Hanging Stringers - Decks & Fencing - Contractor Talk
Hanging Stringers
Old 07-14-2015, 09:08 PM   #1
JAH's Avatar
Trade: carpenter
Rewards Points: 1,910
Hanging Stringers
I have always viewed the stringer / deck connection as a weak link when building taller deck stairs. Im interested in finding out how other contractors hang their stringers.
I use a piece of 3/4 pt ply. It gets fastened to the back of the double flush beam with 3 1/4 nails and 4 headlocks. The stringer gets fastened to the ply with 4, 3 /2 nails per stringer, through the back.
JAH is offline
Old 07-14-2015, 09:36 PM   #2
deck aficionado
SelectDecks's Avatar
Trade: General Building
Rewards Points: 973
Re: Hanging Stringers
This opens up a rather large can of worms
James
www.selectdecks.com
SelectDecks is offline
The Following 2 Users Say Thank You to SelectDecks For This Useful Post:
hdavis (07-14-2015), JT Wood (07-14-2015)
Old 07-14-2015, 10:32 PM   #3
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
2 l70s on each side of the steel stringer. But then again I'm not normal.
RobertCDF is offline
Old 07-14-2015, 10:40 PM   #4
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
I use a sky crane
killerdecks is offline
Old 07-14-2015, 11:05 PM   #5
GC/carpenter
Calidecks's Avatar
Rewards Points: 3,008
How do you keep the ply from rotting?
Calidecks is online now
parkers5150 (07-24-2015)
Old 07-14-2015, 11:06 PM   #6
GC/carpenter
Calidecks's Avatar
Sorry I didn't take my time and read your post. I see you wrote PT.
Old 07-14-2015, 11:10 PM   #7
GC/carpenter
Calidecks's Avatar
I build a wall so to speak, that my stairs lean against. The weight isn't all on the deck side. It's also carried by the landing at the bottom.
Old 07-15-2015, 07:51 AM   #8
General Contractor
greg24k's Avatar
Rewards Points: 8,478
There is a few ways of doing it. one is you cut your stringer adding an extra tread, make a notch and go under it fastening to the joist. Using 2x12 stringer you maintaining more than 5" min requirement between the tread and the bottom of the stringer.
Another way is to add blocking to the joist or extend a 4x4 post and add 2x to provide solid back support for the stringer.
Here is something to give you an idea.
greg24k is online now
The Following 5 Users Say Thank You to greg24k For This Useful Post:
aptpupil (07-16-2015), CITY DECKS INC (07-20-2015), festerized (07-15-2015), hdavis (07-15-2015), Rio (07-15-2015)
Old 07-15-2015, 08:21 AM   #9
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
I found extending the 4x4 below works best
festerized is offline
The Following 9 Users Say Thank You to festerized For This Useful Post:
aptpupil (07-16-2015), Big Shoe (07-16-2015), CITY DECKS INC (07-20-2015), EthanB (07-24-2015), greg24k (07-15-2015), pathbuilder (02-08-2019), Rio (07-15-2015), Tom M (07-15-2015), Windwash (07-15-2015)
Old 07-15-2015, 03:54 PM   #10
deck aficionado
Rewards Points: 973
As a quick fyi, can only do this if you're deck framing is less than 2x10s...the inside mount I'm talking about
James
www.selectdecks.com
The Following User Says Thank You to SelectDecks For This Useful Post:
Rio (07-15-2015)
Old 07-15-2015, 04:23 PM   #11
JAH's Avatar
Trade: carpenter
Originally Posted by killerdecks View Post
I use a sky crane
You mean a sky Hook?
JAH is offline
Old 07-15-2015, 04:30 PM   #12
JAH's Avatar
Trade: carpenter
Im going to give this technique a try with the next deck. Most of the decks you see around here the stringers are held in place with pieces of vertical 5/4 x 6 decking.
Anyone use Simpson LSC adjustable stair stringer connector?
JAH is offline
Old 07-15-2015, 04:52 PM   #13
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
that's how I do it.
a few ledger locks and stair hanger..
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
The Following 2 Users Say Thank You to jaydee For This Useful Post:
festerized (07-15-2015), pathbuilder (02-08-2019)
Old 07-15-2015, 04:58 PM   #14
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
sky something or other
Old 07-15-2015, 07:10 PM   #15
hdavis's Avatar
Rewards Points: 1,556
hdavis is offline
Old 07-15-2015, 08:07 PM   #16
Tom M's Avatar
Rewards Points: 7,320
Same here
Tom M is online now
festerized (07-16-2015)
Old 07-16-2015, 12:11 AM   #17
tipitop's Avatar
Trade: carpenter
Rewards Points: 3,873
This because inspectors ban me use 3/4 plywood and use metal strips. Virtually do not know other way. If would this be banned to I would give up at stairs.
tipitop is offline
Old 07-16-2015, 12:20 AM   #18
GC/carpenter
Calidecks's Avatar
Translated:
The inspector prohibits the use of 3/4 ply and metal straps. And if he decided to fail this, I'd give up on building stairs, because I don't know another way.
The Following 5 Users Say Thank You to Calidecks For This Useful Post:
asevereid (07-16-2015), Big Shoe (07-16-2015), kiteman (07-16-2015), madmax718 (07-16-2015), Rio (07-24-2015)
Old 07-16-2015, 04:34 AM   #19
Big Shoe's Avatar
Rewards Points: 2,066
Can't use pylwood on interior stringer system ???????? Something is not right there.
As far as exterior goes..............Festerized gets my vote.
Expect the Unexpected
Big Shoe is offline
Old 07-16-2015, 04:50 AM   #20
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Far as outside work goes, plywood of any kind ,pt or not, will react the same way exposed to the weather. It will delam .
Marine plywood is not meant to be exposed to the weather it will come apart the same as any other plywood. Marine plywood is made for strength/sheer , no knots in the plys.
John www.deckmastersllc.com
John Hyatt is offline
The Following 3 Users Say Thank You to John Hyatt For This Useful Post:
aptpupil (07-16-2015), Nick R (07-16-2015), Tom M (07-16-2015)
Hanging stuff on walls - best methods MarkJames General Discussion 22 05-22-2013 07:27 PM
Hanging it up stacker Masonry 13 05-02-2013 05:48 PM
Proper Hanging Methods FatherDuctwork HVAC 7 08-27-2012 07:28 PM
Hanging stair stringers using new Simpson thingy UpNorth Framing 29 10-20-2010 09:43 PM
Bamboo on stairs with warped stringers tgeliot Flooring 6 11-02-2008 12:35 PM
