Footings - Page 4 - Decks & Fencing - Contractor Talk
Footings
Old 04-26-2015, 03:44 PM   #61
GC/carpenter
Calidecks's Avatar
Rewards Points: 21,370
Re: Footings
Originally Posted by redwood View Post
I thought your holes were only 18" deep
If I charge 300 bucks a footing it's because it's only 16 or 18 inches deep. Of course there's times I have to go deeper. If I said never I beg your pardon.
I would say 90% are no more then 16 or 18. Some lower decks get zero footings
Calidecks is online now
Old 04-26-2015, 03:52 PM   #62
Tom M's Avatar
Rewards Points: 4,348
Re: Footings
Have any of you California boys had mud slides issues?
Tom M is offline
Old 04-26-2015, 03:53 PM   #63
GC/carpenter
Calidecks's Avatar
Re: Footings
This deck here had zero holes.
Old 04-26-2015, 03:55 PM   #64
GC/carpenter
Calidecks's Avatar
Re: Footings
I've never had it happen on one of my jobs, but if the hill is going to collapse there's not much chance anything will hold, including the home. They have them quite often actually. I have an earth movement exclusion in my contract.
RobertCDF (04-26-2015)
Old 04-26-2015, 04:02 PM   #65
Tom M's Avatar
Re: Footings
Nice pictures Mike and of course great work.
Question: What are those jack stand looking things?
Tom M is offline
Old 04-26-2015, 04:04 PM   #66
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Footings
I see them on trailers around here. They put a bunch of them under it and jack them up and level them out. I'm always amazed they don't sink into the ground when it's wet
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
Tom M (04-26-2015)
Old 04-26-2015, 04:10 PM   #67
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
Re: Footings
There's some work involved
for that kind of money we would use a mixer, and drag our stuff to the site in tea spoons
killerdecks is offline
Old 04-26-2015, 04:18 PM   #68
GC/carpenter
Calidecks's Avatar
Re: Footings
This particular gentleman didn't want that much permanent concrete in the ground. Those things will hold 18000 lbs each. Yes they are mobilhome pier jacks. They've been working well for 50 years. absolutely zero movement if done properly. I use a drawing issued by the state of Cali to get them approved. Makes it tough for cities to deny them when I show them a state standard drawing.
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
BCConstruction (04-26-2015), Tom M (04-26-2015)
Old 04-26-2015, 04:18 PM   #69
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
Re: Footings
The only experience I've had with mudslides is my own house and it didn't involve a deck.
While we were in Hawaii of course, there was a small slide from above our house on to the driveway. The week we got back, retaining walls went up.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 04-26-2015, 04:20 PM   #70
redwood's Avatar
Rewards Points: 496
Re: Footings
This particular gentleman didn't want that much permanent concrete in the ground. Those things will hold 18000 lbs each. Yes they are mobilhome pier jacks. They've been working well for 50 years. absolutely zero movement if done properly. I use a drawing issued by the state of Cali to get them approved. Makes it tough for cities to deny them when I show them is a state standard drawing.
I think if I submitted those to one of my building departments, they would laugh at me.
Mark
Pioneer, CA
redwood is offline
The Following User Says Thank You to redwood For This Useful Post:
John Hyatt (04-26-2015)
Old 04-26-2015, 04:21 PM   #71
GC/carpenter
Calidecks's Avatar
Re: Footings
To bad. They work great.
Old 04-26-2015, 04:41 PM   #72
Trade: Construction
Re: Footings
If there's trailers anywhere in your area they prob allow them for decks. Trailers weight vastly more than a deck does too. I wish I had a bunch more ground level decks but they are few and far between here.
Old 04-26-2015, 04:47 PM   #73
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Re: Footings
Originally Posted by Dan_Watson View Post
Do you get a separate dumpster for the dirt or just in the same with the rest of the construction debris?
Same roll off. We get 30yd roll offs 99% of the time. The only time we get smaller is if there is not an existing deck (rare).
RobertCDF is offline
Old 04-26-2015, 04:47 PM   #74
GC/carpenter
Calidecks's Avatar
Re: Footings
Decks about 36" are a godsend for bad backs.
Old 04-26-2015, 05:02 PM   #75
RobertCDF's Avatar
Re: Footings
If you're pouring a bunch of piers you gotta make some changes to your design. I have 8 piers on the current one (2 are because of a cantilever in the house where the hot tub is going to go) and it is spec'd to hold a 550 gal hot tub, has a roof cover and a built in stone BBQ, and it's 14'x50'. No point in putting in a forest of posts. Of course we also had 4.5 yds of concrete in the piers. still WAY cheaper than 10-15 more holes and 10-15 more 6x6 posts. At a cost of ~$80 for a 6x6x10' cedar post plus the labor to cut (notch for beam to sit on) and all the hardware, you could save money by using less piers.
I'm sure you would all agree if you're digging in rocky conditions it's usually easier to dig a 24" diameter hole than it is to dig a 12" dia hole. If you own a drill it's really almost a wash.
Old 04-28-2015, 07:18 AM   #76
Dan_Watson's Avatar
Rewards Points: 2,688
Re: Footings
That is highly frowned upon here. One or two holes they wont know but anything more and they are going to say no more dumpsters if it happens again.
No dirt, no concrete, no electronics.
Dan_Watson is online now
Old 04-28-2015, 02:19 PM   #77
Keeyter's Avatar
Trade: Home Remodels
Rewards Points: 851
Re: Footings
I do a bit different - I base my off size and depth. Frost line here usually dictates but at a minimum 48" and I do a flat $5 an inch diameter per foot. 12" Hole 48" Deep 12" x $5 x 4' = $240
Now if I hit crappy soil or like the last one, an abandon septic tank that magically appeared, I had to either dig three additional holes or go down 15 Feet - I would like to try helical but I don't see much of that around here.
Keeyter is offline
Old 04-28-2015, 02:22 PM   #78
Keeyter's Avatar
Rewards Points: 851
Re: Footings
I agree but we do alot of low decks that require 2 x 6 for beams and spans on that sucks. On elevated and second story decks you can go nuts with beam sizing but not that low crap
Keeyter is offline
Old 04-28-2015, 02:28 PM   #79
Dan_Watson's Avatar
Re: Footings
Steel. Why deal with that PT crap.
Salesman out.
Old 04-28-2015, 04:52 PM   #80
Talking Head
EthanB's Avatar
Rewards Points: 310
Re: Footings
Salesman out.
Between the steel and helical it's like RobertCDF and Greg Di had a baby.
I don't mind though. If enough of you guys get the word out then it will make it easier for me to switch.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
Dan_Watson (04-28-2015)
Deck with no footings? brhokel606 Decks & Fencing 30 07-05-2014 12:23 PM
Adding on to porch footings openhearth Masonry 4 11-13-2013 12:38 AM
Shoddy Footings What to do? paul6 Masonry 40 05-03-2010 09:30 PM
Freestanding Deck Footings on a Newer Construction Home crazyson2001 Decks & Fencing 33 09-02-2009 03:48 PM
matching footings to footings ApgarNJ Masonry 10 06-07-2006 06:49 AM
