Free Siting Deck - Decks & Fencing - Contractor Talk
Free Siting Deck
Old 07-09-2015, 07:55 PM   #1
D.S.I.'s Avatar
Trade: REMODELING
Rewards Points: 277
Free Siting Deck
I was approached to build a 13' x 15' deck basically at ground level, or a step up. Being in Northern Illinois I planned on piers and the whole deal, but then I had the idea of over killing it and setting it on several large pavers. Is that a terrible idea? It will be in the middle of the yard, 8" above grade.
D.S.I. is offline
Old 07-09-2015, 08:04 PM   #2
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 152
Re: Free Siting Deck
Ah...what?
Andy.
ScipioAfricanus is offline
Old 07-09-2015, 08:34 PM   #3
dvatt's Avatar
Rewards Points: 380
Huh
dvatt is offline
Old 07-09-2015, 08:46 PM   #4
SamM's Avatar
Trade: Carpenter/Handyman
Rewards Points: 1,484
I think he wants to build a deck and use pavers instead if piers.
I think your gonna have some airflow issues either way (if I'm reading it right). Maybe best to do a patio?
Your Dreams won't work unless you do.
SamM is offline
Old 07-09-2015, 08:58 PM   #5
FrankSmith's Avatar
Rewards Points: 5,124
I think he wan't to set the deck on blocks instead of pour piers.
FrankSmith is offline
Old 07-09-2015, 09:03 PM   #6
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
13 x 15' , 12 piers, flush framed with 2x6, 8'' above grade.
What's the problem ?
J.
John Hyatt is offline
Old 07-09-2015, 09:18 PM   #7
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
I would use 1 big pier, a concrete patio
killerdecks is offline
The Following 3 Users Say Thank You to killerdecks For This Useful Post:
greg24k (07-10-2015), SelectDecks (07-09-2015), slowsol (07-09-2015)
Old 07-09-2015, 09:45 PM   #8
deck aficionado
SelectDecks's Avatar
Trade: General Building
Rewards Points: 973
If deck surface will be 8" above grade I say too low for a deck. 2x8 would put you 3/4" from the ground, not the greatest. 2x6 put you 2 3/4 but you're framing a deck with 2x6, even worse
James
www.selectdecks.com
SelectDecks is offline
Old 07-09-2015, 10:56 PM   #9
GC/carpenter
Calidecks's Avatar
Rewards Points: 2,914
It depends on the span. I do it on every manufactured home I build, with zero bounce. Approved by the state of Cali. Not to mention they sit on 4x6 girders.
Free Siting deck-1436500643247.jpg   Free Siting deck-1436500668403.jpg   Free Siting deck-1436500688261.jpg   Free Siting deck-1436500705126.jpg
Calidecks is online now
Old 07-10-2015, 03:54 AM   #10
John Hyatt
John Hyatt's Avatar
It has everything to do with the span, not the width of the framing material.
Moisture Shield has no ventilation requirements far as ground clearance goes it can be installed in the water if ya want.
Low level decks are money makers for Me.
J.
Old 07-10-2015, 05:26 AM   #11
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,886
Hey Cali, how are those temp. railings blocking the patio doors being held on?
Aztec Decks
Oshawa deck builder
heavy_d is offline
Old 07-10-2015, 09:24 AM   #12
GC/carpenter
Calidecks's Avatar
They were screwed on. The manufacturer put those on
Old 07-12-2015, 07:17 PM   #13
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
why not just buy a few more pavers and call it a day?
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 07-12-2015, 07:59 PM   #14
TG Deck's Avatar
Trade: exterior carpentry
Rewards Points: 1,770
Nothing wrong with 2x6' framing done the right way.
Most everything down this way is ground/grade level.
A different world, maybe, to many people.
Then we can get into the people that want the deck level flush with the small crete patio right outside their door....
TG Deck is offline
Old 07-16-2015, 10:04 PM   #15
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,222
did a deck about that high off the ground recently .created a real nice space. i put in a ton of small concrete piers . but it seems like a bunch of pavers would work fine .there is that issue with air .gap the boards wider ,3/8 might be nice. the 2x6 joice seem better then 2x8 allowing some potential drying out with the little bit of space between joice and ground
JFM constr is online now
Deck 1983 Bunited2 Decks & Fencing 5 11-27-2012 02:40 PM
Deck Railing FinishingEdge Decks & Fencing 27 11-04-2012 05:09 PM
Deck Fire greg24k General Discussion 8 10-10-2012 12:19 AM
Free standing pool deck ?'s WarnerConstInc. Decks & Fencing 15 08-06-2008 08:44 AM
