Gate Latches - Decks & Fencing - Contractor Talk
Gate Latches
Old 05-27-2019, 02:27 AM   #1
BlueNails's Avatar
Rewards Points: 34
Gate Latches
Hey my fence pro Bros!
Wondering what the best looking solution for keeping your pickets/pailing on the same plane while having a standard gate latch work without it looking unsightly from the B-side.
Attached some images for clarity.
Obviously it's closer with rails between posts and a tidy tapered block would work. I kinda think I'm missing something here.
What do you do?
BlueNails is offline
Old 05-27-2019, 11:58 AM   #2
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,886
Re: Gate Latches
#1 put hinges and latch on other side .gate opens wider this way .
#2 different type latch .Search the isles of the local hardware store or online supply .not finding the one i have used in the past .though some cost more .which will improve the look anyhow and your work looks better
you could use a simple bolt latch .https://images.search.yahoo.com/sear...g&action=click
JFM constr is offline
Old 05-28-2019, 04:18 AM   #3
BlueNails's Avatar
Rewards Points: 34
Re: Gate Latches
Didn't want to have anything on the A-side. After a bit more thinking I ended up thinking about runnings the rails past the post to attach the latch to. So can use any off the shelf latch without packing gate out or any fugly stuff.
Old 05-28-2019, 03:22 PM   #4
Stunt Carpenter's Avatar
Rewards Points: 1,660
Re: Gate Latches
I use these for gates. Nice to have access from both sides
If this is your house the Ozco ones are the best
Stunt Carpenter is offline
Old 05-28-2019, 06:07 PM   #5
JFM constr's Avatar
Re: Gate Latches
yes! these are definitly a good latch that can handle alot of the changes in the gate due to settling and shrinking . easy to use .not very expensive but effective .
Old 05-29-2019, 11:45 PM   #6
GC/carpenter
Calidecks's Avatar
Rewards Points: 16,490
Re: Gate Latches
My favorite can be locked or either side with a key.
https://www.amazon.com/Keystone-Diec...63574964&psc=1
Mike.
_______________
Calidecks is offline
Recommendation for thick gate locking hardware sy85 Decks & Fencing 0 09-28-2017 12:42 AM
Is a pressure treated mortise and tenon gate a good idea? Woodsmith.Ryan Decks & Fencing 9 10-31-2014 05:47 AM
Idea's for a gate problem ContractorDFW Welding & Steel Trades 12 02-04-2013 12:35 PM
Elite miracle one gate operator problem wlcm2ericcntry Electrical 11 04-08-2011 03:46 PM
Vinyl fence gate posts Danno6102 Decks & Fencing 6 10-20-2008 09:42 PM
