real jerk off :relaxed:
Old 02-17-2016, 05:44 PM   #14
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,886
Originally Posted by kprestige3335 View Post
My bad. I posted it yesterday under General discussion. I thought I"d post it today in a different group to see if anyone else had an opinion. Didn't realize everyone can see it. New here. But that's for your advice. You sound like a real jerk off :relaxed:
If you can see it, we can see it.
Aztec Decks
Oshawa deck builder
heavy_d is offline
The Following User Says Thank You to heavy_d For This Useful Post:
Old 02-17-2016, 05:44 PM   #15
Robie's Avatar
I can be.
Mark Twain
Robie is online now
The Following 4 Users Say Thank You to Robie For This Useful Post:
m1911 (02-18-2016), sunkist (02-18-2016), TNTRenovate (02-18-2016), Tom Struble (02-17-2016)
Old 02-17-2016, 05:45 PM   #16
Dan_Watson's Avatar
Rewards Points: 2,748
Good luck.
Dan_Watson is offline
The Following User Says Thank You to Dan_Watson For This Useful Post:
Old 02-17-2016, 05:52 PM   #17
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Originally Posted by Robie View Post
I can be.
So, you got the SI calendar then?
SmallTownGuy is offline
Old 02-17-2016, 05:57 PM   #18
Robie's Avatar
I'm behind on my subscription....
Mark Twain
Robie is online now
Old 02-17-2016, 06:07 PM   #19
John the Builder
It's not going to be on NetFlix if you were waiting for that option...
Old 02-17-2016, 06:15 PM   #20
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 460
Threads merged. Please do not start multiple threads with the same subject.
And lighten up on the name calling until we give you the secret fraternity handshake.
Tinstaafl is offline
Has anyone heard of "Hercules" decking material? Fence & Deck Decks & Fencing 9 07-21-2013 09:18 PM
You could have heard a pin drop Willie T Off Topic (Non Trade) 5 08-10-2011 09:30 PM
has any one heard of a company called contractor trades. GoodGuyscc Online Leads Services 8 07-28-2011 11:50 AM
Have you heard this one? SK Remodeling Masonry 123 03-20-2009 06:22 PM
Ever heard of electric radiant floor heat under slab? IHI HVAC 10 02-27-2009 05:32 PM
