Ground Level Curved Deck - Decks & Fencing - Contractor Talk
Old 01-30-2016, 11:04 AM   #1
Stunt Carpenter's Avatar
Rewards Points: 2,318
I'm going to build myself and ground level deck this year and have been tossing around the idea of putting a curve on the front the only problem is my wife doesn't want it more than one step up on to the deck.
This would mean that I would need a flush beam not a drop beam but I have only build curved decks on drop beams before.
Is there anyway to do this that I am over looking?
Thanks
builddaley.com
https://builddaley.com/
Stunt Carpenter is online now
Old 01-30-2016, 11:05 AM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,074
Re: Ground Level Curved Deck
That's easy, get a new wife.
Inner10 is offline
The Following 6 Users Say Thank You to Inner10 For This Useful Post:
CENTERLINE MV (01-30-2016), EricBrancard (01-30-2016), Fouthgeneration (01-30-2016), killerdecks (01-30-2016), m1911 (01-31-2016), WarnerConstInc. (01-30-2016)
Old 01-30-2016, 11:29 AM   #3
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 978
Do what I do, just build it the way you want to and shrug your shoulders when it's done.
EricBrancard is online now
The Following 2 Users Say Thank You to EricBrancard For This Useful Post:
m1911 (01-31-2016), SmallTownGuy (02-01-2016)
Old 01-30-2016, 11:39 AM   #4
Dan_Watson's Avatar
Rewards Points: 2,748
Where are you located?
Dan_Watson is offline
Old 01-30-2016, 11:39 AM   #5
Dan_Watson's Avatar
Build it freestanding, right on the ground. Dig out, fabric and stone, build.
Old 01-30-2016, 11:51 AM   #6
I'm in Alberta Canada. The problem with building right on the ground is the frost we get here would destroy it
builddaley.com
Old 01-30-2016, 11:57 AM   #7
Dan_Watson's Avatar
builddaley.com
Thats where I thought you were from.
Build it with steel, flush beams from the field and where it is curved switch to a much small joist, closer spacing with a drop beam. Going to be some shallow but beefy joists and beams but it will definitely work.
Old 01-30-2016, 01:47 PM   #8
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,230
Interesting problem.
Could you do a grade beam on piers out of concrete as your "beam" then then run your joists on that. You'd have to put something under the grade beam to allow for frost heave, like FrostCusion or something.
http://www.beaverplastics.com/Geotec...stCushion.html
Without ventilation under the deck though, wont it just rot anyways?
Philament is offline
The Following User Says Thank You to Philament For This Useful Post:
Old 01-30-2016, 01:52 PM   #9
Chris G's Avatar
Trade: Porch and Deck Builder
Rewards Points: 1,210
I usually trench for the beams. Dig for piers as usual. Line the trench with barrier cloth. Toss in 2 or 3 inches of gravel on top of cloth. Place beam on saddle/concrete pier.
I can not emphasize how stupid I really am
http://www.vicporch.ca
Chris G is offline
The Following User Says Thank You to Chris G For This Useful Post:
Texas Wax (01-30-2016)
Old 01-30-2016, 02:26 PM   #10
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,403
Pour a continuous frost foundation, dig a crawl space, ground fabric, washed rock, maybe drain tile to sump, cover with ground level + 6" high deck. The stoop walls being your "drop' beams, PT wood or galvanized steel on house foundation wall for ledger board.
A real cheapster would just trench a footing, pour and then excavate the crawl space.... And the curve the footer of course, cantilever the deck to hide the footings?
Or pour a floating slab on Raised grade, with a thicken edge for the perimeter step, install sleepers, deck "boards" if you gotta have wood decking.
If you have a lot of $, make a full height basement addition/"fruit cellar addition which include a cellar stairway/ fire egress.
A 'Gun Vault' south of the border.
Fouthgeneration is offline
Old 01-30-2016, 02:35 PM   #11
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Decks, Additions
Rewards Points: 14,468
Sonotubes. http://www.contractortalk.com/f50/radius-steps-123487/
A&E Exteriors is online now
Old 01-30-2016, 02:35 PM   #12
Not all ground level but the step and sunroom is
Old 01-30-2016, 07:16 PM   #13
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
[QUOTE=Fouthgeneration;4234881]
I like this, A continuous radius trench footing would allow you to put the frame right on it.
killerdecks is offline
The Following User Says Thank You to killerdecks For This Useful Post:
Calidecks (01-31-2016)
Old 01-31-2016, 12:05 AM   #14
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,172
[quote=killerdecks;4236321]
You could install a pt sleeper/nailer embedded or on top the footing
Calidecks is online now
Old 01-31-2016, 12:10 PM   #15
CITY DECKS INC's Avatar
Trade: DECK BUILDER. RESIDENTIAL. COMMERCIAL
Rewards Points: 4,608
[quote=Californiadecks;4237897]
maybe 4x6 on level gravel bed (6")...? like jonman would chime in say copper green..2 quick coats and get building. No picts.. You know your environment better then we do and remember happy wife happy life.
CITY DECKS INC is offline
Old 01-31-2016, 04:48 PM   #16
I think I'll go with grade beams. Sounds like it's the best option
builddaley.com
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
A&E Exteriors (01-31-2016)
Old 01-31-2016, 07:30 PM   #17
TG Deck's Avatar
Trade: exterior carpentry
Rewards Points: 1,770
Depends on how serious you want to take it...
If its a small deck, you could simply float it on cap blocks and let it heave as it desires.
Composite deck boards work well for the outside curve you might want. No kerf cuts needed...
TG Deck is offline
Old 02-01-2016, 06:41 AM   #18
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
How big ?
If this is a small project the curve frame could be shop built. I am big on laminations for curves not angles with the decking hung over and cut to a radius.
And like the City Mon said Copper Green retreatment.
There are a few curved projects low to the ground on my Site.
J. www.deckmastersllc.com
John Hyatt is offline
Old 02-01-2016, 09:54 AM   #19
It's going to be about 14 wide and 12 deep with one end attached to my garage
builddaley.com
Old 02-01-2016, 12:52 PM   #20
Inner10's Avatar
builddaley.com
12 deep, sounds more like a swimming pool.
Inner10 is offline
How low to the ground can I get this deck? Easy Gibson Decks & Fencing 76 11-04-2016 11:31 PM
Deck Building Steps jaymelone Decks & Fencing 28 07-28-2010 10:56 PM
curved deck greggmig Decks & Fencing 22 09-12-2008 07:49 AM
