Got A Bite On A Swimming Pool Deck - Decks & Fencing - Contractor Talk
Old 04-23-2019, 10:58 PM   #1
back doors to hell put in
Irishslave's Avatar
Rewards Points: 1,314
1/4 of the circumference need framing ideas with minimum amount of footers. There's a conc wall to attach ledger to so thaat end is covered. Just a little foggy about how to butt the pool. I got an idea with 2 beams i long and 1 short.
Decking over the pool ledge or under?
Throw the ideas out please
Irishslave is offline
Old 04-23-2019, 11:01 PM   #2
Designer/Contractor
Rio's Avatar
Rewards Points: 1,292
Re: Got A Bite On A Swimming Pool Deck
If you have some photos of the area it would help visualize possibilities........
Rio is offline
The Following 2 Users Say Thank You to Rio For This Useful Post:
ScipioAfricanus (04-24-2019), talbit1 (04-30-2019)
Old 04-23-2019, 11:08 PM   #3
Irishslave's Avatar
I'll get them in the next couple of days and post them. This is not my ideal project but I landed it so. I just want simplicity. I hate those designs with footing overkill
The Following User Says Thank You to Irishslave For This Useful Post:
Rio (04-24-2019)
Old 04-23-2019, 11:57 PM   #4
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,266
I've built two decks over pool coping. I'll see if I can dig them up.
Mike.
_______________
Calidecks is offline
Old 04-24-2019, 07:30 AM   #5
tjbnwi's Avatar
Rewards Points: 4,770
I’ve done over and under, either way you need to leave room for the cover to be installed. I liked the look of under better.
tjbnwi is online now
Old 04-24-2019, 07:41 AM   #6
Joe Wood's Avatar
Rewards Points: 904
I did this one a long time ago. We had to scribe and cut the underside of the joists to fit over the little bump on the pool deck's edge. I'll try and find those pics but I doubt I can, way before digital cameras.
Joe Wood is online now
The Following User Says Thank You to Joe Wood For This Useful Post:
Rio (04-24-2019)
Old 04-24-2019, 07:55 AM   #7
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 7,644
I made some crazy coping out of wood last year. Bent Ipe around the pool edge and did a ribbon around the pool. Looks really cool.
As far as framing... Beam under joists and cantilever. Block the ends and you're good.
‘ugly and inaccurate because our thoughts are foolish, but the slovenliness of our language makes it easier for us to have foolish thoughts.’ -George Orwell
Deckhead is online now
Old 04-24-2019, 12:27 PM   #8
GC/carpenter
Calidecks's Avatar
Mike.
_______________
Rio (04-24-2019)
Old 04-24-2019, 12:41 PM   #9
Irishslave's Avatar
over or under with decking?
Old 04-24-2019, 12:42 PM   #10
Irishslave's Avatar
Originally Posted by Calidecks View Post
Mike.
_______________
This is the dilemma with going over. I have to fashion a curved ribbon.
Old 04-24-2019, 01:44 PM   #11
GC/carpenter
Calidecks's Avatar
https://www.deckmagazine.com/design-...tting-curves_o
Mike.
_______________
Old 04-25-2019, 12:23 PM   #12
Irishslave's Avatar
The top few rows of brick can be removed and there's a conc wall behind to mount the ledger
I was just informed today he wants composite. I hate composite. Mike loves it.
It will basically be the area where the brick is back to the pool.
I will need to figure the composite w/o a lot of waste. It only comes in 16' and the main body is 10x12 with that leg going around the side. Maybe I get a little design happy with the decking configuration? Either way I'm going under the coping I think.
Old 04-25-2019, 12:25 PM   #13
Irishslave's Avatar
Old 04-25-2019, 12:27 PM   #14
Irishslave's Avatar
Old 04-25-2019, 11:54 PM   #15
deckman22's Avatar
Trade: Retired Deck Builder
Rewards Points: 5,354
Always go below on above ground pools. If you go above it makes for real pita to change the liner.
Deckman
deckman22 is online now
The Following 3 Users Say Thank You to deckman22 For This Useful Post:
Calidecks (04-26-2019), Deckhead (04-26-2019), Irishslave (04-25-2019)
Old 04-29-2019, 10:56 PM   #16
Irishslave's Avatar
Allright what do I do with composite on the steps if it has those grooves in it?
I hate composite.
Old 04-29-2019, 11:03 PM   #17
deckman22's Avatar
I hate composite.
Use a brand that has non-grooved boards, most of them did when I was still at it.
Deckman
The Following User Says Thank You to deckman22 For This Useful Post:
Bull Trout (04-29-2019)
Old 04-29-2019, 11:08 PM   #18
Irishslave's Avatar
Should I go with 12 or 16 centers? I already know I have to knock all the crowns down to avoid any waving.
Old 04-29-2019, 11:43 PM   #19
Bull Trout's Avatar
Rewards Points: 136
Laying perpendicular to joists or at an angle? Which product are you using?
Bull Trout is offline
Old 04-29-2019, 11:50 PM   #20
GC/carpenter
Calidecks's Avatar
Use square edge for the ends. If the boards are perpendicular, 16 inch centers.
Mike.
_______________
Putting a deck around the pool nmirse Framing 5 07-21-2014 02:31 PM
Maryland - swimming pool plumbing kbelz67 Plumbing 1 06-24-2014 09:12 PM
Deck Construction @ Winery: Review Our Plans? dutchswan General Discussion 14 05-23-2013 12:14 PM
Deck and porch framed maleko Decks & Fencing 179 09-19-2012 09:16 PM
swimming pool deck kodama Decks & Fencing 9 07-16-2010 09:51 PM
